Arduino Nano 33 IoT-based NTP World Clock
Arduino Nano 33 IoT can be used to enhance existing devices and creating new ones to include IoT and to design network-specific applications. This article focuses on one of such applications which uses Network Time Protocol by clock synchronization between systems all over the world. It is necessary to know more about Arduino Nano 33 IoT board.
Arduino Nano 33 IoT has a NINA -W10 chipset working at 2.4GHz, this u-blox module is used for Bluetooth and WiFi network connectivity. This WiFi connectivity can be used for clock synchronizations via Network Time protocols to get information of time from different systems. The primary processor of the Nano 33 board is a low-power Arm Cortex-M0 32-bit SAMD21, the board also features secure communication ensured by the Microchip ECC608 chip.
Key Features of Arduino Nano 33 IoT
  • Arm Cortex-M0 32-bit SAMD21
  • Clock frequency up to 48MHz
  • Flash Memory of 256KB
  • 32KB SRAM
  • NINA W10 for Bluetooth and WiFi connectivity
  • Microchip ECC608 crypto chip for security
  • Circuit voltage 3.3V,
  • I/O: 8 analog pins, 14 digital pins,
  • Interfaces: 1 UART, 1 SPI, 1 I2C
  • Dimensions: 45x25mm
If one wants to know the time of different time zones in the world, there are many mobile applications and websites for this purpose. Although, this is a simple thing but what if one wants to get this time info at a glance. A dedicated device to “know what time it is anywhere in the world” could satisfy this requirement.
Kaleb Clark (Innovation Team Hardware Lead) used a “3.5″ SPI TFT screen to show eight time zones in the device’s main section, plus a pair of 7-segment displays (SSD) for two more “slots.
” The unit runs on an Arduino Nano 33 IoT, which checks the time over WiFi via the Network Time Protocol, or NTP.”
Features of NTP World Clock
The built NTP clock has a TFT screen on the left side and two 4-digit SSDs and a rotary encoder on the right side. The top SSD shows the present location and time and the bottom SSD shows the selected time zone’s time. The TFT screen configured with Nano 33 IoT using NTP, has a WiFi indicator at the top right corner. The screen has four levels of indications based on RSSI values on the radio module of the Nano 33 board:
  • WiFi indicator (top right corner)
  • Current location’s date
  • Country name, Time and Offset Value
  • Progress scroll bar showing the seconds value
The screen shows 8 different time zones (countries) with additional two time zones synced with two SSDs. The offset value of the time for a time zone is with respect to the current location’s time, and not the standard UTC. Pressing the center button of the encoder takes you to the menu page. The rotary encoder functions as a controller to change a particular time zone from the options available in the menu. There is also an option of 24hr /12hr format in the menu.
You can alter the code to change the structure and design of the display. To know more about this project application of Arduino Nano 33 IoT, watch this video by Kaleb Clark. If you hit a dead-end while building this project, you can shoot your queries on Element14 Community Forum.
The images and technical specifications have been taken from The Arduino Blog and Arduino Nano 33 IoT product page.
BIQU BX, World’s First OctoPrint Integrated FDM 3D Printer
Big BigTreeTech is not fond of rushing products to you every month, with their last 3D (BIQU B1) printer having released in July, you can tell they try to deliver meaningful reasons for you to update your 3D printing setup. With the announcement of the new BIQU BX 3D printer, described by the company as “exceptional printing made for creators”, is it the one for you? It certainly is worth checking out!
At first glance, you will feel that this 3D printer is relatively small but sleek, where the carbon-looking frame gives it an appealing look, along with the massive 7 inch LCD touch screen. The enclosure is made of aluminum extrusions, 2040 on both sides and 2020 on top, where the wider base for the Y-axis contributes for more stable 3D prints. For the Z-axis, a dual stepper motor setup is used in combination with a timing belt on top. On the top, you will also find a holder for the filament spool, since we are dealing with a direct drive 3D printer. The bottom heat bed uses the BIQU SSS (Super Spring Steel) technology, guaranteeing that the model is stable when the bed is heated  and does not fall off, while being easy to take when the 3D printing is done. The power supply is located under the Y-axis frame, hiding it from sight and therefore contributing to its simple and appealing appearance. On the front side, you will find not only the touch screen but also an SD card slot.
The direct extruder itself is one key differentiator between this and other 3D printers as it is the world’s lightest (219g), paired with a Ra0.4 nozzle to reduce inertia and clogging to its minimum, providing the maximum accuracy improvement. The 7:1 torque transmission ratio ensure outstanding printing performance. Instead of a 1.8º standard stepper motor, the BIQU BX is makes use of a 0.9º degree motor, doubling the precision, which greatly improves the fineness and accuracy of your 3D prints.
The BIQU BX All Metal Extruder
The BIQU BX All Metal Extruder, one of the stars of the show
The heart of this 3D printer is the new powerful BigTreeTech motherboard, containing their new 32-bit 400MHz chip, enabling it for bigger complexity when it comes to 3D printing. The beefy motherboard also offers some interesting safety features, such as reverse plug protection, heating overload protection and real time monitoring of the power supply voltage, which will result in a more robust and longer-lasting product.
There are 3 operation modes available for this 3D printer: Marlin mode, the BigTreeTech touch screen mode and the Plug & Print Raspberry Pi expansion mode, making it the world’s first laptop-free OctoPrint integrated 3D printer.
The powerful BigTreeTech board with Raspberry Pi integration
Some other interesting specs are:
  • Printing volume: 250 x 250 x 250mm
  • Printing speed: 100mm/s
  • Printing accuracy: 0.1mm
  • Power-loss recovery
  • One-cable extruder-to-board solution
  • Proximity sensor for auto-levelling
  • Capable of handling PLA, TPU, PETG, ABS and nylon filaments
  • Silent printing with a trinamic stepper driver
  • MEAN WELL 24V/350W PSU
The firmware of the BIKU BX is open source and highly expandable, with new updates coming regularly to GitHub and hardware expansions, such as a breaking and blocking detection module and reserve interfaces for the Wi-Fi printing module and the CAN bus.
But how can you get one? Easy. The printer is funded on Kickstarter, through the ogatget website, where you can get a huge discount, acquiring it for $249.
From what we have seen so far, this printer seems to be a no-brainer if you want to get great quality 3D prints. Will you pick it up?
Ogadget Link: https://www.ogadget.com/x/biqu-bx#CTA
TDK introduces revolutionary MEMS-based CO2 gas sensor platform
TDK Corporation announces the InvenSense TCE-11101, a miniaturized ultra-low-power MEMS gas sensor platform for direct and accurate detection of CO2 in-home, automotive, IoT, healthcare, and other applications. The TCE-11101 introduces new technology that expands TDK’s sensor leadership into new applications and solutions, as part of the new SmartEnviroTM family. Its small size and low power enable consumer and commercial devices of all form factors that do not need to be wall-powered. The TCE-11101 is housed in a 5 mm x 5 mm x 1 mm 28-pin LGA package and requires minimal external components to complete the design.
Currently, available gas sensors use bulky, power-intensive, and expensive optical techniques; or an intrinsically inaccurate “eCO2” approach. TDK’s TCE-11101 is based on a groundbreaking technology platform made possible by TDK’s unique combination of novel materials development, MEMS process technologies, and AI and machine learning capabilities, delivering a solution that is orders of magnitude smaller than traditional sensors, consumes less than 1mW of power and provides accurate measurement of CO2 gas concentration.
The TCE-11101 significantly expands the use cases for CO2 detection in a wide variety of new and existing applications where traditional sensors fail due to size and power concerns or simply the economics of their usage, while “eCO2” solutions fail to provide the required performance. For example, the TCE-11101 is ideal for applications such as fixed or robotic indoor air quality monitoring due to its ability to provide accurate CO2 readings, doing so at extremely low power, in a very small form factor, and in a low cost, easy-to-integrate digital device. Further, in applications such as Demand Controlled Ventilation (DCV), the TCE-11101 allows granular control of an HVAC system by accurately measuring CO2 levels that precisely indicate occupancy in a room or given space – information which can be used to optimize energy consumption for HVAC in Smart Buildings or Smart Homes.
Features and benefits of the SmartEnviro products include: Ultra-low-power; Direct CO2 sensing; Digital interface (I2C); Miniaturized form factor; Technology that offers very wide sensing range (400 ppm to 50,000ppm); Integrated solution with onboard programmability via 16-bit microcontroller; Background calibration for long-term stability; RoHS and Green compliant
The gas sensor platform solution includes:
TCE-11101: The TCE-11101 is a 5 mm x 5 mm x 1 mm 28-pin LGA package, with a metal cap and integrated particle ingress filter to ensure long-life operation. It includes an ASIC that provides automatic calibration, reporting, and a serial interface for data output and configuration, making it incredibly easy to integrate into nearly any application, with the low power consumption enabling its use in battery-powered devices. DK-11101: TDK offers a comprehensive evaluation kit with supporting software so developers can quickly evaluate the TCE-11101 and integrate it into their next design.
The TCE-11101 sensor and DK-11101 development kit are available now for select early partners and customers.
Sipeed’s MAIX-II Dock Development Kit for AI-specific Applications
MAIX-II Dock Development Kit for Sipeed’s second-generation MAIX-II core module has a built-in NPU (Neural Processing Unit) for AI-specific applications. The module runs in a complete Linux environment with edge computing features to improve response time and reduce the bandwidth. Hence, the module specializes in deep learning and AIoT functions. MAIX-II module is an Allwinner V831 SoC with better features than the MAIX-I Kendryte K210 module.
The MAIX-II core module on Arm Cortex-A7 works at a higher frequency (800~1000 MHz) than the MAIX-I module which works at a lower (400~600 MHz). The MAIX-I module has a smaller RAM size but the NPU performance is up to 0.23 TOPS (Trillions Operations Per Second), whereas the MAIX-II module has SIP 64MB DDR2 RAM but the NPU performance is 0.2 TOPS. The MAIX-II module provides more peripherals like SDIO, Ethernet port, ADC, and audio port. Additionally, it features video encoding at H.264 up to 1080p at 30fps, H265 up to 1080p at 30fps, and JPEG up to 1080p at 30fps, which is not supported in MAIX-I.
MAIX-II Core Module
MAIX-II Dock Development Board Kit
The Sipeed MAIX-II Dock integrates a 1080p30 camera based on Omnivision SP2305 2 megapixel sensor and 6mm default focal length with an M12 lens. It connects to the board via a B2B connector. The 48.9 x 33.9 x 36.1mm development board “communicates through a 2.4GHz 802.11n Realtek RTL8189FTV module and antenna.” Additionally, it provides 1.3-inch 240 x 240 IPS display, a 1W speaker, a built-in microphone, a microSD slot, and a 3-axis accelerometer. The MAIX-II Dock development board kit is meant for AI-specific applications in smart homes, medical industries, education, and agriculture.
Parameters of MAIX-II Core Module and Development Kit
  • Typically, the core board operating current is 50 mA.
  • 22.1 x 24.9 x 3.0mm are the dimensions of the module board.
  • Core board working temperature is between 38-65 ℃
  • Typically, the kit working current is 490 mA
  • 48.9 x 33.9 x 36.1mm are the dimensions of the kit.
  • 5V and 1A is the recommended power supply with a Type C interface.
The Sipeed has the “OpenWrt-based MAIX-LINUX firmware adapted for edge computing, including the relevant drivers, and all opkg package source code” as the system software. The board uses Python 3.8.5 for programming with a user-friendly Jupyter Notebook environment. The system is also compatible with python software packages like numpy for computations and PIL for image processing. The system also supports additional tools like cross-compilation toolchain, QEMU virtual compilation environment, and online model conversion tools.
Software Features of MAIX-II Dock Development Kit
Sipeed has tweeted the MAIX-III module with a 1.5-TOPS NPU, dual-band WiFi, Gigabit Ethernet, and 512MB to 2GB DDR3. Its performance could be much better than the previous versions of the MAIX series because of the increased RAM and TOPS specification. “Due in February, the module runs on a Linux-ready SoC that could be a Rockchip design.”
The Sipeed MAIX-II Dock is available for preordering from Seeed for $28.80, with delivery dates after the 15th of January. For more information visit the official product page.
Images and technical specifications have been taken from Sipeed’s official product page and Hackster’s post.
LG Introduces LG8111 AI Chip And Development Kit for On-device AI
LG Electronics has introduced a highly-integrated LG8111 AI Chip together with a corresponding Eris Reference Board for edge AI Processing.
The LG8111 AI chip for on-device AI inference is equipped with an LG-specific AI processor that can copy the neural network of the human brain and process the deep learning algorithm efficiently. The SoC supports hardware processing in AI capabilities like video, voice, and control intelligence.
Since the chip has a low power low latency feature that enhances its self learning capacity, products built with the chip can implement On-Device AI learned and inferred by themselves. The chip also supports AWS IoT Greengrass and the integration of the Eris Reference board with AWS IoT Greengrass allows for easier deployment of a variety of applications and solutions.
Features of the LG8111 AI SoC:
  • LG Neural Engine
    • LG proprietary AI Accelerator
    • Inference/Training engine
    • Support for TensorFlow, TensorFlow Lite, Caffe
  • Quad-Core CPU
    • ARM Cortex A53 cores clocked at a frequency of 1.0 GHz
    • 32KB L1 cache and a 1MB L2 cache
    • NEON, FPU, and Cryptography extension.
  • Vision Accelerator
    • Dedicated vision for DSP which enables feature extraction and image warping.
  • Camera Engine:
    • 5M + 5M dual ISP pipeline
    • Parallel interface
    • Noise reduction
    • Lens distortion correction
    • High Dynamic Range (HDR) pre-processing
  • Video Encoder:
    • Support for full HD video H.264 encoding
  • Audio Engine:
    • “Always-on” voice recognition
    • Voice Activity Detector with dedicated Audio DSP
The LG LG8111 AI development board on the other hand, is a cost-effective machine learning device development platform for applications such as control intelligence, image classification/recognition, speech recognition, and more. It can provide improved sensor data collection/analysis as well as machine learning inference performance. The board will also find its application in areas like home automation, industrial automation, lighting, etc.
Features and Specifications of the LG LG8111 AI Development Board:
  • ARM HW Architecture
  • eMMC storage
  • Camera Interface support
  • GPIO, I2C, MIPI, PWM, SD, UART, USB
  • Wi-Fi 2.4 GHz Network only
  • C/C++ programming language
  • Security Features: Hardware Encryption, Secure Boot, TEE
  • Operating System: Linux and Ubuntu 18.04
  • Power Supply: Battery
  • Industrial temperature range: -40°C to +85 °C
  • Form Factor: Embedded
The company has stated a number of component-specific solution highlights on the board. You can visit their official product page for that as well as other details about the board or the chip. They also went ahead to drop their email address: LGSIC-AI@lge.com for those who are interested in getting the reference board or have some questions about the LG8111 AI chip.
TPSM82810 – 2.75-V to 6-V, 4-A step-down module with adjustable-frequency & tracking
TPSM8281x is a family of pin-to-pin 3-A and 4-A compatible high efficiency and easy to use synchronous step-down DC/DC power modules with integrated inductors. They are based on a fixed-frequency peak current-mode control topology. They are used in telecommunication, test and measurement, and medical applications with high power density and ease of use requirements. Low resistance switches allow up to 4-A continuous output current at high ambient temperatures. The switching frequency is externally adjustable from 1.8 MHz to 4 MHz and can also be synchronized to an external clock in the same frequency range. In PFM/PWM mode, the TPSM8281x automatically enters Power Save Mode at light loads to maintain high efficiency across the whole load range. The TPSM8281x provides a 1% output voltage accuracy in PWM mode which helps design a power supply with high output voltage accuracy. The SS/TR pin sets the start-up time or tracks the output voltage to an external source. This allows external sequencing of different supply rails and limits the inrush current during start-up.
Features for the TPSM82810
  • Input voltage range: 2.75 V to 6 V
  • Output voltage range: 0.6 V to 5.5 V
  • Adjustable and synchronizable switching frequency of 1.8 MHz to 4 MHz
  • Spread spectrum clocking – optional
  • Selectable forced PWM or PFM/PWM operation
  • Output voltage accuracy ±1% (PWM operation)
  • Power-good output with window comparator
  • 100% duty cycle
  • Output discharge
  • Precise ENABLE input allows
    • User-defined undervoltage lockout
    • Exact sequencing
  • 15-µA typical quiescent current
  • Adjustable soft-start or tracking
more information: https://www.ti.com/product/TPSM82810
TinyPocketRadio – FM Stereo Radio based on ATtiny13A
Stefan Wagner published another project on github.com. He writes:
TinyPocketRadio is a simple FM stereo radio based on ATtiny13A and RDA5807MP. It’s powered by a CR2032 coin cell battery and can drive 32 Ohm headphones via the 3.5 mm audio plug. The board size is 38 x 23 mm. It has a power switch and three buttons: “Channel+”, Volume-” and “Volume+ “.
The low-cost RDA5807MP is a single-chip broadcast FM stereo radio tuner with fully integrated synthesizer, IF selectivity, RDS/RBDS and MPX decoder. The tuner uses the CMOS process, support multi-interface and require the least external component. All these make it very suitable for portable devices.
TinyPocketRadio – FM Stereo Radio based on ATtiny13A – [Link]
EPC2218 Enhancement-Mode GaN Power Transistors
EPC’s 3.2 mΩ, 100 V, 231 Apulsed GaN transistor provides power efficiency and switching frequency
EPC’s EPC2218 transistors and development/evaluation boards supply 100 V, 60 A, and 231 APULSED enhancement-mode GaN FETs. The transistors are only supplied in passivated die form with solder bars and a die size of 3.5 mm x 1.95 mm. The EPC2218 is ideal for 48 VOUT synchronous rectification, Class-D audio, infotainment systems, DC/DC converters, and LiDAR for autonomous cars, robotics, and drones.
  • Higher switching frequency for lower switching losses and lower drive power
  • Higher efficiency provides lower conduction and switching losses, as well as zero reverse recovery losses
  • Smaller footprint allows for higher power
  • DC/DC converters
  • BLDC motor drives
  • Sync rectification for AC/DC and DC/DC
  • LiDAR/pulsed power
  • Point-of-load (POL) converters
  • Class-D audio
  • LED lighting
more information: https://epc-co.com/epc/Products/eGaNFETsandICs/EPC2218.aspx
ON Semiconductor NCN51xxASGEVB KNX Evaluation Boards
ON Semiconductor NCN51xxASGEVB evaluation boards are Arduino-compatible shields that enable rapid prototyping with a microcontroller of choice. These evaluation boards incorporate all the external components necessary for operating the transceivers. The NCN51xASGEVB boards come in three variants such as the NCN5110ASGEVB, NCN5121ASGEVB, and NCN5130ASGEVB. The NCN51xx series of KNX transceivers handle the low-level communication necessary to comply with the KNX standard. The NCN5110 is a bit transceiver and all the timings are handled by the microcontroller. The NCN5121 and NCN5130 implement the MAC layer that reduces the software development effort. The critical timings are handled by the transceiver.
  • Arduino Uno V3 connectors ensure compatibility with a wide variety of development boards
  • Enable rapid prototyping
  • All external components necessary for operating the transceivers are included
  • Four onboard buttons/LEDs to build a dimmer application
  • Available in UART- and SPI-version
  • Easily get started with KNX
more information: https://www.onsemi.com/support/evaluation-board/ncn5110asgevb
New Triple Output DC Power Supplies are cTUVus Certified
B&K Precision, a leading designer and manufacturer of reliable, cost-effective test and measurement instruments, today announces the 9140 Series Triple Output Multi-Range DC Power Supplies. With three isolated and individually controllable outputs, the 9140 (32 V, 8 A) and 9141 (60 V, 4 A) provide up to 300 W of clean power with low ripple and noise or 100 W per channel in a compact 2U half-rack form factor. The front panel features a 4.3-inch LCD and unique output terminals that support sheathed banana plugs or spade lug type connectors. Multiple outputs combined with advanced list mode programming, data logging, and extensive protection features make these power supplies suitable for a wide range of benchtop or test system applications.
This series offers several enhanced features not available on any of B&K Precision’s existing triple output power supplies. Powerful list mode features include list sequencing and step triggering for synchronizing events. List mode programs can be assigned to run on one or multiple channels simultaneously. Output sequencing allows users to link the output states between multiple channels with configurable on/off delays. Both models come equipped with LXI compliant LAN and USB (USBTMC-compliant and USBVCP) interfaces for remote control and programming with an optional GPIB interface. Remote control PC software, LabVIEWTM and IVI drivers are provided to simplify instrument control and test system integration. The USB host port on the front panel allows for logging voltage and current measurements directly to an external flash drive.
The 9140 Series is also cTUVus certified, indicating compliance with Canadian and U.S. National Safety Standards.
Available now, both models start at $1,850 and are backed by a 3-year standard warranty.
Features:
  • Three independent, floating output channels for up to 100 W per channel or 300 W total
  • High power density, compact 2U half-rack form factor
  • Multi-ranging operation
  • Low output ripple and noise down to 1 mVrms
  • Combine outputs to increase voltage up to 180 V or 24 A (depending on model)
  • Advanced and easy to use list mode programming
  • Channel coupling, tracking, configurable delays
  • Direct data logging to USB flash drive
  • Thermostatically-controlled fans for quiet operation
  • Adjustable voltage and current slew rates
  • OVP, OCP, OTP, and key-lock protections
  • USB (USBTMC-compliant) and LXI compliant LAN standard, GPIB option
  • LabVIEWTM, IVI-C, and IVI.NET drivers provided
  • Operating software included
  • cTUVus certification mark
For additional technical specification, accessories, photos, and support documents, visit: https://www.bkprecision.com/products/power-supplies/9140-triple-output-multi-range-dc-power-supply-32v-8a-300w.html
TOP PCB Companies
