Hardkernel has announced an open-spec, “ODROID-HC4” Network-Attached Storage (NAS) device that runs Linux on a quad -A55 Amlogic S905X3 and offers 4GB DDR4, HDMI 2.0 and two PCIe-driven 2.5- or 3.5-inch SSD/HDD slots for just $65 to $75.
This follows after the company updated its Odroid-HC1 NAS board with an Odroid-HC2 model sometime in 2018, both of which are somehow limited as they support only one drive.
The new Odroid-HC4 however seems to be a powerful upgrade as the HC4 does not only switch to a more powerful Amlogic S905X3 processor but also adds a second SATA slot. For the first time also, the SATA slots are enabled via PCIe instead of USB, meaning a faster and more reliable operation.
“We’ve heard that many users wanted to run their storage server on a modern ARM 64bit platform with more DRAM memory, higher power efficiency and more storage capacity. Therefore, we started developing a new Home-Cloud platform late last year and it is time to show you something new based on the same ARM S905X3 CPU in the ODROID-C4”, says Hardkernel. “We connected a SATA SSD to the HC4 platform and measured the storage IO throughput. We could observe 390~420MB/s transfer speed which is quite good for many applications.”
Unlike most NAS systems, the ODROID-HC4 has what it takes to keep things running cool from the inside. It has a passive heat sink attached on top of Amlogic S905X3 processor and a 5V 4,000-RPM bearing fan that operates at 23.9 dBA. The drives can also be inserted into the case slots and exposed to open air rather than hidden away inside a metal or a plastic.
ODROID-HC4 is ideal for workgroups, single users and families members. The server centralizes data and enables users to share and stream multimedia files to desktop and mobile devices.
Key Features and Specifications of the new dual-bay NAS device include:
ODROID-HC4 comes pre-installed with an Ubuntu Linux image but will also support third-party software like CoreElec, OpenMediaVault and Android soon.
The basic ODROID-HC4 board with a pre-assembled case shell will be available for sale by October 27th for just $65 while another version with a 1 inch OLED display and real-time clock pre-installed and visible on the front of the case, for $75. The company will also offer optional accessories like Wi-Fi and Bluetooth adapters, IR remote control, USB-UART cable and ODROID-VU series display devices.
Further details may be found on their announcement and wiki pages.
Sinovoip has launched its latest Banana Pi model, which is a $16 board featuring Edgeless’ EAI80 microcontroller with 300 gigaoperations per second (GOPS) neural processing unit (NPU) on-board. The core of the Banana Pi EAI80 is the Edgeless EAI80 system-on-chip (SoC), which consists of a dual-core Arm Cortex-M4F primary processor clocking at 200MHz, and a 300MHz neural processing unit (NPU) designed to accelerate convolutional neural network (CNN) workloads with up to 300 GOPS of compute performance.
The board features 8MB of SDRAM memory, a 40-pin GPIO header, an LCD connector offering up to 1024x768px resolution, CAN bus header, two on-board microphones, and a DVP camera connector. The board is powered by a USB 2.0 Type-C connector, with network connectivity enabled by an on-board Espressif ESP8266 Wi-Fi module. The board runs uGelis embedded OS, and you can also program the board using the Kelis SDK which includes AI audio and computer vision demos for word recognition, hand gesture detection and recognition, and human body detection.
Target Applications of the Banana Pi EAI80 includes:
Voice Control – Key words real-time control
Computer Vision – Detection & recognition of object and biology (Face, Body, Gesture), vSLAM
Motor Control & Power Conversion – VFC,FOC, 3D/thermal Printers, ADAS, UAV, Robots STEAM education
EAI Series adopt “Dual-CPU+NPU” structure, combine AI ability with real-time and low power embedded MCU. Rich peripherals and HW-security integrated, EAI series are designed to support next-gen. IoT applications, provide single-chip turnkey solution with AI recognition and MCU control. Edgeless Embedded AI Series crossover processor, EAI series,under the wave of AIoT, are launched for smart home, industry, stem education, energy MGT and etc., with AI ability, low power and cost-effective, provide complete HW/SW turnkey solutions. Target to establish the smallest AI+MCU module in the world, promote transboundary innovation, empower end-sides and industries:
More advanced structure and performance
Lower run and standby power consumption
Voice / Computer vision / 2D Graph accelerator
Real-time operation / Multiple HW-level security
Easy to use / Richer integration / Lower cost
EAI series crossover AI MCU, CPU core is based on ARM Cortex-M4, ARMv7-M supports a predefined 32-bit address space, with subdivision for code, data, and peripherals, and regions for on-chip and off-chip resources, where on-chip refers to resources that are tightly coupled to the processor. EAI is a multi-core microcontroller implementing Dual-ARM Cortex-M4 cores. All cores have access to the complete memory map. One ARM Cortex-M4 is used as the master processor.
The other ARM Cortex-M4 core can be used as a co-processor to off-load the ARM Cortex-M4 and to perform complicated mathematical calculations. CNN processor is integrated in EAI, which can handle image detection and recognition use deep learning methods with high performance and low energy consumption. It supports mainstream CNN model such as Resnet-18, Resnet-34, Vgg16, GoogleNet, Lenet etc, convolutional with kernel size from 1 up to 7, channel/feature number up to 512, max/average pooling function with kernel
Hardware specs includes:
CPU Dual-Cortex M4F@200MHz 500DMIPS
AI-NPU:CNN-NPU @300 MHz 300GOPS
2D Graph :Dual-Camera Max
SDRAM 8M
LCD 1024*768 TFT-LCD
CANBUS 2.0 A/B
ESP8266 Wifi onboard
40PIN GPIO (share with LCD )
2 Mic support
The board is available on AliExpress for $16, and comes with an all-in-one educational kit, which contains the board, touchscreen display, camera, and USB power supply for $80. You can find more information on the Banana Pi wiki.
Many applications these days require a small or bigger display, either for displaying the time, temperature or other sensor value, or even just a battery indicator, in a simple manner. With them, you usually want some sort of animation, such as a blinking, so that the system feels more alive and interesting to the user. The problem is, with the nature of these devices, when you get to a lower power state in your microcontroller you lose the ability to display anything at all, and animating? Only in your dreams. A possible solution is to have a separate component dealing with the display state, so that your MCU can go to sleep and save power. Regarding this problem, the new PIC24F ‘GU/GL’ promises to help you out and bring much more to the table!
The PIC24F ‘GU/GL’ family is a set of extremely low power (XLP) microcontrollers from Microchip, that enable you to create some innovative applications, both with and without displaying capabilities. Being packed with 14 types of Core Independent Peripherals (CIPs) that can work even on low power saving modes, this series of MCUs offers ultra low power modes, just what you need for your battery powered projects. Besides that, there are also code protection features and this set of MCUs will also work with the CryptoAuthentication devices, in order to add security to your application in a secure manner.
Besides the interesting set of specs, remember us mentioning a little help with the displays? Well, one of the core independent peripherals from this series is a LCD with autonomous animation. But what exactly does this mean? As the name implies, you can use the integrated LCD driver from your MCU, independently of the power mode your microcontroller is in. Since it is detached from the CPU, it performs animations even when the CPU is in a sleeping state! Besides that, the MPLAB Code Configurator (MCC, for short) allows you to design an interface for the display with minimal fuss, eliminating the time consuming task of mapping pins from the seven segment display.
The animation capabilities from the display even when the MCU is asleep
Regarding applications, you can do a lot with this set of MCUs, such as applications where a display is necessary, such as automotive clusters, thermostats, measurement units and even medical devices. With its security capabilities, you can dive into secure IoT projects, such as smart sensors, in-home displays and fitness monitors / wearables. Devices designed for harsh environments are also a reality, such as industrial sensors and monitors, fault detectors and control / automation projects. Lastly, you can also take advantage of its low power capabilities with handhelds and projects in remote areas where access may not be easy. Regarding the pricing, MCUs are available for as little as $0.97, and for development boards with an LCD display you are looking at around $45.
Driving innovation in energy harvesting, e-peas has gained another major endorsement for its cutting-edge technology. The company’s highly optimised power management ICs are set to feature in a large scale remote monitoring application that is being rolled out across New York.
IoT solutions provider MCCI has incorporated the e-peas AEM10941, which specifically targets solar powered implementations, into a new environmental sensor module that it is about to start deploying. As part of a community-funded project, these sensor nodes will be placed in economically disadvantaged neighbourhoods within the city boroughs of Brooklyn, the Bronx and Harlem, where air pollution levels are extremely high.
The MCCI modules each feature PM2.5 particulate and VOC sensing devices, plus temperature and humidity sensors. Located on utility poles, these compact form factor units will dynamically gather real-time data relating to their surroundings every 6 minutes. This data will be transmitted back to a network hub via LoRaWAN connectivity for subsequent analysis. With prototyping almost completed, the pilot scheme is due to go into operation before the end of the summer.
Thanks to the AEM10941-based energy harvesting circuit, it has been possible to avoid powering the sensor module via a battery (and the inconvenience of battery replacement). This highly advanced e-peas power management IC can deal with the DC power output from up to 7 solar cells and supply hardware with two independent regulated voltages. It can start operating from a very low threshold – needing an input voltage of just 380mV and a 3µW input power. Supplied in a space-saving 28-pin QFN package (with 5mm x 5mm dimensions), the IC incorporates all the active elements needed for an energy harvesting subsystem, including a boost converter and two LDOs. Only 7 passive components (5 capacitors and 2 inductors) are needed to accompany it, thereby keeping the bill-of-materials costs down.
“As we want to carry out analysis at a granular level, the intervals between when data is acquired are very short. The e-peas ICs can start extracting energy at really low voltages, ensuring the power budget requirements of our modules can be fully satisfied,” states Terry Moore, CEO and founder of MCCI. “The company’s track record in remote sensing applications was another important factor, as was the quick turnaround time they were able to support.”
“Our AEM series is continuing to make headway in a variety of different industry sectors, with ICs that are purpose built to attend to the particular demands of photovoltaic, thermal, vibration and RF-based energy sources,” adds Christian Ferrier, CMO at e-peas. “Through this project with MCCI, and others that are currently underway, we will keep on building e-peas’ reputation as the preferred supplier of energy harvesting IC technology.”
Users of a microscope always want one with big viewing screen, and excellent image quality. One microscope that falls into this category and we had the chance to review, is the Andonstar ADSM302. ADSM302 is a multifunctional digital microscope individually designed, developed with full HD sesnor, high object distance, multi-output at the same time.
Additional the Andonstar measuring software can be used in many industries, such as industrial overhaul and teaching demonstration. Its appearance and design combines ergonomic consideration, and provides users with better experience. The ADSM302 is manufactured by Shenzhen Andonstar Technology Co and comprises an excellent quality microscope. Let’s dive in.
Unboxing
The microscope comes in a big box with plenty of insulation to protect it during transport. The box includes:
1 * Andonstar ADSM302 High Object Distance Digital USB Microscope
1 * Power adaptor
1 * USB cable
1 * HDMI Cable
1 * IR remote controller
1 * Manual (English)
Unboxing and powering up the unit took only 4-5 minutes. The microscope comes assembled and all you have to do to start is to add batteries to the remote control and connect the light and power control cable the the USB adapter. Hit power ON button and you are ready to go.
The first impression we had is that it is a well build and quality constructed microscope with precise movement of the focus and distance set knobs. The two LEDs add adequate light on the test bench and they are easily configured in both placement and light intensity.
First Impressions
The ADSM302 is the newer model of the ADSM201, with some improvements on some of the gripes people had with the older model. One area of improvement is the camera sensor. The sensor is larger and the working distance has been increased significantly because of the elongated tube for the lens to move. The ADSM302 also features a larger and higher quality screen than the ADSM201, with the ability to adjust it’s angle.
Another area of improvement is the base, which is much larger and heavier than the previous model. This give the device more stability. The objective table is big enough to do most of the soldering and repair work. One area of improvement i like is the black color, which is different from the reflective silver of the older model. This is a significant improvement, because the silver color made it hard to look at single components without glare. The Andonstar microscope is fully functional even without using it’s software or connection to a PC or TV screen.
The ADSM302features a 5-inch display. This increased resolution and size makes user experience better, from video recording to photo shooting to image analysis, making everything clearer. It also features a technical grade lens, which functions by focusing the light onto the field of view when the background is dark.
If there is too much light, the lens will deflect the light away from the light source in order to get a better image. It also features an adjustable monitor which enables the user choose the most comfortable and suitable angle from the display. Its UV filter helps to protect the lens from the heat, smoke, dust and other things which are produced by heat machines and soldering irons during repair work.
The UV filter can also help to reduce the effects of ultraviolet rays and increase the sharpness and color of the image.
The ADSM302 can support 4 different outputs, not including its own monitor: AV-OUT, USB,HD-OUT and SD memory card. It also features buttons & IR remote, which is handy when a user is doing some repair work on the table, it would be convenient for them to capture photos, record videos, zoom in and out etc from a distance.
If you want to perform object or specimen manipulation under the viewing lens barrel, you have a maximum working distance of slightly more than 4.5 inch. This should be sufficient space to perform any sort of SMD related works. The ADSM302 features two adjustable LED illumination arms shining down both sides of your viewing object or specimen. This gives the user a very clear and concise viewing experience.
If you need to carry measurement (spacing in between circuit board holes), or tool for counting bacteria inside a petri dish, there is a calibration software made available that comes with ADSM302, and can help you with on-screen measurements.
Software
Screenshoot from Andonstar Software
Software comes in Chinese and English and you have to go to the Language menu to change it (the third menu item from left). It offers some basic functionality to mark and measure points on an image acquired with the microscope. Before you make any measurements it is advisable to run a calibration of the software so you get some proper values.
We couldn’t find the download on the official website so we downloaded from Elektor reference page and we also included the download link below.
Specifications:
Material: metal+plastic
Main color: black
Image sensor: 3 mega pixels HD sensor
Video output: 1080P full HD;720P
Video format: MOV
Magnification ratio: up to 560x
Photo resolution: 12M
Photo format: JPEG
Focus range: 50mm to 220mm
Frame rate: max 30f/s under 600 lus brightness
Storage: micro-SD card
PC support: yes, for Windows XP/7/8/10
Remote control battery: 2 * AAA battery (not included)
Here are some images captured on the SD card of the microscope. As you can see the quality is nice and the images are sharp and clear. Resolution of images is 4032 x 3024 px which is fair enough.
In summary, the ADSM302 is a good and solid piece of equipment because of its full HD resolution, high object distance, multifunction abilities, multi-output at the same time. And also its appearance design combines more ergonomic consideration, provides user a better experience.
A mobile phone nowadays is an essential, probably the one thing we can’t live without, with 7.2 mobile devices being in use worldwide. But did you ever take a moment to realize where all the old phones are? Electronic waste is a big concern, with 50 million tons being generated this year. From these, only 12.5% being recycled. There is an estimate $60 million worth of gold and silver from the cellphones thrown away in the U.S. each year, and it only looks like it is getting worse! This is where the Teracube 2e comes in, the “Next Evolution of Sustainable Phones”!
But what is the Teracube 2e? It is a phone, as you can guess, but it has a huge particularity about it. It has a replaceable battery, is DIY repairable, made from recycled materials and comes in a sturdy biodegradable case. Besides this, it contains a 4 year premium care warranty. From the patterns the phone companies have gotten us used to by now, there are some interesting steps taken towards the Teracube 2e. First of, the battery: can you know anyone who misses the good days where you could take it out? Well, I do! The battery is one of the first components to get degraded over time, so the fact that you can’t easily replace it seems like a move to make you buy another phone.
Regarding the specs of the phone itself, there is nothing too impressive but not too disappointing either:
MediaTek Helio A25 octa-core processor, clocked at 1.8 GHz
4 GB of RAM and 64 GB of storage
6.1 inches HD+ IPS display (resolution of 720 x 1560)
Cameras: 8 MP (front) and 13 + 8 MP (rear)
4000 mAh replaceable LiPo battery
Fingerprint and face unlock
Connectivity: Wi-Fi A/B/G/N/AC, Bluetooth 5.0, NFC (with support for Google Pay)
Headphone jack, USB-C port, dedicated dual SIM with separate Micro SD slot
4 year premium care with flat fee repairs
A Teracube 2e for you to look at all day
Besides the battery, the phone is easily disassembled and repairable, as no glue is used in the production process, only screws. Meaning that you can, if you are brave enough, repair it yourself!The makers behind it mentioned spare parts will be available in the future. Their efforts to reduce the carbon footprint on this phone go as far as not including a charger (this time with no second intentions, heh Apple?), but there is an option for including a USB-C charger, if you live in a bunker and did not get one yet. The packaging is made of recycled paper and printed using soy ink.
Regarding the pricing, this phone is available for as little as $99, if you are fast enough, as this is an Indiegogo campaign that already reached its goal, and it was quite a success. Overall, we think it is a decent option for a phone, specially because of the mission it takes on.
The project presented here is an open source 2-digit 7 segment Arduino compatible display board. It can used in many applications that require 2-digit display and switches inputs. Possible application of this board is a 2-digit counter, 2-digit countdown timer, token display, score board etc. 2 x 7 segment 0.56-inch Common cathode displays are used in multiplexing mode. Refer to the connection table to check connections between display segments and Atmega328 chip. A led connected to A4 pin of IC is used as indicator LED. All 3 switches have pull-up resistors of 10Kohms, 220E ohms series resistors used between I/O pin of Atmega328 chip and display segments.
Arduino Compatible 2-digit 7-segment Display Board for Timer/Counter – [Link]
After the introduction of Intel’s Tiger Lake U-series processors that have support for TDPs up to 28W, notable vendors started adopting the Tiger Lake-U series to launch interesting systems that give a twist to the original NUC’s 100mm x 100mm ultra-compact form-factor (UCFF), and one of them happens to be ASRock Industrial.
Barely a month after ASRock unveiled ASRock iBOX 1100 rugged mini PC, the company is back to announce a more compact line of mini PCs powered by the 11th Generation Intel® Core™ i7/i5/i3 processors and Iris® Xe graphics.
The new NUC 1100 BOX Series available in three models – NUC BOX-1165G7, NUC BOX-1135G7, and NUC BOX-1115G4 – offers amongst others, an Intel® Wi-Fi 6 and 2.5GbE Ethernet connectivity, dual storage with M.2 Key M 2280/2260/2242, SATA III port for SSD/HDD as well as Quad-display outputs in picture-perfect 4K resolution. It is an all-inclusive BOX series expected to deliver phenomenal and reliable performance while handling real-time computing workloads.
“To have state-of-the-art technology included within an even smaller design, we hope users can enjoy more immersive home theater and gaming experiences, higher quality collaboration, and productivity, or induce commercial profits in business applications.”
says James Lee, President of ASRock Industrial.
Key Features and Specifications include:
SoC:
NUC BOX-1115G4 – Intel Core i3-1115G4 dual-core/quad-thread Tiger Lake UP3 processor running at up to 1.7 GHz / 4.1 GHz (Turbo); 15W TDP (Configurable between 12 and 28W); 48EU Intel UHD Graphics.
NUC BOX-1135G7 – Intel Core i5-1135G7 quad-core/octa-thread Tiger Lake UP3 processor running at up to 0.9 GHz / 4.2 GHz (Turbo); 15W TDP (Configurable between 12 and 28W); 80EU Iris Xe Graphics.
NUC BOX-1165G7 – Intel Core i7-1165G7 quad-core/octa-thread Tiger Lake UP3 processor running at up to 1.2 GHz / 4.7 GHz (Turbo); 15W TDP (Configurable between 12 and 28W); 96EU Iris Xe Graphics.
2x 260-pin SO-DIMM slots that support up to 64 GB of DDR4-3200 RAM
256 Mbit SPI flash
1x SATA 3.0 port
1x M.2 Key-M 2242/2260/2280 socket with PCIe x4 and SATA3
2×2 802.11ax Wi-Fi + Bluetooth 5.1 module
Intel Wi-Fi 6 AX200 M.2 card
1x 2.5GbE (Intel I225LM)
1x GbE port (Intel I219V)
1x HDMI 2.0a
1x displayPort 1.4
2x displayPort 1.4 outputs via USB Type-C ports
Quad 4K display support
1x 3.5mm audio jack (Realtek ALC233)
3x USB 3.2 Gen2 Type-A port (1x front and 2x rear)
2x USB 3.2 Gen2 Type-C ports
Watchdog timer
Kensington lock
Power Supply: 12V-19V DC
Dimensions: 117.5 mm x 110 mm x 47.85 mm
Weight: 1kg
Operating temperature range: 0ºC – 40ºC
Humidity: 5% – 90%
There’s no word on pricing and availability yet, but the company hopes to say something before the end of October. Further details however may be found here .
New IDS lenses with 5, 8 and 10 MP: Excellent price-performance ratio.
IDS is now offering more than 20 new C-mount lenses. Thanks to lens resolutions of 5, 8 and 10 MP as well as different focal lengths and optical classes, they can be used in numerous application scenarios. In addition, they are characterised by a very good price-performance ratio. With these features they fit seamlessly into the “It’s so easy!” product philosophy of the company.
“When implementing image processing applications, it is not only important to choose the right camera, the lens also has a decisive influence on the image quality,” explains Jürgen Hejna, Product Manager at IDS.
Focal length, resolution and aperture, for example, must be taken into account. The lenses are suitable for different sensor sizes (from ½ inch to 1.1 inch) and allow focal lengths of 4 mm to 75mm depending on the model. The aperture and focus can be fixed mechanically if required. This ensures that brightness and image quality remain constant even if the lens is exposed to vibrations, for example. An additional set of screws is included in each delivery.
The new lenses not only meet high demands on optical quality, but are also more than competitive in terms of price.
“For our customers, this means that they receive all components from camera to lens from a single supplier – and in the usual high IDS quality,” says Hejna.
The lenses can both be obtained from the company’s webstore where a configurator helps select the right model or via the local IDS sales representative.
Choosing the right interface for your machine vision application is a key decision in your camera selection process. The following sections provide an overview of the different types of cables and connectors available for machine vision applications along with associated pros and cons.
Dedicated interfaces
Useful for applications where extremely high-speeds or ultra high-resolution necessitate the use of such interfaces; for example, line-scan cameras used to inspect continuous flow processes like paper or plastic film production where cameras frequently work in the kHz range. However, these interfaces tend to be significantly more expensive, less flexible and add to system complexity. CarmeraLink (supports up to 6.8Gbit/s of data) and CoaXPress (supports up to 12Gbit/s) are dedicated machine vision interfaces typically used in such applications. In addition to the cameras, systems using these interfaces require frame grabbers. These are specialized adapter cards to receive image data and assemble it into usable images. Dedicated machine vision interfaces also use proprietary cables, making integration with other peripherals a little more challenging.
CoaXPress (CXP)
The CoaXpress interface was launched in 2008 to support high-speed imaging applications. CXP interfaces use 75ohm coaxial cables and support data transfer speeds of up to 6.25Gbit/s per channel, with the ability to use multiple channels to support even faster data transfer rates. A CXP cable can supply up to 13W of power per cable and requires that both the ‘device’ and the ‘host’ support the GenICam camera programming interface. While single-lane coaxial cables are inexpensive, the cost of setting up multi-lane cable assemblies and frame grabbers add up very quickly.
CameraLink
The CameraLink standard was launched in the year 2000 by Automated Imaging Association (AIA) and has been upgraded progressively in order to support higher data speeds, with some versions requiring two cables for transmission. The three main configurations available include Base (2.04Gbit/s), Medium (5.44Gbit/s) and Deca/Extended (6.8Gbit/s). The base standard uses MDR (“Mini D Ribbon”) 26-pin connector, while the medium/full configuration doubles capacity using a second cable. The Deca/Extended versions go beyond limits imposed by CameraLink, carrying up to 6.8 Gbit/s of data. Like CXP interfaces, CameraLink requires frame grabbers and additionally need to be compatible with Power over Camera Link (PoCL) standard in order to supply power. CameraLink lacks any error correction or resend capabilities, requiring expensive and cumbersome cable setups to try and eliminate dropped images by maximizing signal integrity.
Consumer interfaces
These interfaces enable machine vision cameras to connect with host systems using widely available USB and Ethernet standards. For most machine vision applications, the USB 3.1 Gen 1 and Gigabit Ethernet consumer interfaces provide a winning combination of convenience, speed, simplicity and affordability. Furthermore, consumer interfaces support widely available hardware and peripherals for machine vision implementation. USB and Ethernet hubs, switches, cables and interface cards can be purchased anywhere from Amazon to your local computer or electronics store at a range of price points to suit your exact requirements. Most PCs, laptops and embedded systems include at least one port each of Gigabit Ethernet and USB 3.1 Gen 1.
The most obvious difference between these categories of interfaces is their bandwidth. Faster interfaces enable higher framerates (Fig. 1) for a given resolution. A faster interface enables you to capture more images each second or capture higher resolution images without sacrificing throughput.
For example, a semiconductor wafer inspection system being upgraded from 8” to 12” wafers, higher resolution cameras will be required. In this case, the system designer will need to choose between keeping their existing interface and trading higher resolution for reduced throughput, or upgrading to a faster interface to maintain, or improve the throughput.
Fig. 1. Bandwidth available for each interface vs. sensor resolution and the resulting frame rate.
Your requirements for resolution, frame rate, cable length and host system configuration should all be considered to ensure you get performance you require without spending more than you need. FLIR’s machine visions cameras support all three trusted and widely available interfaces.
Universal Serial Bus (USB)
USB is everywhere. Look around and count the number of USB devices and accessories around you. See what we mean? Most USB machine vision cameras use the USB 3.1 Gen 1 interface. This interface provides up to 4Gibt/s of image data bandwidth between the camera and the host system. The USB3 Vision standard helps ensure compatibility between a wide range of cameras and software by defining a common set of device detection, image transfer and camera control protocols.
Fig. 2. USB 3.1 Gen1 cable (USB to locking USB)
USB supports Direct Memory Access (DMA). With this DMA capability, image data can be transferred across from the USB directly into memory where it is available for use by software. DMA coupled with the widespread support for USB and availability of drivers for USB controllers on virtually any hardware platform makes USB ideal for use in embedded systems. The 5m maximum cable length of USB 3.1 Gen 1 is generally not an issue for embedded systems. USB 3.1 Gen 1 can simplify system design by supplying up to 4.5 W of power to a camera. The recently developed USB Power Delivery specification allows some hosts to supply more power to devices like rapid-charging mobile phones, this specification is independent from the base USB 3.1 Gen 1 standard and has not been adopted by machine vision camera manufacturers.
Fig. 3. Different types of USB connectors
High-flexibility USB cables help maximize the lifespan of cables in systems where the camera must be moved repeatedly. Active optical cables (AOCs) may be used to greatly extend the working distance and provide Electromagnetic Interference (EMI) resistance. The performance of active optical cables is dependant on the throughput requirements and the host system configuration. When using optical cables, even those that supply power via the cable, FLIR recommends using powering cameras externally via GPIO. Additionally, locking USB cables provide a secure connection between cables, cameras and host systems. Prior to purchasing locking cables, FLIR recommends checking the locking screw position and spacing compatibility, as several options are available.
USB 3.1 Gen 1 is available on FLIR Blackfly S – Cased and Board level versions, and the tiny Firefly S.
Gigabit Ethernet (GigE)
GigE provides up to 1Gbit/s of image data bandwidth. Its combination of simplicity, speed, 100m maximum cable length and ability to supply power to cameras over a single cable make it an extremely popular camera interface. Ethernet cables are available with robust shielding. This is ideal for environments with high electromagnetic interference caused by proximity to the powerful motors found in some robots and metrology equipment. FLIR GigE cameras also support a packet resend feature which further boosts transmission reliability.
Unlike USB, GigE does not support DMA. Packets containing image data are transmitted to the host where they must be reassembled into image frames prior to being copied to software accessible memory. This process is trivial for modern PCs, though it may result in latency for some low-power embedded systems with limited system resources.
Fig. 4. Gigabit Ethernet / GigE Cable (RJ45 to RJ45)
The widespread adoption of Gigabit Ethernet means there is an incredibly wide range of supporting products from cables to switches, ready to meet any project requirement. GigE cameras support the IEEE1588 PTP time synchronization protocol, enabling cameras and other Ethernet enabled devices such as actuators and industrial Programmable Logic Controllers to operate on a precisely synchronized common time base.
The widespread adoption of Ethernet across many industries has enabled availability of many specialized cables and connectors for a wide range of use cases. For example, there are Ethernet cables designed to protect against EMI (Electromagnetic Interference), high temperature and chemical resistance, while some cater to high flexibility requirements and so on.
Ethernet cables have a category number depending on their construction. CAT5e is the most common for GigE, while CAT6A, CAT7 and CAT8 may be used for additional EMI resistance at the expense of greater cost and increased cable diameter. Some industrial devices use an X-Coded M12 (Fig. 3, right) connector to provide increased shielding, however, for most applications, the familiar RJ-45 connector is good enough and provides greater convince at lower cost. Additionally, screw locking RJ45 connectors easily add additional security to RJ45 cables.
Fig. 5. The ubiquitous RJ45 connector (left) and the less common X-Coded M12 connector (right)
Note: RJ45 connector is quick to connect and disconnect. X-Coded M12 connector (right) is slower to connect, but more robust and available in IP rated versions.
10GigE builds on the strengths of GigE by increasing the bandwidth to 10Gbit/s. 10GigE is an ideal interface for high-resolution 3D scanning, volumetric capture and precision metrology. GigE and 10GigE can be combined in numerous ways. Multiple GigE cameras can be connected to a 10GigE switch to support multiple GigE cameras at full speed over a single 10GigE port on a host system. While CAT5e cables will work with 10GigE cameras over distances less than 30m, CAT6A or higher cables are recommended.
10Gbit/sec is a lot of data! Modern PC systems with high-speed CPUs, PCIe 3.0 and dual channel memory can handle this well, while higher performance systems can support multiple 10GigE cameras. Embedded systems with reduced system resources will generally lack the memory bandwidth and processor speed required to keep up with the incoming image data.
10GgiE is available on FLIR Oryx cameras.
Summary
Both consumer and dedicated interfaces are used across many machine vision applications. Pros and cons mentioned in previous sections would eventually determine the suitability of one over another for a specific use case. However, the combination of performance, ease of use, widespread availability and low cost make consumer interfaces an attractive choice for most machine vision applications.
