Modules with Wirepas Mesh protocol for Massive IoT
Würth Elektronik has entered into a partnership with the Finnish software developer Wirepas. The aim of the agreement is to offer a portfolio of radio modules that use the IoT network protocol Wirepas Mesh from 2021. This innovative technology can be used to create large IoT networks, for example of battery-powered sensors, in which each participant also functions as a router. The mesh is self-healing and scalable as required. As part of an “early bird offer”, Würth Elektronik customers can receive from today the proven Proteus III / Thyone I hardware with firmware from Wirepas.
The design principles of the software stack from Wirepas were geared from the beginning to the requirements of the industry with regards to reliability, scalability and longevity of devices in battery operation. As a provider of compact and energy-saving radio modules in the 2.4 GHz band, Würth Elektronik is the ideal partner for manufacturing, selling and supporting ready-to-use radio modules for Wirepas mesh networks.
“This will make us a one-stop shop for companies willing to develop IoT solutions for remote monitoring and remote control of devices based on the extremely flexible and scalable Wirepas technology,” explains Luca Settembre, product manager for GNSS and Wirepas in the Wireless Connectivity & Sensors Division at Würth Elektronik eiSos. “There are a lot of interested parties and developers who are urgently waiting for Wirepas radio modules available in smaller numbers. We have decided to be very flexible and offer a solution before the official start. “
Wirepas modules
With immediate effect, Würth Elektronik customers can receive their first radio module with Wirepas basic firmware. In cooperation with Wirepas, Würth Elektronik offers standard hardware in which the Wirepas firmware can be customized according to customer requirements. This means that an intelligent mesh network can be implemented for the customer within a very short time. The hardware is based on the Nordic chipset nRF52840, which has already proven itself very well at Würth Elektronik as the Bluetooth LE 5.1 module Proteus-III or as the 2.4GHz proprietary radio module Thyone-I. From the end of Q1 2021, a standard radio module, like all products at Würth Elektronik eiSos, will be available from stock without a minimum order quantity.
more information: https://www.we-online.de/web/en/wuerth_elektronik/start.php
High voltage Half-Bridge with Current Feedback using L6390
The project presented here is a versatile high voltage Half-Bridge with current feedback. The board is built using L6390 IC from ST Semiconductor. It is suitable for DC-DC converters, EHT drivers, induction heater drivers, battery chargers, LED drivers, DC motor speed controller and field-oriented control (FOC) motor driving application etc. The user can make a FOC Brushless motor driver with 3 of these units, Bidirectional Brushed DC motor can be controlled with 2 units. FDH3632 MOSFETs rated at 100V DC and 80A Current drive the output. Other High voltage and high current MOSFET can be used as per voltage and current requirements.
High voltage Half-Bridge with Current Feedback using L6390 – [Link]
TSCR4 LED Driver ICs delivering improved performance at comparable cost
The Taiwan Semiconductor TSCR4 family of linear CMOS LED driver ICs offers a drop-in replacement for legacy bipolar drivers with much improved performance . These constant current drivers provide stable LED current over a wide range of conditions including source voltage variations and changes in load or temperature variations. Compared to legacy bipolar LED drivers, the TSCR4 family offers higher current set-point accuracy and stability, lower quiescent current, tighter output compliance voltage, and improved temperature coefficient. These ICs enable upgrades of existing designs for higher performance with no re-design effort required.
  • Higher accuracy of output current improves manufacturing yields in mass production
  • Lower quiescent current (e.g., 300 mA. vs 1 A at 24 VDC) lowers power dissipation and reduces battery standby and operating power consumption
  • More precise output voltage drop: CMOS control of voltage drop enables operation closer to the rail
  • Higher stability of output current delivers consistent brightness control and extends LED life
  • Better temperature coefficient (-0.07%/°C) controls output current with temperature increases to eliminate the risk of thermal runaway
  • AEC-Q100 parts available, ideal for many basic automotive lighting applications
  • PWM dimming: up to 10 KHz digital input for 0 to 100% dimming (TSCR421CX6/H)
  • Supply voltage up to 40 V, supports large LED arrays
  • Easy parallel driver structure
more information: www.taiwansemi.com/en
ULN2003 – Seven Darlington arrays in new TSSOP16 package
The ULN2001, ULN2002, ULN2003 and ULN2004 are high-voltage, high-current Darlington arrays each containing seven open collector Darlington pairs with common emitters. Each channel is rated at 500 mA and can withstand peak currents of 600 mA. Suppression diodes are included for inductive load driving and the inputs are pinned opposite the outputs to simplify board layout.
The versions interface to all common logic families: ULN2001 (general purpose, DTL, TTL, PMOS, CMOS); ULN2002 (14 – 25 V PMOS); ULN2003 (5 V TTL, CMOS); ULN2004 (6 – 15 V CMOS, PMOS).
These versatile devices are useful for driving a wide range of loads including solenoids, relay DC motors, LED display filament lamps, thermal printheads and high-power buffers.
The ULN2001A/2002A/2003A and 2004A are supplied in a 16-pin DIP package with a copper leadframe to reduce thermal resistance. They are available also in small outline package (SO-16) as ULN2001D1/2002D1/2003D1/ 2004D1.
Key features
  • Seven Darlingtons per package
  • Output current 500 mA per driver (600 mA peak)
  • Output voltage 50 V
  • Integrated suppression diodes for inductive loads
  • Outputs can be paralleled for higher current
  • TTL/CMOS/PMOS/DTL compatible inputs
  • Input pins placed opposite to output pins to simplify layout
more information: https://www.st.com/en/interfaces-and-transceivers/uln2003.html
Avnet AVT9152 Module offers a high degree of flexibility for IoT product development
The Avnet AVT9152 Module combines BLE, LTE and GPS technologies into a module targeting a broad range of IoT applications where low power and small size matters. Market ready, the module supports both LTE-M and NB-IOT technology and is certified to conform with FCC, CE, RCM and BQB.
The nRF52840 Bluetooth 5.2/Bluetooth LE advanced multiprotocol SoC features a 64MHz, 32-bit Arm® Cortex® M4 processor with floating point unit (FPU) which, alongside the nRF9160 SiP’s Arm Cortex-M33 processor, ensures the module can offer ample computational power to support a range of complex and processor-intensive IoT applications.
The module offers a high degree of flexibility and scalability for IoT product development while shortening time to market. Completing an IoT design can be as straightforward as connecting a power source, sensors and an antenna to the module.
  • nRF91 with LTE-M/NB-IoT global carrier certification
  • BLE for short range communication
  • Support power safe mode, PSM and eDRX
  • ARM® TrustZone® security isolation
  • OTA support on both nRF91 and nRF52
  • Rich in peripherals support – UART, SPI, I2C, NFC, USB and GPIOs
  • Flexible LTE and GPS antenna options
  • AT commands modem architecture supporting UDP/TCP protocols
  • Two powerful processors dedicated for application
  • 3V@200mA power supply to the external
Avnet AVT9152 Evaluation Kit
The AVT9152 Evaluation Kit simplifies IoT application development with an end-to-end cloud connection platform via Avnet’s enterprise-ready IoTConnect® Platform. Along with the AVT9152 Module, the kit includes Avnet’s global eUICC SIM with 50MB/three-month trial service. The evaluation kit is available globally and features a three-axis accelerometer, three-axis gyroscope, as well as pressure, temperature, relative humidity, ambient light and motion (PIR) sensors.
The nRF53 PDK or nRF91 DK are the recommended programming tools covered in AVT9152 EVB programming guide but NOT included in the kit. For more information or to purchase these, see the Accessory box on this page.
Benefits
  • Shortened time to market for end-product development
  • Ease of cloud connection with SDK support, end-to-end connection ready
  • Suitable for POC field trial
  • High degree of flexibility and scalability
  • Handy with commonly used sensors in IoT applications
  • Can be battery powered
more information:  https://www.avnet.com/wps/portal/us/products/new-product-introductions/npi/avnet-avt9152-module/
ATmega3208 Powered Development Board for Embedded Applications
Microchip has recently launched a simple yet powerful development board aimed at embedded and IoT applications. As the name suggests, the development board is powered by the ATemga3208 from Microchip. The microcontroller features an 8-bit AVR processor clocked at up to 20MHz and comes with up to 32 KB Flash, 4 KB SRAM and 256 bytes of EEPROM. The AVR family of processors is famous for their performance, power efficiency, and design flexibility and are widely used in embedded systems applications.
The development board has an onboard decoupling capacitor, which suppresses high-frequency noise in the power supply signals, and Unified Program and Debug Interface, which is an interface for external programming and on-chip debugging of a device. This programming header includes the USART.0 TX and RX signals in “UPDI+” that is in a 2×3 o.1″ layout matrix at the lower end of the board.
The LED is attached to the PF5 pin that can be seen from the figure and is connected through a 2k2 current-limiting resistor to ensure that the amount of current does not exceed the limit that the circuit can handle. Similarly, the onboard button is connected to the PF6 RESET pin via a resistor, while the PF6 pin is the default pin for the GPIO mode.
Additionally, you can see an extra 2-pin header that has a VCC and GND pin for additional connections that are placed above the onboard LED. Coming back to the heart of this development board that is ATmega3208 chip has a CPU Speed of 20 MIPS/DMIPS. The chips also have digital communication peripherals, including 3x-UART, 1x-SPI, and 1x-I2C, along with a 10-bit 12 channel analog to digital converter input.
The popular solution for low-power design is to put it into an appropriate sleep mode. For this, the chips have three sleep modes, including idle, standby, and power down. It also has an event system, which is popular among the AVR microcontrollers as it lets you connect the on-chip peripherals without writing any code.
The advised operating temperature is -40 to 125 degrees Celsius and an operating voltage of 1.8 to 5.5 volts. I wouldn’t be surprised to see this ATmega3208 powered development board aiding in several embedded and IoT applications, as mentioned before.
You can buy this board on Tindie for $18.
e-con Systems launches 120 fps Full HD Color Global Shutter Camera Module
Full HD @ 120 fps | Color Global Shutter|AR0234CS CMOS sensor| ON Semiconductor® | NVIDIA® Jetson Xavier™ NX
e-con Systems Inc., a leading embedded camera solutions company, is expanding its wide portfolio of cameras by introducing a FHD color global shutter 4-lane MIPI camera module, e-CAM217_CUMI0234_MOD, designed to capture fast-moving objects with superior image quality and accuracy. This FHD MIPI CSI-2 camera module is based on the 1/2.6″ AR0234CS image sensor from ON Semiconductor®, a leading supplier of semiconductor-based solutions, with a well-tuned image signal processor (ISP). Its interchangeable M12 (S-mount) lens allows manufacturers to select a lens of their choice according to their application needs.
Recognizing the growing need for color global shutter cameras in embedded vision applications, we are excited to launch our first color global shutter camera module with MIPI CSI-2 interface. Color global shutter allows artifact-free imaging of moving objects and together with high-frame rates and NVIDIA Jetson platform support, this camera will enable new genre of applications powered by AI on the edge”, said Ashok Babu President of econ Systems, Inc. “With our continuous investment in developing new cameras for embedded vision applications along with technology partnership with ON Semi, we have a wide range of production-ready MIPI CSI-2 camera modules which will cut down the time-to-market for our customers”, he added.
“Vision has become one of the main data acquisition technologies in electronic systems today, as more OEMs offer state-of-the-art image processing techniques in their solutions,” said Gianluca Colli, Vice President and General Manager, Industrial & Commercial Sensors Division (ICSD) at ON Semiconductor. “Small form-factor camera sensor modules delivering high performance at low power enable a variety of imaging solutions previously out of reach. Recognizing this need, ON Semiconductor has been working closely with technology partners over several years to create camera modules for simplified development and quick time to market.” he added.
This global shutter camera module captures images at a high frame rate, which helps to minimize frame-to-frame distortion and reduce motion blur while capturing fast-moving objects to produce smoother images with greater scene details. The global shutter functionality and high frame rate make it suitable for applications such as License Plate Recognition (LPR), Automotive ADAS, Robotic Vision, Drones, Factory Automation, Gesture Recognition, Traffic Monitoring, and Barcode Scanning.
To accelerate product development for the above applications and to evaluate e-CAM217_CUMI0234_MOD camera module’s capabilities, e-con Systems offers e-CAM24_CUNX camera evaluation kit that plugs into the NVIDIA® Jetson Xavier NX™ developer kit. The camera is integrated into systems through V4L2 framework which enables out-of-the-box evaluation. e-con Systems also offers complete customization of firmware and hardware according to manufacturers’ application requirements.
Features and benefits:
  • Best in Class Global Shutter Efficiency helps to capture fast moving objects without motion blur
  • Onboard ISP helps to bring out best-in-class image quality in both uncompressed UYVY and offloads image processing tasks and reduces CPU usage
  • FHD up to 120fps helps to minimize frame to frame distortion
  • Low noise capabilities help to produce clear and sharp images in both low-light and bright scenes
Availability
Customers interested in evaluating FHD MIPI camera with NVIDIA® Jetson Xavier™ NX developer kit can purchase e-CAM24_CUNX from e-con Systems’ online store.
Axiomtek’s New Compact-Size Embedded System Targets Intelligent IoT Based Automation Solutions – eBOX630-528-FL
Axiomtek – a world-renowned leader relentlessly devoted in the research, development and manufacture of series of innovative and reliable industrial computer products of high efficiency – is pleased to announce the eBOX630-528-FL, its new fanless embedded system powered by the 8th generation Intel® Core™ i7/i5/i3 or Intel® Celeron® ULT processor (code name: Whisky Lake-U). The quad-core embedded box PC is designed with exceptional platform performance, abundant I/O interfaces, a wide-range power source, and triple display outputs. Its ultra-slim design allows it to be integrated for space-constraint applications. It also supports Axiomtek’s exclusive AXView 2.0 intelligent remote monitoring software to fulfill the requirement of remote monitoring. The eBOX630-528-FL is designed for smart production, machine automation, product testing, smart warehouse and AIoT-related applications.
The eBOX630-528-FL has a dual-channel DDR4-2400 SO-DIMM socket for up to 64GB of system memory. It also features two swappable 2.5” HDD drive bays and one mSATA slot for flexible storage options. For extra expansions, the rugged computer has two full-size PCIe Mini Card slots and one front-accessible SIM slot for various peripheral modules such as wireless modules, 3G/4G or LTE. Additionally, the fanless embedded box PC supports the optional PoE function through PoE board to support applications that require the use of IP cameras or any PoE device, such as vision inspection. Additionally, the eBOX630-528-FL supports up to three independent displays via two HDMI and one VGA port.
Advanced Features:
  • 8th Gen Intel® Core™ i7/i5/i3 or Intel® Celeron® ULT processor (code name: Whisky Lake-U)
  • Dual-channel DDR4 2400 SO-DIMM for up to 64GB of memory
  • Supports two HDMI ports, one VGA port, three GbE LAN ports, four COM ports, and six USB ports
  • 9V to 36V DC wide range power input
  • Fanless -40°C to +70°C* wide operating temperature range (at 0.7 m/s airflow)
  • Trusted Platform Module 2.0 (TPM 2.0) onboard
  • Supports AXView 2.0 intelligent remote monitoring software
“Axiomtek’s eBOX630-528-FL adopts the Intel® Core™ ULT Whiskey Lake processor to reduce energy costs without sacrifices in functionality or performance. This ultra-slim embedded system is capable of operating under wide temperature settings ranging from -40°C to +70°C and vibration of up to 3 Grms, which ensures reliable and stable performance,” said Janney Lee, product manager of Product PM Division at Axiomtek. “To be user-friendly and easy-to-deploy, the eBOX630-528-FL is specially designed with a front-accessible SIM slot and HDD drive bays. Moreover, it supports Trusted Platform Module 2.0 (TPM 2.0) to ensure a secure system environment.”
The Intel® Core™-based embedded box PC platform comes with diverse I/O interfaces including two RS-232/422/485 ports, two RS-232 ports, two USB 3.1 Gen2 ports, two USB 3.1 Gen1 ports, two USB 2.0 ports, three Gigabit Ethernet ports with Intel® Ethernet Controller I211-AT and Intel® Ethernet Connection I219-LM that supports iAMT, one 8-CH TTL port, two lockable HDMI ports, one VGA port, one audio port, and four SMA-type antenna openings. More features include AT/ATX switch, remote power switch and reset switch. The Intel® Whisky Lake-U-based system supports Windows® 10 IoT and Linux operating systems. Its flexible mounting options include VESA mount, wall mount and DIN-rail mount. Moreover, the eBOX630-528-FL supports a wide range 9V to 36V DC power input with over-voltage protection (OVP), under-voltage protection (UVP) and short current protection (SCP).
Axiomtek’s eBOX630-528-FL will be available in January 2021 for purchase. For more product information or pricing, please visit our global website at www.axiomtek.com or contact one of our sales representatives at info@axiomtek.com.tw.
M1108 AMP AI Accelerator Chip, Industry’s First Analog Matrix Processor
Mythic has announced the M1108 AMP AI accelerator chip, which is a compute-in-memory technology based on a 40 nm process, and boasted as the industry’s first Analog Matrix Processor (AMP). About the AMP, Mythic says Mythic AMPs are designed as an array of compute tiles. At the heart of each AMP tile is the Mythic Analog Compute Engine (Mythic ACE™) which integrates a flash memory array and ADCs that combine to store the model parameters and perform low power, high-performance matrix multiplication. Each Mythic ACE is complemented by a digital subsystem that includes a 32-bit RISC-V nano processor, SIMD vector engine, 64KB of SRAM, and a high-throughput network-on-chip (NoC) router. The result is an Analog Matrix Processor that delivers power-efficient AI inference at up to 35 TOPS. Edge devices can now deploy powerful AI models without the challenges of high power consumption, thermal management, and form-factor constraints.”
The M1108 is equipped with a host of flash cells, ADCs, a 32-bit RISC-V nano-processor, a SIMD vector engine, SRAM, and a high-throughput Network-on-Chip (NOC) router. The 108 AMP tiles enables the M1108 to clock at up to 35 Trillion-Operations-per-Second (TOPS), thereby enabling ResNet-50 at up to 870 fps. This enables the M1108 carry out power-efficient execution of complex AI models like ResNet-50, YOLOv3, and OpenPose Body25. The M1108 supports different processors such as Intel x86, NXP iMX8, NVIDIA Jetson, and Qualcomm RB5. The M1108 has a low power consumption of about 4W when running AI models at peak. The M1108 AI accelerator chip features powerful pre-loaded models for the AI use cases. These models includes object detector and classifier, human pose estimator, image segmentation, just to name a few.
The M1108 M.2 card (22mm x 80mm) has a tiny footprint, which enables it to be easily integrated into many different systems. The M.2 card is suitable for processing deep neural network (DNN) models, you can execute multiple DNNs simultaneously with it. It also features 4-lane PCIe 2.1 for up to 2GB/s bandwidth, with no external DRAM. There is also PCIe evaluation card (156mm x 121mm) which enables you to evaluate Mythic’s high performance, and power-efficient AI inference solution for edge devices and servers. The AI workflow offers support for PyTorch, TensorFlow 2.0, and Caffe.
“The efficient dataflow architecture of the Mythic AMP combined with its powerful model optimization suite and efficient graph compiler provides for deterministic execution of AI applications. AI system developers can be confident that when they design their product for a targeted accuracy, framerate, latency, or power profile, their performance targets are guaranteed when they deploy their product.”
Specifications includes:
  • Array of 108 AMP tiles, each with a Mythic Analog Compute Engine (Mythic ACE™)
  • Capacity for up to 113M weights – able to run single or multiple complex DNNs entirely on-chip
  • On-chip DNN model execution and weight parameter storage with no external DRAM
  • Deterministic execution of AI models for predictable performance and power
  • Execution of models at higher resolution and lower latency for better results
  • Support for INT4, INT8, and INT16 operations
  • 4-lane PCIe 2.1 interface with up to 2GB/s of bandwidth for inferencing processing
  • Available I/Os – 10 GPIOs and UARTs
  • 19mm x 19mm BGA package
  • Typical power consumption running complex models ~4W
The M1108 AMP will be available in PCIe M.2, and PCIe card form-factors. The M1108 mini PC evaluation kits are also available on request. You can find more information about the M1108 on Mythic’s website.
STMicroelectronics STEVAL-LLL009V1 Digitally Controlled Power Supply
STMicroelectronics STEVAL-LLL009V1 Digitally Controlled 300W Power Supply consists of power factor correction (PFC) and half-bridge LCC resonant converter power stages. An STM32F334R8 microcontroller implements DC-DC and output synchronous rectification digital control, while the PFC is driven in transition mode by the L6562AT controller. To ensure maximum efficiency, MDmesh K5 and MDmesh DK5 Power MOSFETs are used in the PFC and LCC half-bridge. The STripFET F7 Power MOSFET is employed to reduce conduction losses in the secondary side’s synchronous rectification stage. The primary and secondary sections are supplied by an off-line flyback circuit based on VIPER267KDTR high voltage converter for ultra-wide input, which provides regulated voltages to the control board, the gate driver ICs and the signal conditioning circuits.
The STMicroelectronics STEVAL-LLL009V1 Digitally Controlled 300W Power Supply delivers high efficiency, power factor near unity, and low THD across wide input voltage and load conditions.
  • System architecture based on transition mode boost PFC, half bridge LCC and synchronous rectification (full bridge)
  • 270V to 480VAC input voltage range
  • Output can be configured in constant current (CC) or constant voltage (CV) mode:
    • 300W maximum O/P power rating
    • 48.5V ± 1% CV mode
    • 6.25A ± 2.5% with voltage drop from 36 to 48V CC mode
  • Peak efficiency >93.5%
  • Power Factor > 0.9 for load > 33% of max. load of the input voltage range
  • THD < 20% for load > 25% of max. load of the input voltage range
  • Dimming control in CC mode configuration:
    • 0V to 10V control
    • 1% resolution
    • Analog dimming
  • Soft start
  • I/P and O/P under and overvoltage protection, O/P open/no load circuit protection, O/P short/overload circuit protection
  • Digitally controlled by STM32F334R8
  • RoHS compliant
  • WEEE compliant (2012/19/UE RAEE II)
more information: https://www.st.com/en/evaluation-tools/steval-lll009v1.html
TOP PCB Companies
