Researchers at the Duke University Developed the World’s First Fully Recyclable Printed Electronics
With the increase in demand for wearable electronic devices, the need for flexible, thin, and compact electronic circuits also arises. Wearable devices and many other sophisticated systems need sensors that can be attached to various kinds of surfaces or substrates. Therefore, it is necessary for the sensors to be flexible and also hold the same electrical property. In addition, there is a constantly growing demand for flexible indicators and displays. The most crucial component of an electronic system is, however, the transistor. There is a lot of research and development ongoing for Thin-Film Transistors (TFTs). These special types of transistors are made by depositing thin films of the semiconductor layer as well as the dielectric layer and metallic contacts on a non-conducting substrate.
Printed Electronics: A Summary
Very thin electronic devices and circuits are part of the printed electronics terminology. Printed Electronics is a new way to manufacture electronic components and circuits. It refers to the process in which printing technology is utilized to produce various electronic circuits, displays, sensors, RFID systems, solar cells, etc. We’re all aware of conductive ink which is an ink that can result in a printed object which conducts electricity. It is created mainly by infusing graphite. Similarly, some well-known technologies for printing electronics are gravure, flexographic, offset, and inkjet printing. Flexographic printing can print the thinnest layers while gravure is the fastest technique for printing electronic circuits.
The printing is based on organic conducting, semiconducting as well as printable organic materials. The printed transistors are fabricated on thin plastic film substrates with various printing processes. Thin-film transistors can also be based on organic semiconductors. The benefit of organic printing is its eco-friendliness.
An Overview of a Research at the Duke University on Fully Recyclable Printed Electronics
The market for printed electronics is constantly growing. The market was predicted to increase to 45 billion USD in 2021. With this, some questions arise like what happens when the printed electronics become waste? Can they be recycled? The silicon-based systems cannot be recycled easily and they just add up to landfills. Similarly, in printed electronics, the use of nanomaterials is a crucial part.
Engineers at the Duke University have successfully developed the world’s first fully recyclable printed electronics. They demonstrated the creation of transistors with three-carbon-based inks. These transistors can be easily printed onto paper or other flexible materials. Carbon nanotubes and graphene inks are used for semiconductors and conductors respectively. The recyclability is due to the use of nanocellulose ink which is derived from wood.
“Nanocellulose is biodegradable and has been used in applications like the packaging for years,” said Aaron Franklin, the Addy Professor of Electrical and Computer Engineering at the Duke University. He further added, “And while people have long known about its potential applications as an insulator in electronics, nobody has figured out how to use it in a printable ink before. That’s one of the keys to making these fully recyclable devices functional.”
The researchers developed ways for suspending crystals of the extracted nanocellulose which will act as an insulator in printed transistors. The team showed that their recyclable printed transistor is well enough for use in a variety of applications, even six months after the initial printing. Further, the recycling process recovers 100% of the materials and the materials lose very little of their properties.
“Recyclable electronics like this aren’t going to go out and replace an entire half-trillion-dollar industry by any means, and we’re certainly nowhere near printing recyclable computer processors,” said Franklin. “But demonstrating these types of new materials and their functionality is hopefully a stepping stone in the right direction for a new type of electronics lifecycle.”
The detailed information about the research can be found at https://pratt.duke.edu/about/news/recyclable-printed-electronics
Programmable Frequency – Continuous Conduction Mode (CCM) – Boost Power – Factor Correction (PFC) Controller
The circuit described here is a simple PFC controller using the UCC28180 chip from Texas instruments. The controller operates under average current mode control at a fixed programmable switching frequency of 116 kHz. Simple external current and voltage loop compensation, along with advanced protection features, make this controller ideal for server and desktop power supplies, industrial power supplies, and white goods. The module is a flexible and easy-to-use, active Power-Factor Correction (PFC) controller that operates under Continuous Conduction Mode (CCM) to achieve high Power Factor, low current distortion, and excellent voltage regulation of boost pre-regulators in AC – DC front-ends. The controller is suitable for universal AC input systems operating in 100-W to few-kW range with the switching frequency programmable between 18 kHz to 250 kHz, to conveniently support both power MOSFET and IGBT switches. An integrated 1.5-A and 2-A (SRC-SNK) peak gate drive output, clamped internally at 15.2 V (typical), enables fast turn-on, turn-off, and easy management of the external power switch without the need for buffer circuits. Low-distortion wave shaping of the input current using average current mode control is achieved without input line sensing, reducing the external component count.
In addition, the controller features reduced current sense thresholds to facilitate the use of small-value shunt resistors for reduced power dissipation, especially important in high-power systems. To enable low current distortion, the controller also features trimmed internal current loop regulation circuits for eliminating associated inaccuracies. The module requires few external components to create a complete PFC Controller. In the future, we will publish few PFC drivers using this module. Refer to the datasheet of UCC28128 to configure the board as per requirement.
  • Supply 12 to 15V DC
  • Default Frequency 116Khz (Programable 18Khz to 250Khz Resistor R9, R12)
  • Average Current Mode PWM Control
  • NO AC Line Sensing Needed
  • Soft Over Current and Cycle by Cycle Peak Current Limiting
  • Voltage Regulation Open Loop Detection
  • Output Over-Voltage Protection with Hysteresis Recovery
  • Enhanced Dynamic Response
  • Soft-Start
  • PCB Dimensions 29.21 x 16.67 mm
Schematic
Parts List
NO.QNTY.REF.DESC.MANUFACTURERSUPPLIERSUPPLIERS PART NO
11CN110 PIN MALE HEADER 2.54MM PITCHTEMOUSER571-1-825433-0
25D1,C1,C4,R7,C10DNP0MIT
31C22K2 5% SMD SIZE 0805MURATA/YAGEOMOUSER
41C31KPF/50V SMD SIZE 0805MURATA/YAGEOMOUSER
51C50.47uF/50V SMD SIZE 0805MURATA/YAGEOMOUSER
61C64.7uF/50V SMD SIZE 0805MURATA/YAGEOMOUSER
71C710uF/25V SMD SIZE 1210MURATA/YAGEOMOUSER
81C80.1uF/50V SMD SIZE 0805MURATA/YAGEOMOUSER
91C9820PF/50V SMD SIZE 0805MURATA/YAGEOMOUSER
101D2LED SMD SIZE 0805DIALLIGHTMOUSER645-599-0120-007F
111R121.5K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
121R291K 1% SMD SIZE 1206MURATA/YAGEOMOUSER
131R3910K 1% SMD SIZE 1206MURATA/YAGEOMOUSER
141R43K 1% SMD SIZE 1206MURATA/YAGEOMOUSER
151R51E 1% SMD SIZE 1206MURATA/YAGEOMOUSER
161R61K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
171R813K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
181R916K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
191R1022.6K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
201R11300E 1% SMD SIZE 0805MURATA/YAGEOMOUSER
211R121.8K 1% SMD SIZE 0805MURATA/YAGEOMOUSER
221U1UCC28180TIMOUSER595-UCC28180D
Application Circuit
Connections
Block Diagram
Gerber View
Photos
Video
UCC28180 Datasheet
Luminus Devices MP-2835 Mid-Power LEDs feature a thermally enhanced package
Luminus Devices MP-2835 Mid-Power LEDs are lighting class solutions that are designed to provide high luminous flux output and high current capability. These LEDs operate at 5V reverse voltage (VR) and -40°C to 85°C operating temperature range. The MP-2835 LEDs feature a thermally enhanced package design and are available in compact package sizes. These LEDs are used in applications such as horticulture, architectural, decorative, billboard light, and industrial.
  • Thermally enhanced package design
  • High luminous flux output
  • High current capability
  • Compact sizes
  • Pb-free reflow soldering application
  • RoHS compliant
  • 5V reverse voltage (VR)
  • -40°C to 85°C operating temperature range
more information: https://www.luminus.com/products/midpower
C&K Switches PTS847 SMD Side Actuated Tactile Switches
C&K PTS847 switches are 4.6mm x 2.2mm side actuated SMT tactile switches. These normally open SPST momentary switches offer an estimated life of 200k cycles. C&K PTS847 switches offer a variety of configurations, including actuation force (160gf or 350gf), actuator options (hard or soft), and shielding (with or without L shaped shield). These tiny surface mount switches are suitable for a variety of small electronics controls.
  • 4.6mm x 2.2mm 2.6mm package
  • 160gf and 350gf variants
  • Side actuation
  • SMD termination, with or without L shape shield
  • Hard and soft actuator variants
  • 200,000 estimated cycles
  • .95mm height above PCB (edge mount)
  • .15mm travel distance
more information: https://www.ckswitches.com/products/switches/product-details/Tactile/PTS847/
Fluke TiS 55+ and TiS 75+ Thermal Imagers
Fluke Electronics’ thermal imagers allow for simplified proactive maintenance
Fluke Electronics’ proactive maintenance (PM) program helps maintenance teams and the bottom line by allowing users to see what is working well or if something is about to break down before that happens. To get started, the TiS55+ and TiS75+ thermal imagers have the features to easily set up image organization and inspection routines.
With the TiS55+ and TiS75+, executing a successful preventative maintenance program will not take long. This system makes a clipboard to record notes for numerous inspections unnecessary. It becomes easier than ever to keep track of what has already been inspected. Save time and improve the reliability of maintenance data by wirelessly syncing measurements using the Fluke Connect system.
  • Eliminate data-entry errors by saving measurements directly from the tool and associating them with the work order report or asset record
  • Maximize uptime and make confident maintenance decisions with trustworthy and traceable data
  • Move away from clipboards or notebooks and multiple spreadsheets with a wireless one-step measurement transfer
  • Access baseline, historical, and current measurements by asset
  • Share measurement data using ShareLive™ video calls and emails
  • The TiS55+ and TiS75+ infrared cameras are part of a growing system of connected test tools and equipment maintenance software
more information: https://www.fluke.com/en-us/product/thermal-cameras/tis55plus
2D CMOS PDF417 customized mini-size auto-sensing embodied barcode scanner module
Image sensors are the crucial part of various analog and digital electronic devices such as digital cameras, webcams, camera phones, camera modules, optical mouse devices, medical applications, night vision cameras, thermal cameras, barcode scanners, radar, sonar, and many others. An image sensor is a type of sensor that detects and conveys information used to make images. The information is the variation in light waves. This data of attenuation of the light waves are converted to electrical signals. The signals created are like short bursts of current that carry information. The image sensors mostly use either CCD (Charge Coupled Device) or CMOS technology.
CCD Technology-based Image Sensors
CCDs (Charge Couple Devices) use MOS (Metal-Oxide-Semiconductor) capacitors and CMOS amplifier stage for image sensing. Here, an array of MOS capacitors is employed, each carrying an electric charge corresponding to the light intensity of a pixel. With the help of a control circuit, the charge from one capacitor is transferred to its neighboring capacitor. The process here is similar to the data transfer in shift registers. The charge from the last capacitor in the array is transferred to a charge amplifier. The charge amplifier reads the quantity of that charge and in this way, an image is formed. The CCD-based image sensors are used in high-end broadcast systems where quality is a concern.
CMOS Technology-based Image Sensors
CMOS image sensors are also based on MOS technology like the CCD technology. But in this technology, a photodiode, and a MOSFET is used for each pixel. This allows the pixel data to be amplified individually. With this approach, the CMOS image sensors achieve a higher data rate than CCDs. Further, noise occurrence is also low in CMOS technology. In addition, CMOS image sensors cost less to produce and are preferred in compact devices due to their low power consumption.
About the 2D CMOS PDF417 Barcode Scanner module
2D CMOS barcode scanners are very popular nowadays due to their high quality, range, and low price. 2D barcode scanners can scan 1D barcodes as well as 2D codes such as QRCodes and data matrices. 2D CMOS PDF417 scanner module is a very compact auto-sensing barcode scanner module that supports the TTL interface. It is specially designed for PDF417. PDF417 is a stacked linear barcode format used in a variety of applications such as transport, identification cards, and inventory management. “PDF” stands for Portable Data File. The “417” signifies that each pattern in the code consists of 4 bars and spaces in a pattern that is 17 units (modules) long [1].
It has the following features:
  • Specially Designed for PDF417
  • CMOS image sensor,reads 1D & 2D barcodes.
  • No driver, plug and play.
  • Supporting TTL interface.
  • A wide-angle lens design that scans a large area.
  • Super scanning and decoding ability, can read incomplete and fuzzy codes.
  • The scanner reads 2D & 1D barcodes printed. on labels or displayed on device screens.
  • Mini size and lightweight easy to be integrated into various solutions such as kiosks flow line. medical equipment. ticketing machines, PDA. vending machines, and many more.
  • Can be customized according to customer demand.
Store Website: https://www.aliexpress.com/item/10000386520899.html
References:
BleuIO: BLE 5.0 USB Adapter
The USB Bluetooth dongles are quite popular nowadays. Most wireless computer mouse comes with a USB Bluetooth dongle which enables wireless communications to your PC. A USB Bluetooth dongle is a very quick and inexpensive means to allow Bluetooth communications onto your computer. To use the dongle, you simply need to plug it in the USB port of your PC and any Bluetooth peripheral devices will be able to communicate with your PC. You can connect various peripherals like cellphones, printers, PDAs, Wireless earphones, wireless keyboards, etc.
A USB Bluetooth dongle has a built-in antenna that has a range of 2 to 100 meters and operates on a 2.4GHz frequency band. The Bluetooth dongles are used for various applications like transferring videos, photos, and in many other applications like this.
Bluetooth Low Energy
Bluetooth Low Energy (BLE) is a wireless personal area network technology independent of the classic Bluetooth and has distinct compatibility. The original BLE specifications were developed by Nokia in 2006 under the name Wibree and are intended for applications in fitness products, healthcare, security, and home entertainment. BLE features a significant reduction in power consumption and also cost as compared to standard Bluetooth. Very low-power devices which operate for months or years on a button cell uses BLE for communication. However, a similar communication range is maintained and the same 2.4GHz frequency band is used.
As mentioned earlier, BLE’s compatibility is different from the basic Bluetooth protocol but BR/EDR and LE systems are permitted.
Bluetooth 5.0
Bluetooth 5.0 is the latest Bluetooth standard in the industry. Bluetooth 5.0 supported devices can transfer data at up to 2Mbps speed which is twice the speed of Bluetooth 4.2. In addition, the range is extended up to 260 feet (if no walls interfere). BLE 5.0 will have a big impact on smart home systems and other IoT devices as per the experts. Low energy, increased range, and increased speed means that the devices can switch over from Wi-Fi.
About BleuIO
BleuIO is a Bluetooth Low Energy USB dongle that can support BLE 5.0 devices. It can be used to create new BLE 5.0 applications in the fastest and easiest way. To use it, you just need to utilize the AT commands already available on the device. It is built around Dialog Semiconductor’s latest Bluetooth chip DA14683. The chip supports Bluetooth 5.0 and Bluetooth Mesh. Its flexible architecture ensures plenty of processing capacity when needed and goes in power-saving mode when there is no need. It allows multi-sensor arrays and also has extensive memory capacity. In a nutshell, the chip is a very integrated solution providing the benefits of MCU and Bluetooth compatibility on a single chip.
The BleuIO USB adapter comes with the following features:
  • Compatible with Windows 10, macOS, and Linux.
  • One can update the firmware or flash their applications with the integrated bootloader.
  • Low Energy
  • Just use the AT commands already on the device.
  • Custom settings can be stored on flash memory or OTP
The JavaScript and Python libraries for BleuIO are available for software development support.
BleuIO Tindie page: https://www.tindie.com/products/axelh/bluetooth-50-usb-adapter-ble/
2.8” Compact Low-Power Graphic LCDs
EA Display Visions’ chip-on-glass 128 x 64 graphic LCD is compact, low-power, and pin-connected
EA Display Visions’ DOGL128 series 2.8″ graphic LCDs are available in FSTN positive transflective, STN positive transmissive, STN negative transmissive, FSTN negative transmissive, and STN positive reflective versions. These displays have a 2.54 mm pitch and can be soldered directly or plugged into socket strips. Therefore, cumbersome gluing procedures, the need for designing a special mounting device, and error-prone cable connections that may lose contact are no longer a concern.
The extremely efficient ratio of external dimensions to the active display area helps in designing very compact devices. Furthermore, its low power use (single supply 2.5 V to 3.3 V (typically 250 µA)) makes it ideal for handheld applications.
The EA 9780-4USB development board and free windows simulator are all that users require to evaluate pin-connected chip-on-glass LCDs with and without backlight. Simply plug the 2.54 mm connector pins of the display into the socket strips of the development board. Proprietary hardware or software development is not required, and decisions can be made quickly at a minimum expense.
  • High-contrast LCD supertwist display (STN and FSTN) with 15 µm dot-gap
  • Optional LED backlights in various colors
  • 128 x 64 pixels (corresponds to 8 x 21 characters or 4 x 16 large characters)
  • ST7565R controller with SPI (4-wire) interface
  • Power supply: single supply 3.0 V to 3.3 V (typically 320 µA)
  • No additional voltages required
  • Operating temperature range: -20°C to +70°C
  • Storage temperature range: -30°C to +80°C
  • LED backlighting 5 mA to 90 mA
  • No mounting required, simply solder onto PCB
more information: https://www.lcd-module.de
EnOcean is presenting the PTM 535BZ module that combines two radio standards in one product
EnOcean, the world’s leading developer of energy harvesting wireless technology, is presenting the PTM 535BZ module, the latest addition to its range of transmitter modules wireless technology for battery-free switch applications. In addition to the already established PTM 535 for the EnOcean wireless standard and PTM 535Z for Zigbee applications, PTM 535BZ is the first module that offers a combination of supported wireless standards in the 2.4 GHz radio band. In conjunction with the EnOcean ECO 200 harvester, PTM 535BZ enables the realization of energy harvesting wireless switches communicating based on Bluetooth Low Energy (BLE) or Zigbee Green Power (ZGP) radio standards. Thanks to the integrated Near Field Communication (NFC) interface, it is easy to switch between the two radio standards depending on the application.
Combined radio standards and NFC for an easy integration
With the new PTM 535BZ module, EnOcean is setting a new standard among battery-free and wireless radio transmitter modules. Until now, energy harvesting modules were designed to use only one radio protocol – EnOcean, Bluetooth or Zigbee Green Power – for data transmission. The newly developed PTM 535BZ is the first module that integrates the two 2.4 GHz protocols BLE and ZGP into one product. This gives users the option of selecting one of these two protocols for transmission depending on their needs. On top, PTM 535BZ is also the first module from the product range to be equipped with an NFC interface; a technical challenge due to the very small form factor. The use of NFC makes configuration much easier and also saves valuable time during installation. It also allows selecting between BLE and ZGP radio protocol and defining all configuration parameters using an NFC-enabled smartphone or, alternatively, a PC with an NFC reader.
“We want to support our customers as best we can with new developments and make the integration and commissioning of our products as simple as possible,” says Matthias Kassner, Vice President Product Marketing, EnOcean GmbH. “The fact that the module supports two wireless standards means that the same end product can be used in various applications. This saves customers not only time but also costs, both being important factors when choosing a product.”
Uniform form factor
As with the existing PTM 535 models for the EnOcean radio standard and PTM 535Z for ZGP, EnOcean is again relying on the same form factor for PTM 535BZ. This offers customers a fast integration into already existing mechanical designs. At the same time, there are almost no limits to the possible radio switching applications due to wireless and battery-free operation and the worldwide usability of 2.4 GHz radio solutions. These include stop buttons in public buses, mechanical door and window sensors or even mini switches for the private home, e.g. to switch household appliances on and off.
For more information, please visit www.enocean.com
TOP PCB Companies
