MPS’ MP8770C is a 3 V to 17 V, 8 A, synchronous step-down converter with forced CCM
The MP8770C from Monolithic Power Systems is a fully integrated, high-frequency, synchronous rectified step-down switch-mode converter with internal power MOSFETs. The device offers a very compact solution to achieve 8 A of continuous output current with excellent load and line regulation over a wide input range. It uses synchronous mode operation for higher efficiency over the output current load range. Constant on-time (COT) control operation provides a very fast transient response, easy loop design, and very tight output regulation. Full protection features include short-circuit protection (SCP), overcurrent protection (OCP), Undervoltage protection (UVP), and thermal shutdown. The MP8770C requires a minimal number of readily available, standard external components and is available in a space-saving QFN-16 (3 mm x 3 mm) package.
  • Operating input range: wide 3 V to 17 V
  • Output current: 8 A
  • 22 mΩ/10 mΩ low RDS(ON) internal power MOSFETs
  • Quiescent current: 100 μA
  • Output adjustable from 0.6 V
  • High-efficiency synchronous mode operation
  • Pre-biased start-up
  • Fixed 700 kHz switching frequency
  • Forced PWM operation
  • External programmable soft-start time
  • EN and power good for power sequencing
  • OCP and hiccup mode
  • Thermal shutdown
  • Available in a QFN-16 (3 mm x 3 mm) package
more information: https://www.monolithicpower.com/en/mp8770c.html
Pico-EZmate Plus 1 mm-Pitch Connectors
Molex’s connectors are ideal for automated assembly processes in tight-spaced applications
With a current rating of up to 2.8 A and an improved withdrawal force, Molex’s compact Pico-EZmate Plus 1 mm-pitch connector deliver high performance in a low-profile height, making them ideal for automated assembly processes in tight-spaced applications across various industries. Pico-EZmate Plus has thicker housing side walls which improve withdrawal force over the original Pico-EZmate, increasing mating security. This series also provides a low profile to provide space real estate savings in a sleek design, with an open-top receptacle header allowing for easy snap-in mating for speedy assembly processing.
  • Voltage (max.): 50 V
  • Current (max.): 2.8 A (two circuits)
  • Contact resistance (max.):
    • 20 mΩ
    • 5 mΩ (on crimped portion)
  • Dielectric withstanding voltage: 500 VAC insulation
  • Resistance (min.): 100 MΩ
  • Housing: polyamide, UL94V-0
  • AWG size: 28 and 30
  • Contacts: copper alloy
  • Plating: gold
  • Operating temperature range: -45°C to +105°C
  • Contact insertion force (max.): 18 N
  • Contact retention to housing (min.): 3.5 N
  • Durability (min.): 10 cycles
more information: https://www.molex.com/molex/products/part-detail/crimp_housings/2121320002
Marktech Optoelectronics High Power SMD UV Emitters
Marktech Optoelectronics High Power SMD UV Emitters offer a peak emission wavelength range of 275nm to 385nm. The Marktech High power UV LEDs are designed for high current and high power output operations. The devices combine state-of-the-art SMD design and low thermal resistant material in one package.
The High Power UV Emitters are ideal for disinfection, UV curing, and chemical and biological analysis.
  • Deep ultraviolet LED
  • Low thermal resistance
  • SMT solderable
  • Super high power output
  • SMT solderable
  • Designed for high current operation
more information: https://marktechopto.com
Parker Expands Thermal Interface Materials Offering
The Chomerics division of Parker Hannifin Corporation, the global leader in motion and control technologies, announced the launch of THERM-A-GAP GEL 75, a 7.5 W/m-K single component dispensable thermal interface material designed for high-performance applications.
THERM-A-GAP GEL 75 is a single component, gel material best suited for today’s high-powered electronics applications. When applied to a heat-generating component, THERM-A-GAP GEL 75 provides minimal stress and pressure due to its low compression force and represents the highest thermal conductivity dispensable available from Parker Chomerics. Its flow rate is nearly 3x faster than the next closest performing material in the THERM-A-GAP family.
THERM-A-GAP GEL 75 is best suited for high volume, automated production, specifically found in telecommunications equipment, automotive safety electronics modules, power supplies, and memory and power modules.
The opportunity for automation is a significant advantage for THERM-A-GAP GEL 75 over thermal gap pads because gel dispensing systems allow for the support of multiple size and thickness requirements with a single system configuration. While thermal gap pad placement can be automated to an extent, the equipment and fixturing required to do so is typically quite specialized and may not be readily adapted from one job to another.
“GEL 75 was formulated to accommodate the future high-power demands of many different markets, including 5G enabled telecom infrastructure, automotive applications — any application that is seeing increased bandwidth demands that generate excessive heat.”
says Brian Mahoney, Global Thermal Business Unit Manager, Parker Chomerics. “It is the next evolution in our THERM-A-GAP gap filler family of easy to use, reliable, high performance, single-component dispensable gels.
THERM-A-GAP GEL 75 is now available globally in different sizes of syringes, cartridges, and pails to suit a wide variety of customer needs. Learn more about THERM-A-GAP GEL 75 and the THERM-A-GAP family of products at www.parker.com/chomerics.
SparkFun Thing Plus nRF9160 Development Board Gets Cellular Connectivity
SparkFun Thing Plus- nRF9160
We have yet another Feather form factor board that is released by SparkFun in association with CircuitDojo, which is powered by the famous Nordic nRF9160 microcontroller, SparkFun Thing Plus- nRF9160, designed for users working in smart cities and smart agriculture applications. Last year there had been a crowdfunding project on nRF9160 Feather v2 by CircuitDojo that was funded over 100%. Moving forward, this board is assumed to be taken from the crowdfunding campaign as it has a small form factor with immense wireless communication capabilities.
The integrated Nordic’s nRF9160 SiP is a next-generation chip for LTE-M and NB-IoT wireless protocols. Along with this, the SiP gets ARM Cortex-M33 CPU running at 64 MHz frequency, featuring 1 MB flash memory and 256 KB RAM. Moreover, the ARM CPU also distinguishes through ARM TrustZone for trusted execution and ARM CryptoCell 310 for accelerated cryptography.
“This little chip is capable of both CAT M1 LTE and NB-IoT cellular communication and is designed to work with Zephyr, the go-to RTOS for embedded development. To make the Thing Plus even easier to use, this board utilizes our handy Qwiic Connect System which means no soldering or shields are required to connect it to the rest of your system!”
Video
One of the important highlights of this electronic development board is the wide support for wireless protocols. The support for CAT M1 LTE and NB-IoT cellular communication makes it exceptionally outstanding for various automation applications with the hardware running with Zephyr which is an RTOS for embedded development. Apart from these more details on wireless connectivity can be found on the product page.
When you buy the hardware, you need not worry about powering the development board, there are supports external LiPo batteries through the JST connector. Additionally, the development board is capable of interfacing with J-Link and CMSIS-DAP based programmers that basically allow you to program and debug the application software running on Arm Cortex Microcontrollers.
As you would have expected a sim card slot for cellular connectivity, the manufacturer has provided a sim card slot for which more details are available on the Hologram’s start page. To give you a rich experience by interfacing several sensors, SparkFun has provided a Qwiic Connector using Qwiic sensors which are plug-and-play types.
The SparkFun Thing Plus- nRF9160 is priced at $129.95 and can be bought via the SparkFun product page. If you buy this product, the manufacturer has already made the Hookup Guide available.
Aeotec’s Z-Pi 7 Z-Wave gateway module for your Raspberry Pi
If you have been using home automation devices to control, monitor, and status reading, they may employ the Z-Wave communication protocol. There have seen several SBCs that support the interface of the Z-Wave protocol, like the RK3568 development board. It is widely known for its ability to work among other wireless communication protocols like Wi-Fi, ZigBee, and other 2.4 GHz-based protocols. One such Z-Wave gateway is introduced by a Silicon Valley-based manufacturer Aeotec, Z-Pi 7 is designed to control actuators and sensors in a Z-Wave Plus network.
The Z-Pi 7 module is compared to Z-Stick Gen5+ with the major difference being the former is built around the Series 700 Z-Wave and the latter gets the Series 500 Z-Wave hardware. One of the interesting things when buying this module is that it lets you add the connectivity of the Z-Wave communication protocol to several SBCs, including Raspberry Pi and Orange Pi. However, the manufacturer has specifically designed the hardware for developers working on Raspberry Pi. For more information, the company has provided a detailed guide to get started with your favorite SBC.
Z-Pi 7 Z-Wave gateway modules
One of the other upgrades in the Z-Pi 7 over Z-Stick Gen5+ is the support for Gen7 devices that lay the foundation for smart homes and smart buildings. The hardware is built around the Silabs’ EFR32ZG14 Z-Wave 700 Modem SoC that is designed for gateways and controllers in smart home applications. For installation purposes, the manufacturer has given you the option to use GPIO connections with a power supply of 3.3V DC through these GPIOs.
The hardware doesn’t get a built-in rechargeable battery that is provided in its predecessors mentioned earlier. However, the installation process is considered to be very simple and easy for any developer working on SBCs. Note that the hardware uses the same port as the Bluetooth on the Raspberry Pi, so make sure you deactivate the Bluetooth before installing the module. This hardware opens several opportunities for the developers to explore the capabilities of the Z-Wave wireless communication protocol in smart home applications.
If you are interested in the Z-Pi 7 Z-Wave gateway, head to the official product page for a more detailed comparison with other existing modules.
CosmicWatch muon detector – Building a Cosmic Ray Detector
CosmicWatch is a project from MIT in the US and Poland’s National Center for Nuclear Research, that enables anyone with basic electronic skills to build a low-cost desktop detector for the muon particles which are created when cosmic rays collide with the earth’s atmosphere.
In this series of posts, we’ll take a look at constructing the CosmicWatch muon detector and where necessary, modifying the design very slightly to make use of more widely available parts.
The project is published in three parts as linked below:
  • Building a Cosmic Ray Detector Part 1: Introduction and Planning – [Link]
  • Building a Cosmic Ray Detector Part 2: Assembly and Initial Testing – [Link]
  • Building a Cosmic Ray Detector Part 3: Completion and Testing – [Link]
Linux and Windows Hardware boot selection switch
Stephen Holdaway has created a switch with “Linux” and “Windows” labels, enabling you to boot into the correct OS with ease. About the reason for creating the switch, he says:
“ Dual-booting Linux and Windows is a great way to get the best of both worlds, but there’s one thing that’s always bothered me. To boot into Linux, I simply press the power button and walk away. To boot into Windows on the other hand requires a tactical, precision-timed strike on the keyboard to change the selection when GRUB briefly reveals itself. Now I could just increase the GRUB selection timeout, or remove it entirely, but I’d still need to wait around to make an operating system selection. I could use the mode in GRUB that remembers the last OS selection, but I’d still need to be around to change it half the time. I could make a “reboot into Windows” action in Linux, but I’m just as often booting from a powered-off state as I am rebooting from Linux. Since I always know which operating system I want ahead of time, why not make a physical switch to select between Linux and Windows?”
For the project, he uses an STM32 microcontroller to act as a USB mass-storage device, which serves up a dynamic file. The file can be loaded by the system’s boot configuration to change its boot behavior based on the physical input.
Instead of him making a custom USB interface, he leverages the fact that the BIOS already enables GRUB, with access to all attached storage devices. All he did was to present the device as storage, containing a file whose contents indicate the switch position. This looks simple. However, there are a few layers to it:
  • Provide the mass-storage class descriptor, indicating one of several storage protocols to use (SCSI, ATA).
  • Implement the chosen storage protocol. This is a set of commands to interrogate the storage device’s capabilities, capacity, layout and other metadata in addition to standard requests to read and write sectors.
  • Emulate a valid filesystem when read from, without actually having any storage medium.
The next thing he did was emulating a filesystem that GRUB could understand. He picked FAT12 because it’s fairly well documented and has a simple layout, which are:
  • Boot sector: a fixed structure that describes the name and geometry of the volume
  • File Allocation Table: an index of which parts of the disk are used, and how large files are distributed/fragmented
  • Root directory entry: file metadata. pointing to where the actual file content lives
  • [No fixed structure on the rest of the disk]
After many activities, he had a setup where a list of virtual files could be defined, with the directory entries and file contents generated on the fly when requested by the unsuspecting host. After encountering setbacks because GRUB doesn’t have any built-in support for loading the contents of a file into a variable, nor does it support command substitution as typical Linux shells do, he came up with a better solution. Using GRUB’s “source” command to load additional config from a virtual file. This approach works out of the box, and in theory on any version of GRUB.
After successfully using the switch position in GRUB’s shell, the only thing left for him to do is to modify the system boot configuration to make its boot selection based on this information: In /etc/grub.d/00_header, add this to the generated output (escaping removed to make it easier to read) After running update-grub to generate the new boot configuration, the setup worked perfectly.
For the hardware, he used a little aluminum flat bar, a couple of screws, and some drilling, then he placed the device permanently under the lip of his desk, within arm’s reach. For more information about the project, and how you can make your own switch, visit the project write-up, and his GitHub repository.
How Can 5G mmWave Benefit IoT Applications
What is 5G mmWave
The millimeter wave (MM wave), also known as the millimeter band, is a spectrum band with wavelength ranging from 30 GHz to 300 GHz, which the International Telecommunication Union also refers to as the extremely high frequency (EHF) band. According to 3GPP, 5G NR (New Radio) mainly uses two frequency bands: FR1, also called the sub-6GHz frequency band, and FR2, which is mmWave. 5G can have several times or even dozens of times the network speed of 4G LTE thanks to the utilization of mmWave.
Advantages of 5G mmWave
You might ask why 5G needs mmWave and why mmWave means higher network speed rate. There are two fundamental reasons: High bandwidth, and abundant spectrum resources.
  • High bandwidth
Compared with sub-6GHz, the millimeter wave frequency band can provide higher bandwidth. The wider the bandwidth, the higher speed rate that can be supported. Take trucking as an example. The transmission of data is like the transportation of goods between two stations. The goods on the truck are the data that needs to be transmitted. The road between the starting point and the ending point is the electromagnetic wave we use.
In order to quickly deliver all the goods to the other end, we can increase the lanes to increase the number of trucks that can travel at one time, which is to increase the bandwidth. The more lanes, the more trucks can drive through in a unit time. In other words, the higher the bandwidth, the more data can be received in a unit time, which is undoubtedly a faster network speed as well as low latency.
  • Rich resources
As the wireless communication technology developing from generation 1 to generation 5, the frequency of electromagnetic wave they used is getting higher and higher. The sub-6GHz frequency band is already very crowded, with plenty of wireless communication services interfering with each other. The available spectrum resources below 6GHz are increasingly scarce. Therefore, in order to have a higher network speed, 5g must explore more frequency resources.
The spectrum resource of mmWave, conversely, is very rich, and thus the frequency band that can be allocated to the operators is extremely broad. The higher the frequency, the richer the spectrum resources that can be used. The richer the spectrum resources, the faster the transfer rate that can be achieved. That is how ultra-fast, ultra-high capacity 5G network takes advantage of mmWave.
5G mmWave in IoT Applications
So what are the scenarios that are perfect for 5G mmWave? Based on the fact that 5G mmWave enabled high bandwidth, high transmission speed and low latency, it is useful for applications such as ultra-high-definition video, live streaming, real-time surveillance camera and AR/VR for enhanced online gaming experiences. The higher bandwidths may improve sensor resolution and reduce latency. Besides, the antennas of mmWave devices are smaller than those of other frequencies, making them more suitable for small IoT devices.
Furthermore, in terms of transmission speed and bandwidth, 5G mmWave is suitable for densely populated areas or scenarios with high demand for stable network connectivity, such as Industrial IoT, smart manufacturing and shared workspaces. Everyone must have experienced something like this: when you are around a large amount of people, even though you are able to connect to the Internet, the network speed is not up to ones’ expectations. The number of communication devices in urban environments such as subway stations, offices and factories are often large. As the frequency band of 5G mmWave have higher capacity and suffers from less interference, it can greatly improve the efficiency of interconnection and intercommunication between these smart terminals.
The high bandwidth and short transmission distances of 5G mmWave also make it useful for C-V2X. With higher frequency, 5G mmWave can better resist the influence of rain and weather, and provide a more stable data transmission. Additionally, 5G mmWave enables high-position GNSS services. Due to the fact that distance resolution is inversely proportional to bandwidth, the high bandwidth of mmWave can achieve centimeter-level positioning accuracy.
Compared with 3G, 4G, and even the Sub-6 frequency band in the early stage of 5G deployment, 5G mmWave use higher spectrum frequencies and therefore have higher network speed rate — this is what makes 5G mmWave unique.
Being a completely new technology, 5G mmWave requires a significant amount of effort from all parts of the industrial ecosystem to roll out. Cellular wireless module plays an essential role in the popularization of 5G mmWave applications in IoT. As a global leading provider of wireless communication modules, Fibocom steers through this new world of 5G mmWave and provides 5G wireless modules supporting both sub-6GHz and mmWave bands, offering faster transmission speed, better carrying capacity, and lower network latency in the sector of IoT.
Based on Qualcomm® Snapdragon™ X65 and X62 5G Modem-RF Systems, Fibocom 5G mmWave module FM160W and FG160W support data transmission speeds up to 10Gbps per second, dynamic antenna tuning and global frequency bands of 5G SA/ENDC/4G, with three CA (Carrier Aggregation) combinations including FDD+TDD, TDD+TDD, FDD+FDD for greater 5G coverage and throughput.
Fibocom’s FM160W and FG160W mmWave modules are compliant with the 3GPP R16 standard, delivering enhanced mobile broadband and high-reliability, low-latency wireless services for Industrial IoT, FWA (Fixed Wireless Access), 4K/8K live streaming, telemedicine, private 5G networks and other mass data scenarios.
High-Computing Performance 3.5” SBC with 11th Gen Intel® Core™ Processors
IBASE Technology Inc., IBASE, a leading provider of industrial motherboards and embedded systems, launches its latest 3.5” SBC IB953 powered by 11th Gen Intel® Core™ processors (codenamed Tiger Lake). Measuring 146 x 102 mm in a compact footprint, the single board computer offers impressive I/O and computing performance, making it an ideal platform for a broad range of demanding applications in factory automation, machine vision, healthcare, as well as retail environments.
The IB953 features a 5G compatible M.2 3052 socket and the latest 11th Gen. Intel® Core™ and Celeron® processors built on 10nm SuperFin process, delivering up to 25% faster performance and greater AI acceleration. With the Intel Core i7-1185G7 (IBASE model IB953AF-I7) comes the new Iris Xe (Xe-LP) graphics architecture supporting 96 EUs (Execution Units) which equals 768 cores and runs at 1.35GHz, an increase of 250 MHz over the previous 11-gen graphics to provide up to twice the performance and improved power efficiency. The graphics engine’s hardware acceleration can drive up to four simultaneous 4K HDR displays (via 2x DisplayPort + eDP and LVDS).
IB953 FEATURES:
  • Onboard 11th Gen Intel® Core™ i7/i5/i3 / Celeron® processor
  • 2x DDR4-3200 SO-DIMM, Max.64GB
  • Supports 4x 4K displays (2x DisplayPort, eDP and 24-bit dual-channel LVDS)
  • 2x Intel PCI-E GbE LAN
  • 3x USB 2.0, 3x USB 3.1, 2x SATA III
  • 3x M.2 sockets (B-Key/E-Key and M-Key, NVMe and CNVi supported)
  • Watchdog timer, Digital I/O, TPM (2.0), 5G compatible
IB953 supports high-speed interfaces to deliver reliable processing for business-critical data operations with 2x SATA III, 3x USB 2.0, 3x USB 3.1, 2x COM, and 3x M.2 sockets (NVMe and CNVi supported). Additionally, it features 2x GbE ports, 2x DDR4-3200 slots, TPM (2.0) data encryption technology, ErP/EuP energy-saving function, and a wide-range 12~24V DC power input suitable for different industrial applications. Operating systems supported are Win10 (64-bit) and Linux Ubuntu (64-bit). For more information, please visit www.ibase.com.tw.
TOP PCB Companies
