Tagore’s transistor is ideal for radio applications such as public safety radios and EW radios.
Tagore’s TA9410E is a broadband 50 V, 25 W GaN transistor capable of operating from 20 M to 3 GHz. Using a simple input/output match, it can be tuned for various bands of interest. This transistor can be considered as a final stage PA or driver.
SP’s FSP330 is a slim 330 W high wattage fanless external power supply
The FSP330 is a 330 W AC-to-DC adapter from FSP intended for use in IPC systems, embedded systems, printers, monitors, charging systems, and POS systems that have high wattage demands. This adapter operates at 90 VAC to 264 VAC input voltage and meets CISPR32 EN55032 CLASS B, EN55024, and FCC PART 15B Class B emission limits, and is designed for ITE application.
The Würth Elektronik sensors are an integral part of every future application. Measuring temperature, humidity, pressure or acceleration has never been easier. Take advantage of services like the Software Development Kit and Evaluation Boards available off-the-shelf. Detailed documentation, as well as direct support by trained engineers, will leave no questions open.
With excellent measuring accuracy and long-term stability, the sensors provide high precision and accurate output values with intelligent on-chip interrupt functions.
The AEAT-9922 is an angular magnetic rotary sensor that provides accurate angular measurement over a full 360° of rotation
The AEAT-9922 is an angular magnetic rotary sensor that provides accurate angular measurement over a full 360° of rotation. It is a sophisticated system that uses integrated Hall sensor elements with complex analog and digital signal processing within a single device. A simple two-pole magnet generates the necessary magnetic field by rotating it perpendicularly. Wide magnetic field sensor configurations allow on-axis (end of shaft) or off-axis (side of the shaft) modes. The AEAT-9922 is a versatile solution that supports a broad range of applications with its robust architecture to measure and deliver both absolute and incremental signals.
Key features
5 V and 3.3 V operation
Selectable 10 bits up to 18 bits of absolute resolution
Flexible Incremental ABI resolution ranging from 1 to 10,000 CPR
Commutation angle output UVW 1 to 32 pole-pair
Additional features
PWM output modes with Cyclic Redundancy Check (CRC)
User-programmable zero position, direction, index width, and index position
Programmable hysteresis
Absolute output over 2-wire SSI, 3-wire SSI, and 4-wire SPI
The diode is a semiconductor device that allows current to flow in only one direction when it is forward biased and blocks the current in reverse bias condition. This has been explained in the previous article of “The Signal Diode”. This feature of the diode resembles a switch or valve and can be utilized to allow passage of current at certain desired conditions only.
In the “The Signal Diode” article, the most popular applications of diodes have been explained and one of them is Rectification. The Rectification means, in electrical terms, conversion of alternating current (AC) to direct current (DC) using electronic equipment. The alternating current is bidirectional, having positive and negative values, and the direct current is unidirectional, either positive or negative. The direct current signal should ideally provide a continuous and constant value. The rectifier circuits are mostly used in power supplies, inverters, and battery chargers, etc. The diodes used in high-power circuits are termed Power Diodes.
Power Diode
The power diode has the capability to pass high current through it and can withstand high voltage. It has a larger PN-junction compared to the simple diode and as such can allow several hundred amperes to flow through it. However, the larger PN-junction of the power diode, makes it less responsive to high-frequency signals. Commercially available power diodes are used in battery chargers, inverters, and rectifiers, etc. Due to their high voltage withstand capability they are used as freewheeling diodes to protect against voltage spikes/ surges.
The power diodes have a greater breakdown voltage and are generally classified into:
General Purpose
Fast Recovery
Schottky
The general purpose power diodes are the most commonly used in electronic circuits involving power supplies and rectifiers. The Glass Passivated type 1N400X (1N4001 to 1N4007) series of power diodes have voltage rating from 50 V to nearly 1000 V with a forward current bearing capacity of 1A at these voltages.
A simple power diode rectifier circuit is shown in the following figure. This is the simplest example of the rectifier and termed a half-wave rectifier which is explained below in the article.
The half-wave rectifier has a sinusoidal input and the power diode conducts (ON) only during the positive (+) cycle (half of the full-cycle) when the anode is more positive with respect to the cathode. In the next half-cycle (negative one), the power diode blocks (OFF) the current until the next positive half-cycle. The voltage appears across the load resistance during the ON period only. The input sinusoidal wave has been clipped off during the negative half-cycles and only positive half-cycles appear across the output. The rectification during only half-cycles terms the circuit as a half-wave rectifier.
In addition to positive cycle rectification, the diodes can be used to rectify during full-cycle and are called “Full-Wave” or “Bridge” rectifiers.
Rectifiers
The rectifiers based solely on diodes are uncontrolled rectifiers in which the output cannot be controlled and remains constant. The rectifiers based on Silicon-Controlled Rectifiers (SCR) are controllable rectifiers and the output of rectifiers can be controlled through firing angles of SCRs.
Half-Wave Power Rectifier Circuit
Continuing with the above half-wave power rectifier circuit, a half-wave rectifier circuit for conversion of mains supply (230 VACRMS) to 10 VDC is explained for understanding. Before, the basic calculations are revised to cope up with the upcoming explanation of the half-wave rectifier circuit.
The average value of the periodic signal is given below:
For a sinusoidal signal, the positive half-cycles equals negative half-cycles, and such cancels out to zero average. For a half-wave rectifier, the average is given as follow:
Figure 3: Half-Rectified Sinusoidal wave.
The half-rectified figure shows, Time Period = 2π and no (zero) signal during the negative (-) half-cycle, resulting in:
Similarly, the root means square (RMS) represents the DC equivalent of an AC signal for power calculations and calculated as:
In a nutshell, for a half-wave rectifier:
Now, consider the following half-wave rectifier circuit in which a transformer (100:1) is used to step down the mains supply from 230VAC to 23VAC.
Using the above formulas on the secondary side of this circuit:
So, a 10VDC appears across the 1 kΩ load. The average current flowing through the load:
For power dissipation, the following formula can be used on the supposition that it is purely a DC signal.
In half-wave rectifiers, only 50% of the input signal is converted into a DC signal, and the rest of the 50% is wasted due to the OFF state of the rectifier. Due to this, the less average value is delivered to the load and the circuit is not that efficient. Further to this, the half-wave rectifier is prone to ripples due to a larger stop period and frequent switching. The ripples cause fluctuations and are undesired in electronic and digital circuits. The ripples cause unnecessary heating, distortion, and noise etc. Especially, in digital circuits, it may cause malfunctioning and give undesired output.
The ripples can be primarily avoided using a shunt capacitor and called filter capacitor or smoothing capacitor because of its purpose in the circuit. A half-wave rectifier circuit with a capacitor filter is shown in the following figure. The circuit is called a peak rectifier.
The capacitor acts as a storage or reservoir and supplies the load during the OFF period. The value of the capacitor should be large enough so that its time constant (RC) >> time period of the sinusoidal signal. The capacitor gets charged to peak voltage on the initial positive cycle and when the negative cycle starts, the diode cuts off supply to the capacitor. The diode supplies the load and charges the capacitor during the (Δt) period. For the rest of the period, the capacitor supplies the load current until input voltage becomes equal to capacitor decaying voltage during the next positive cycle. The capacitor recharge starts and the process keeps repeating.
The ripple voltage for a half-wave rectifier is given by the following formula:
The half-wave rectifiers are seldom used because of their low average output and half of the input cycle is not utilized. They can be found in low-power or cheap power supplies. Instead, the full-wave or bridge rectifier is used because of its high average output and utilizes both input cycles.
Conclusion
The power diode is used for applications involving high current and high voltage.
Power diodes have a larger PN-junction and, thus, have greater breakdown voltage.
Power diodes are less responsive to high-frequency signals such as greater than 1 MHz signals.
Power diodes are used in power supplies, battery chargers, rectifiers, and inverters, etc.
The rectifier converts alternating current into direct current.
The half-wave rectifier uses a single power diode to convert the half-cycle of the input cycle.
The average or DC output of the half-wave rectifier is VDC = 0.318XVP or 0.45XVRMS.
The half-wave rectifier DC output is low compared to the input, half-cycle of input goes unutilized and is prone to ripples.
The ripples can be reduced by the use of a capacitor filter across the load and called a peak rectifier.
The capacitor should be large enough to have a greater time constant (RC) than the time period of the input signal.
The project presented here is a three-phaseBLDC motor pre-driver. The project consists of 3x half-bridge IR2101 driver IC and 6 channel high current N-MOSFETS. The project can be configured as 3 independent half-bridges H-bridge for a brushed DC motor, or a single high current brushless motor driver. The rotor position can be detected using 3 hall sensors assembled in the motor. Hall-effect shaft position sensors are used to control the switching sequence of the three 1/2 bridge outputs. The bridge voltage can vary between 15V and 60V and the maximum summed bridge current is 10A with a large size heat-sink and sufficient airflow using a fan. This motor driver can be used for multiple applications including e-bikes, battery-powered tools, electric power steering, wheelchairs, or any other application, where a BLDC motor is utilized. Motor start/stop, forward/reverse rotation, braking with closed-loop speed control. The project also includes 3 phase current sense circuit which can be used to detect 3 independent phase currents. An LM317 regulator provides 5V DC to op-amp circuitry. All inputs and feedback outputs provided for an easy micro-controller or DSP interface.
Current Sense Circuit: Current sense circuit measures the current across all 3 half-bridges and provides 3 independent current feedback outputs, this can be used for overcurrent sense or senseless FOC configuration, the default output at 0A is 1.45V, and provides approx. 100mV/Amp. User may change the Gain of an op-amp, current shunt resistors as per requirement, LM317 power 5V to op-amp circuit.
User need to generate 6 PWM pulse sequence to control the motor, the board accepts TTL input, more information about brushless motor driver available here:
Driving a 3-phase brushless DC motor is very easy with this project. It is a simple and easy-to-build project that requires only a few external components. The circuit is based on AMT49400 IC which is an advanced 3-phase, Sensorless, brushless DC (BLDC) motor driver with integrated power MOSFETs. The chip includes the field-oriented control (FOC) algorithm which is fully integrated to achieve the best efficiency and acoustic noise performance. The motor speed is controlled by applying a duty cycle signal to the PWM input. Users may use Arduino, microcontroller, or discrete circuit to generate PWM for the speed controller. It is a hassle-free easy to use board, just connect the 3 phase brushless motor, connect the power supply and feed PWM to control the speed of the motor. This project is the best choice to drive a FAN motor, small pumps, and brushless toy motors, etc.
Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver – [Link]
This project helps to optimize the 12V lead-acid (SLA) battery life as it prevents the battery from going into deep discharge. It is very important to disconnect the load before the battery enters into deep discharge as this may destroy or damage the battery cells. The circuit shown here turns off the load before the battery enters deep discharge and avoids a further (deep) discharge that can shorten the SLA battery life. Once the battery is recharged or replaced you need to push a reset switch to power ON the load. The predetermined load level is set to 12V, this voltage level is proportional to the battery voltage which is determined by resistor divider R2, and R9. Once the voltage falls below the setpoint (12V) it disconnects the load, the load-battery connection remains open until the system receives a manual reset command using tactile switch SW1.
Low Voltage Lead Acid Battery Disconnect board – Prevents Deep Discharge Of 12V Lead Acid Battery – [Link]
The project here is a 48V protected, high side switch designed to switch a 5A output load from input voltages from 8V to 48V. The circuit helps the user to easily ON/OFF the high current and voltage load with over-voltage lockout and over-current protection. The wide input range and low shutdown current (1μA typical) make it suitable for automotive, industrial, medical instruments, and telecom applications. This board offers a low 50ns (typical) propagation delay, fast switching times (<10ns), and 100% duty cycle operation. The project is based on LTC7000 which is a fast high voltage protected high side N-channel MOSFET driver. An internal charge pump fully enhances an external N-channel MOSFET switch, allowing it to remain on indefinitely. Its powerful gate driver can drive large gate capacitance MOSFETs with very short transition times, ideal for both high-frequency switching and static switch applications.
High Side Switch with Input Overvoltage and Overcurrent Protection – [Link]
The circuit presented here is a 3W stereo audio amplifier with memory UP/DOWN volume control. The project is based on PAM8408 IC from Diode Incorp which is a filter-less class-D amplifier with high SNR and Differential input which helps eliminate noise. Two tactile switches are provided to control the UP/DOWN volume in 32-steps and it will hold the setting when the chip is in shutdown mode. The operating supply is 2.5V to 6V DC and this supply range helps to operate it with batteries like the use of 4 x Alkaline batteries. The small PCB size, 87% efficiency, low cost, minimum external components make this project ideal for portable applications. The PAM8408 also has built-in auto-recovery SCP (Short Circuit Protection) and thermal shutdown. The circuit works with differential audio signal input. It is advisable to use shielded wire for the audio input signals. Jumper J3 is open in normal operation, and if you close it puts the amplifier into shutdown mode and the audio volume will memorize when shutdown mode is recovered. Solder jumpers J1 and J2 are optional and of no use, it is advisable to keep these jumpers open. Connector CN1 is for power supply, CN2 is for audio signal input, CN3, and CN4 are for the speaker, Jumper J3 is for Shutdown, D1 is the power LED, Switch 1 increased volume, and Switch 2 decreases volume.
