AAEON’s SRG-IMX8PL and PICO-IMX8PL enhance its growing RISC computing line.
Industry leader AAEON has expanded its RISC computing product portfolio by releasing the SRG-IMX8PL and PICO-IMX8PL, a Mini PC and 2.5” PICO-ITX board, respectively. The NXP i power both products.MX 8M Plus platform, featuring a quad-core Arm® Cortex®-A53 processor with a Neural Processing Unit (NPU) operating at up to 2.3 TOPS.
Built to provide cost-efficient IoT Gateway solutions in rugged environments, the SRG-IMX8PL and PICO-IMX8PL both offer wide temperature ranges of -40°C to 80°C with the use of a fanless heatsink, a 9V to 36V power input range. The SRG-IMX8PL Mini PC also features enhanced shock, drop, and vibration resistance.
Dual LAN ports with IEEE 1588 and TSN capabilities, alongside Wi-Fi and 4G module support via M.2 2230 E-Key and full-size mini card, provide each device with broad connectivity options for industrial IoT use. Additionally, both the PICO-IMX8PL and SRG-IMX8PL support a wide range of operating systems, including Debian® 11, Android™ 13, Windows® 10 IoT, and Yocto, as well as data communication protocols such as Modbus, MQTT, and OPC Unified Architecture (OPC UA).
Key Features:
-40°C to 80°C with fanless heatsink + 9V to 36V power input range
Dual CAN-FD, dual RS-232/422/485, GPIO, SPI, I2C, and UART.
Modbus, MQTT, and OPC UA support
Dual LAN with IEEE 1588 and TSN, Wi-Fi and 4G module support via M.2
Other key interfaces that make the two products well-suited for low-power, efficient IoT applications are their various industrial communication protocols. Both platforms provide dual CAN-FD, dual COM for RS-232/422/485, and a range of other options such as GPIO, SPI, I2C, and UART. These interfaces offer scalability, long-distance communication, and wide compatibility for legacy systems.
It should also be noted that the SRG-IMX8PL is available with both wall-mount and DIN rail mounting options, making the compact system suitable for a variety of settings.
Pricing and ordering information are now available via AAEON’s online contact form, with the products also available via the AAEON eShop.
tinySniffer is a USB sniffer designed to capture USB 1.x and 2.0 packets remotely. Based on the Allwinner H3-powered NanoPi Neo Air SBC, tinySniffer makes use of WiFi connectivity to enable remote packet capture, and the captured data is compatible with the popular Wireshark packet analyzer tool.
While Wireshark can already capture USB packets, it has limitations, particularly in capturing some low-level USB packets. In such cases, a hardware USB sniffer like Total Phase Beagle USB, PhyWhisperer USB, or tinySniffer is necessary. The micro USB OTG port of the NanoPi NEO Air SBC is connected to the host computer, and the company added a USB 2.0 Type-A port connected to the USB interface on the GPIO header to connect a device under test, such as a USB keyboard, a USB Ethernet dongle, or a USB printer.
After configuring WiFi, the user can access the tinySniffer USB capture tool remotely by visiting the usb7.net website and selecting “My Devices.” This opens a terminal window in the browser, allowing users to capture packets with the sniff command.
Specifications
Processor:
Allwinner H3
Quad-core Cortex-A7
Memory:
512MB DDR3 RAM
Storage:
8GB eMMC Flash
MicroSD card slot for expansion
Connectivity:
WiFi: Dual-band 802.11b/g/n
Bluetooth 4.0
Ports:
1x Micro USB OTG port
1x USB 2.0 Type-A port
GPIO header with USB interface
Software:
tinyDebian Linux distribution
Compatible with Wireshark for packet analysis
Additional Features:
Remote access via usb7.net
Supports capturing USB 1.x and 2.0 packets
Video
The tinySniffer runs on the tinyDebian Linux distribution, which was first introduced in an article about the NanoPi NEO Air SBC modified with a dual-band WiFi module from the same company. However, neither tinyDebian OS nor the sniff command is open-source, so replication of this USB sniffer is not possible if you already own a NanoPi NEO Air board. You can copy those to your computer and analyze them in Wireshark , and the main advantage of the solution is remote access. More details can be found in the documentation.
The tinySniffer is sold for$199 on Tindie, which represents a significant markup compared to the $23 price for the NanoPi Air NEO. This pricing is similar to FPGA-based USB capture solutions.
Raspberry Pi Foundation has just announced the launch of Raspberry Pi Pico2, built around the RP2350 Microcontroller. The new board will feature dual Cortex-M33 or Hazard3 processors, increased SRAM and flash memory, and advanced security features like anti-fuse OTP for key storage, Secure boot, and Fast glitch detectors.
The company also mentions that more upcoming variants will be like the Pico 2 W with wireless functionality and models with pre-installed headers. The previous Raspberry Pi Pico RP2040 sold nearly four million units for various applications and with the upgraded specs and low cost of this new RP2350-based Pico 2 board the company expects to exceed that number.
Let me clear one thing, the new RP2350 will feature two sets of dual-core processors: the RISC-V and the Cortex-M33, but you can only use one set at a time. Other than that it’s very similar to the RP2040 but has faster cores, more memory, and an extra PIO block. The Cortex-M33 cores also have added security features.
The block diagram of the new RP2350 MCU gives us a good idea about the internal workings of the CPU, you can find the block diagram along with other information about this new controller on the Datasheet for the RP2350 MCU.
The company also provides a Pinout diagram of the RP2350 MCU along with the block diagram of the device, and as of my understanding the company offers two packages the RP2350A and the RP2350B the main difference between the two is that the B-package features additional GPIOs and analog inputs whereas the A-Package has the same number of GPIOs as of the RP2350A.
Raspberry Pi Pico 2 Specifications
Processor:
Dual Arm Cortex-M33 or dual Hazard3 RISC-V processors @ 150MHz
Memory:
520 KB on-chip SRAM
4 MB on-board QSPI flash
Compatibility:
Software- and hardware-compatible with Raspberry Pi Pico 1
Programming:
Drag-and-drop programming using mass storage over USB
Form Factor:
The castellated module allows soldering directly to carrier boards
Security Features:
Optional boot signing, enforced by on-chip mask ROM
Key fingerprint stored in OTP
Protected OTP storage for optional boot decryption key
Global bus filtering based on Arm or RISC-V security/privilege levels
Peripherals, GPIOs, and DMA channels individually assignable to security domains
Hardware mitigations for fault injection attacks
Hardware SHA-256 accelerator
Interfaces and Peripherals:
2 × UART
2 × SPI controllers
2 × I2C controllers
24 × PWM channels
4 x ADC channels
1 × USB 1.1 controller and PHY (host and device support)
12 × PIO state machine
Other:
Operating temperature: -20°C to +85°C
Supported input voltage: 1.8–5.5V DC
The Raspberry Pi Pico 2 utilizes the same C/C++ and Python SDK as its predecessor, with additional features for security. A new toolchain is available for RISC-V development. For more information, refer to the documentation website and GitHub repositories for the Pico SDK new MicroPython and CircuitPython images along with examples.
Various companies like Seed Studio, SparkFun, Tiny Circuits, Switch Science, Solder Party, and others have showcased their variants of the RP2350-powered dev boards which will be launching soon.
Raspberry Pi Pico 2 costs $5 and will be available until at least 2040. The RP2350 microcontroller price ranges from $0.80 to $1.30 depending on the variant and quantity.
Tenstorrent has released four new products based on their next-generation Wormhole chip, designed for scalable multi-chip development. These include the TT-QuietBox Workstation, Wormhole-based N300 PCIe Card, Wormhole n150 and n300 Developer Kits, and TT-LoudBox Workstation. The new products build upon Tenstorrent’s first Grayskull AI Dev kits and leverage the company’s open-source software stacks for advancements in AI software development.
The TT-QuietBox is a $15,000 liquid-cooled workstation for AI development, featuring 8 Wormhole processors (4x n300 cards) and a 96GB memory pool. Its quiet operation makes it ideal for various environments. It includes an AMD EPYC 8124P CPU, 512GB DDR5 memory, 4TB NVMe storage, and various connectivity options.
The n300s has dual Wormhole ASICs (128 Tensix Cores @ 1 GHz), 192MB SRAM, 24GB GDDR6 (12 GT/sec, 576 GB/sec). It achieves 466 TeraFLOPs (FP8) at 300W. Connectivity includes 2x Warp 100 Bridge, 2x QSFP-DD 400GbE, and PCIe 4.0 x16. Default cooling is passive with optional active cooling.
The n150s features a Wormhole ASIC with 72 Tensix Cores running at 1 GHz, along with 108MB SRAM, and can be configured with 12GB GDDR6 memory with 12 GT/sec, and 288 GB/sec bandwidth respectively. The ASIC can deliver 262 TeraFLOPs (FP8) at 160W power. In terms of connectivity, it features 2x Warp 100 Bridge, 2x QSFP-DD 400GbE, and PCIe 4.0 x16. Default cooling is passive with optional active cooling.
The TT-LoudBox is a $12,000 4U rack-mounted workstation designed for AI development. It features 8 Wormhole processors (4x n300s cards) with a 96GB memory pool, supporting models up to 80 billion parameters. It includes two Intel Xeon Silver 4309Y CPUs, 512GB DDR4 memory, 3.8TB NVMe storage, and various connectivity options.
TT-QuietBox and TT-LoudBox are supported by open-source SDKs TT-Buda (high-level) and TT-Metalium (low-level). The n150 and n300 kits support various data precision formats: FP8, FP16, BF16, FP32 (output), BFP2, BFP4, BFP8, INT8, INT32 (output), UINT8, TF32, VTF19, VFP32, enhancing versatility for AI and computing tasks.
Tenstorrent’s Wormhole n150s is available for $999, while the Wormhole n300s is priced at $1,399. The company also offers two workstation options: the TT-QuietBox for $15,000 and the TT-LoudBox for $12,000.
Waveshare Pi5 Module BOX is a multi-functional all-in-one mini-computer kit designed for Raspberry Pi 5. The most interesting feature of this kit is that it is made from aluminum alloy and includes the option to add a Gigabit Ethernet, PCIe to 4-ch USB3.2 Gen1 USB adapter board, or PCIe to M.2 interface card on the card. Also, the kit allows you to add Dual Micro HDMI to an HDMI adapter that gives access to two HDMI ports for connecting your monitor.
Compatibility – Designed for Raspberry Pi 5 (not included)
Case Material – Aluminum alloy
PCIe Adapter Options:
Module BOX-A – PCIe to Gigabit Ethernet
Module BOX-B – PCIe to 4x USB 3.2 Gen1
Module BOX-C – PCIe to M.2
Internal Space – Extra space for HATs and cable management
Adapters – Includes Pi5 HDMI and Type-C adapters for dual 4K outputs and dual power supply options
Cooling – Airflow vents with optional fan support
Dimensions – 163 x 91 x 43 mm
This Waveshare Pi5 Module BOX comes in three variants the Pi5 Module BOX-A which features a PCIe to Gigabit Ethernet adapter board is aloe the BOX-B features a PCIe to 4-ch USB3.2 Gen1 adapter, and finally there is the BOX-C which includes the PCIe to M.2 interface card. The company also provides detailed instructions on how to install the Raspberry Pi 5 and the attachment boards in case which can be found on the company’s product page. You can also check out the company’s wiki page for more information.
The Waveshare Pi5 Module Box can be purchased from Aliexpress where it’s priced between $24.10 to $28.69 or you can check out the waveshare store where it is priced at $21.99 to $23.99.
The Recore A8 is an all-in-one 3D printer control board with six built-in TMC2209 stepper motor drivers and support for two additional drivers. It features additional connectors for end-stops, Neopixels, servos, probes, and BLTouch(An auto-leveling sensor for 3D printers), on top of that the board supports various temperature sensors and includes durable JST PH connectors for secure cable connections.
The maker of this control board mentions that the PCB is an 8-layer PCB, which holds the components and is used to cool the TMC2209 stepper motor driver adding to longevity and durability. The board also supports various types of temperature sensors, like thermistors, thermocouples, and PT100/PT1000 sensors which means it can be compatible with a range of 3D printers.
Previously we have written about similar 3D printer control boards including the BIGTREETECH PAD 5, and Phi Mainboard 5LC feel free to check them out if you are interested in those topics.
Recore A8 3D Printer Control Board Specifications
SoC and Processor:
Allwinner A64 SoC
Quad-core ARM Cortex-A53 CPU @ 1GHz
Stepper Motor Drivers:
6x TMC2209 stepper motor drivers
Quiet operation
Precision control
Connectivity:
Industry-standard JST PH connectors
Improved cable retention
Configurable connectors
End-stops
Neopixels
Servos
Inductive probes
BLTouch (auto-bed leveling sensor)
Expansion Headers:
Supports 2 additional stepper motor drivers
Compatible with TMC2209 or Revolt drivers (48V power supply)
Temperature Management:
Supports:
Regular thermistors (4 inputs)
Direct use of thermocouples (4 inputs, no additional hardware needed)
PT100 and PT1000 sensors (PT100 requires an additional board)
Power Management:
Higher current 5V step-down converter
Enhanced voltage stability
Optimized ground layer clearances
Reduction in inrush current
PCB and Connectors:
8-layer PCB for durability
More robust 2 mm JST connectors
Enable pin for stepper motors
USB button for simplified interaction
Enhanced signal integrity
The Recore A8 3D printer control board, comes pre-installed with Debian Linux, offering users a choice of tools like Klipper, OctoPrint, MainSail, and Fluidd. Additionally, A recent Armbian forum update confirms support for models A5 through A8. The board is not fully open-sourced but documentation like PDF schematics, Allwinner binaries, and other files are available on GitHub, along with the Refactor Linux distribution for 3D printers. For more technical details, visit the Recore A8’s wiki page.
Electronic Polarization Of Atoms In Static Electric Field
In previous discussions, we have considered the effect of an electric field on charges in free space. In this section, we shall study the effect of electric fields on material media. Matter, which is made of atoms or molecules, comes in many varieties—solids, liquids, gases, metals, woods, and glass—and these substances do not all respond in the same way to electrostatic fields.
In free space, the electric field is defined as force per unit charge. This implies that the electric field in free space is a measurable quantity. However, measuring the electric field inside materials may be very difficult or impractical. Instead, we can focus on the external effects of a material body using external measurements.
In general, we classify materials according to their electrical properties into three types: conductors, semiconductors, and insulators (or dielectrics).
In terms of the orbital atomic model, each atom consists of a positively charged nucleus with orbiting negatively charged electrons in a cloud surrounding the nucleus.
In conductors, which are substances that contain a large number of mobile charges, the electrons in the outermost shells of each atom, are very loosely held and migrate easily from one atom to another. Most metals belong to this group. In a typical metal body, this means many of the electrons (one or two per atom) are not associated with any particular nucleus, but roam around at will.
In dielectrics, by contrast, every electron is attached to a specific atom or molecule, and all charges can move a bit within the atom or molecule. Such microscopic displacements are not as large as the rearrangement of charge in a conductor, but their cumulative effects account for the characteristic behavior of dielectric materials.
The electrical properties of semiconductors fall between those of conductors and insulators and they can pass a relatively small number of freely movable charges.
An atom as a whole is electrically neutral. When a neutral atom is placed in an electric field E, these two regions of charge within the atom are influenced by the field: the nucleus is pushed in the direction of the field, and the cloud of electrons the opposite way. Thus, the center of charge of the electron cloud in an atom moves slightly concerning the center of charge of the nucleus. This temporary separation of charge from their equilibrium position makes one side of the atom somewhat positive and the opposite side somewhat negative. This phenomenon creates a dipole moment in the atom and is called electronic polarization.
Figure 1 shows a model of an atom in a neutral condition and without any external electric field.
Figure 2 shows the effect of an external electric field on the polarization of the atom.
It is clearly shown that due to the direction of the external electric field E, the center of positive charges (protons) is displaced to the right side, and the center of negative charges (electrons) is displaced to the opposite side.
Molecular Polarization Of Dielectrics In Electric Field
Although the molecules of most dielectrics are normally neutral, the presence of an external electric field causes a force to be exerted on each charged particle and results in small displacements of positive and negative charges in opposite directions. Although these displacements are small compared to atomic dimensions, they can polarize a dielectric material and create electrical dipoles. These induced electric dipoles will modify the electric field inside the dielectric material.
In terms of molecular behavior in electric fields, dielectrics can be classified into two main types. Thus, when we put a piece of dielectric in an electric field, there are two possibilities happen, depending on the type of molecules in a dielectric:
1. Dielectrics with nonpolar molecules: These dielectric substances consist of neutral molecules. When they are placed in an external electric field, the field induces some tiny dipoles in molecules. This occurs because the external field tends to stretch the molecules and separate the centers of negative and positive charges slightly.
Figure 3 shows a nonpolar dielectric slab with no external electric field applied (Eex = 0). The circles represent the electrically neutral molecules within the slab. Then, the electric field inside this dielectric slab is also zero (Ein = 0).
Figure 4 shows that the slab is placed inside an external uniform field Eex. The result is a slight separation of the centers of the positive and negative charge distributions within the slab. It means each molecule would become a tiny dipole, with positive and negative ends slightly separated.
In Figure 4, there are long strings of induced dipoles. Along the line, the head of one effectively cancels the tail of its neighbor, but in the end, there are two charges left over. This produces a positive charge on one face of the slab (due to the positive ends of dipoles there) and a negative charge on the opposite face (due to the negative ends of dipoles there).
These are not free charges, and they cannot contribute to the conduction process. Rather, they are bound in place by atomic and molecular forces and can only shift positions slightly in response to external fields. They are called bound charges.
Figure 4 also shows that these bound charges produce a net electric field E’ in the direction opposite that of the applied electric field Eex. The resultant field Eininside the dielectric (the vector sum of fields Eex and E’) has the direction of Eex but is smaller in magnitude. Equation 1 explains this fact.
2. Dielectrics with polar molecules: In such dielectrics, molecules usually consist of two or more dissimilar atoms. The molecules of such dielectrics, like the water molecule (H2O), have permanent electric dipoles.
When there is no external field, the individual dipoles in a polar dielectric are randomly oriented, producing no net electric field macroscopically (Figure 5).
An applied electric field will exert a rotational force F on the individual dipoles and tend to align their axes with the field direction like that shown in Figure 6. The dipole moments (q × d) of polar molecules are of the order of 10-30 Coulomb-meters.
Thus, when an external electric field is present in polar dielectrics, all the electric dipole moments tend to line up with the external electric field as in Figure 7.
Because the molecules are continuously jostling each other as a result of their random thermal motion, this alignment is partially and not complete, but it might become more complete as the magnitude of the applied field is increased.
Therefore, the principal mechanisms by which electric fields can change the charge distribution of a dielectric atom or molecule are the rotating and stretching of tiny electric dipoles.
In conclusion, the effect of both polar and nonpolar dielectrics is similar to weaken any externally applied field within them.
Permittivity Of Dielectrics
In a conductor, the outer electrons of an atom are easily detached and migrate readily from atom to atom under the influence of an electric field. In a dielectric, on the other hand, the electrons are so well bound or held near their equilibrium positions that they cannot be detached by the application of ordinary electric fields. Hence, an electric field produces no migration of charge in a dielectric, and, in general, this property makes dielectrics act as good insulators. Paraffin, glass, and mica are examples of dielectrics.
The characteristic that all dielectric materials have in common, whether they are solid, liquid, or gas, and whether or not they are crystalline in nature, is their ability to store electric energy. An important characteristic of a dielectric is its permittivity (ϵ). It is the ability of a substance to hold an electrical charge.
Since the permittivity of a dielectric is always greater than the permittivity of vacuum ϵ0, it is often convenient to use the relative permittivity ϵr, of the dielectric, i.e., the ratio of its absolute permittivity to that of vacuum. Equation 2 explains the definition of ϵr.
where ϵr = relative permittivity of dielectric,
ϵ = permittivity of dielectric,
ϵ0 = permittivity of vacuum = 8.85 x 10-12 F.m-1.
Whereas ϵ and ϵ0 are expressed in Farads permeter (F/m), the relative permittivity ϵr, is a dimensionless ratio.
The relative permittivity of some media is shown in Table 1, where the values are for static (or low-frequency) fields and, except for vacuum or air, are approximate. The absolute permittivity of vacuum is unity by definition. Note that ϵ0, for air is so close to unity that for we can consider air equivalent to vacuum. Notice that ϵr is a constant greater than 1, for all other materials.
Dielectrics Inside A Capacitor
In our previous articles, we considered capacitors with air dielectric between their plates. Here we shall see how to modify and generalize that law if dielectric materials, such as those listed in Table 1, are present.
A capacitor is a device used to store electric charge. The amount of charge q a capacitor can store depends on two major factors – the voltage applied and the capacitor’s physical characteristics, such as its size and plate separation. Figure 8 shows an example of a parallel-plate capacitor that acquires charges from a battery.
For such a parallel-plate capacitor with the air dielectric between its plates, the capacitance due to its dimensions can be written in the form of Equation 3:
where, A is the area of plates, measured in squared meters and d is the distance between plates, measured in meters. Cair is the value of the capacitance with only air between the plates measured in Farad.
Historically, in 1837, Michael Faraday first looked into this matter, if we fill the space between the plates of a capacitor with a dielectric, which is an insulating material such as mineral oil or plastic, what happens to the capacitance? He found that the capacitance increased by a numerical factor denoted as κ, which he called the dielectric constant of the insulating material. Today, this factor is also known as the relative permittivity εr and these names are used interchangeably.
Faraday discovered that, with a dielectric filling the space between the plates, the capacitance of a parallel-plate capacitor is defined as in Equation 4:
It shows that by placing a dielectric between the plates of a capacitor, the capacitance is increased by the factor κ (= ϵr). Obviously, κ and ϵr are dimensionless quantities. Even common paper can increase the capacitance of a capacitor, and some materials, such as Titanium dioxide (TiO2), can increase the capacitance more significantly.
We have already defined the capacitance of this two-conductor system as the ratio of the magnitude of the total charge on either conductor to the magnitude of the potential difference between conductors, as explained in Equation 5:
Where Q is the amount of charge (in Coulombs) on each plate and Vc is the potential difference between plates (in volts). If we rearrange the variables in Equations 4 & 5, we achieve Equation 6 which is easier to understand:
Figure 9 provides some new insight into Faraday’s experiments. Figure 9a shows a simple electrical circuit, a parallel-plate capacitor with air dielectric (Cair) is connected to a battery with an arbitrary voltage Vc. Some amounts of charge (Q) are placed and stored on the plates of the capacitor and the battery ensures that the potential difference Vc between the plates will remain constant.
When a dielectric slab (with dielectric constant κ) is inserted between the plates, as shown in Figure 9b, because of increasing the capacitance C, the primary charge Q on the plates increases by the factor κ; according to Equation 6. Here, the battery delivers the additional charge to the capacitor plates to reach the new amount of Q’, where, Q’ > Q. So, when the potential difference between plates of a capacitor is maintained, as by the battery, the effect of a dielectric is to increase the charge on the plates.
In Figure 10a the battery is replaced by a voltmeter (a device for measuring potential difference). A capacitor cannot discharge through a voltmeter. Therefore, the primary charge Q must remain constant.
When a dielectric slab is inserted between the plates, as shown in Figure 10b, then the voltmeter shows that the potential difference (Vc’) between the plates reduces by a factor κ, it means that Vc’ < Vc.
Finally, both these observations, constant voltage (with battery) and constant charge (with voltmeter), are consistent with the increase in capacitance caused by the dielectric. Equation 6 confirms these results.
Dielectric Strength
When the electric field in a dielectric is sufficiently large, it begins to pull the electrons completely out of the molecules, and the dielectric becomes conducting. Dielectricbreakdown is said to have occurred when the dielectric becomes conducting. This phenomenon could be due to electron avalanche or ionization processes.
Hence, every dielectric material has a characteristic dielectric strength, which is the maximum value of the electric field that it can tolerate without breakdown. For example, this parameter for air is about 3 x 106 V/m. When the electric field intensity exceeds this value, the air breaks down and corona discharge happens. Sometimes it is observable as lightning between clouds in nature.
A few dielectric strength values are listed in Table 2.
Summary
Conductors are substances that contain a large number of charges that are free to move about through the material.
Dielectrics possess no free charges that can drift around under the control of an externally applied electric field.
Electronic Polarization occurs when an electric field distorts the negative cloud of electrons around a positive atomic nucleus in a direction opposite the field.
In insulators or dielectrics, all charges are bound to their atoms or molecules, and they can be forced to move by only tiny distances, with positive charges going one way and negative charges in the opposite direction.
A dielectric in which this displacement has taken place is said to be polarized.
Nonpolar molecules do not have permanent dipole moments.
The molecules of polar dielectrics possess permanent dipole moments, even in the absence of an external field.
In the absence of an external electric field, they have random orientations.
In polar molecules, each permanent dipole will experience a force by the external polarizing field, tending to line it up along the field direction.
When a lot of little dipoles are produced pointing along the direction of the field, the material becomes polarized.
The net charges at the ends are called bound charges because they cannot be removed.
The alignment of the electric dipoles in a polarized dielectric produces a net electric field inside the dielectric that is directed opposite the applied field and is smaller in magnitude.
The relative permittivity informs us about the electrical storage ability of an insulator.
The historical term for the relative permittivity was dielectric constant.
Because air is mostly space, its measured dielectric constant is only slightly greater than unity.
The dielectric strength is the maximum electric field that a dielectric can tolerate or withstand without breakdown.
The X-Sense STH51/STH54 Thermo Hygrometer is a WiFi-enabled device for precise and convenient indoor climate monitoring. Featuring high-precision Swiss-made sensors, it delivers temperature accuracy of ±0.36°F (±0.2°C) and humidity accuracy of ±2% RH. The device also has Wi-Fi with an open-air transmission range of 1700ft or 500m, so you can connect it to your home router and monitor your home environment remotely through a smartphone or a web app. Before going any further, one quick thing to clear is that the X-Sense STH51 is the sensor only and doesn’t come with a base station whereas the STH54 product code comes with three sensors and a base station.
The STH51/STH54 has a sleek, modern design that seamlessly fits into any home or office. These devices are compact & lightweight, making them easy to place on a shelf or mount on a wall. The build quality feels well built, with durable materials ensuring longevity.
Operational Features and Functionality
WiFi Connectivity: Among all the features one standout feature is the WiFi connectivity, which allows the devices to sync with the X-Sense Home app, enabling remote monitoring from your smartphone. Whether at home or away from home or office, you can check real-time temperature & humidity levels in your home. The mobile & web app is user-friendly & provides detailed results with history, which is extremely useful for tracking long-term bias. The app is available for both iOS & Android devices, offering easy access to data and settings.
Temperature and Humidity Monitoring: The primary function of this device is to accurately measure and record temperature and humidity levels, to achieve this the sensor module uses advanced sensors to provide accurate or specific readings with very little error. This certifies that the data provided by these thermo-hygrometers is ideal for maintaining indoor conditions; you can rely on it.
24/7 Data Logging and History: These devices store historical data, allowing you to review how temperature and humidity have changed over time. Analyzing this data helps identify trends and potential issues, enabling informed decisions for optimal environmental control.
Multiple Sensors: The STH51 requires the base station to work (doesn’t work stand-alone), and the option of the STH51 is for those who have already owned an X-Sense Base Station which also works with their Smoke & CO Alarms. With the help of the hub, multiple sensors can access temperature & humidity in different rooms at the same time. For example, you can place one sensor in the living room, another in the kitchen, & another in the bedroom. This way, you get a complete picture of the conditions of the entire house. It is useful for making sure every room is at the right temperature & humidity level, or for checking if there are any issues in specific areas.
Performance: In terms of performance, the sensor nodes can deliver consistent & reliable results. The sensors respond quickly to changes in the environment, and the readings are displayed and logged in the APP. The battery life is outstanding; these devices will last several months on a single one, depending on their usage and settings.
Alert System: To ensure you never miss a critical change in your environment, the X-Sense devices can send alerts and notifications directly to your smartphone. You can customize thresholds for temperature & humidity, receiving instant alerts if the conditions go beyond your set parameters. This feature is really useful for wine cabinets, and greenhouses to keep them in their best condition. It has configurable alerts for high or low temperature and humidity thresholds. (Please note that the X-Sense thermo-hygrometer is set to be used in a temperature range of -20-60°C as shown in the manual). Outside of this range, the measurement results will be somewhat skewed, and it is generally recommended that you do not use it in a refrigerator.
Integration with Smart Home Systems: The X-Sense thermo-hygrometer is compatible with smart home ecosystems, like Amazon Alexa. Google Assistant is not supported at the time of writing this review. This integration allows for voice-activated updates & flawless integration into existing smart home setups. Additionally, you can set up automation routines, such as triggering your HVAC system based on the readings from the sensors.
Model: STH51&STH54 (requires SBS50 Home Safety Hub)
Power Source: 2 AAA batteries (included)
Connection: 2.4 GHz Wi-Fi via SBS50 Base Station
Range: Up to 1,700 ft (500 m) open-air transmission
Monitoring Features: 24/7 monitoring, historical data storage, CSV data export
Compatibility: Works with Alexa for voice commands
Mounting Type: Free hanging, portable with lanyard
Included Components: 1 STH51&STH54 Thermo-Hygrometer, SBS50 Base Station
Battery Life: Up to 1 year
Temperature Range: -4°F to 140°F (-20°C to 60°C)
Temperature Accuracy: ±0.36°F (±0.2°C)
Humidity Range: 0% to 100% RH
Humidity Accuracy: ±2% RH
Weight: 14 ounces
Additional Features: Compact design, suitable for various environments including wine cabinets and terrariums
Dimensions: 6.61 x 4.72 x 3.27 inches
The X-Sense WiFi Thermometer Hygrometer models STH51/STH54 are excellent choices for anyone needing precise and convenient environmental monitoring. The fusion of accurate readings, WiFi connectivity, & smart home integration makes these devices a flexible addition to any home or office. The cost is slightly high for these thermo-hygrometers, but the features & performance make them worth buying, especially for those who want advanced functions and easy use.
The X-Sense STH51/STH54 Thermo Hygrometer can be purchased from the official X-sense store where it will cost you around $15.99 for a single sensor and $49.99 for 3-Pack& 1 Base Station. It’s also available on Amazon where prices are the same.
AAEON’s newest PICO-ITX board offers Meteor Lake processors, LPDDR5x, and a -20°C to 70°C temperature range.
Premier embedded computing provider AAEON, has announced the release of the PICO-MTU4, the smallest single-board computer to host the new Intel® Core™ Ultra Processor platform.
On the ultra-small 100mm x 72mm PICO-ITX form factor, the PICO-MTU4 leverages the disaggregated die design, hybrid CPU core architecture, and integrated VPU of the Intel® Core™ Ultra series for a multi-thread performance increase of up to 24%, with a 50% reduction in SoC power consumption.
Key Features:
Intel Core Ultra 5/7 Processors on the PICO-ITX (100mm x 72mm) form factor
Wide -20°C to 70°C default temperature range
LPDDR5x, up to 32GB
M.2 2280 M-Key (PCIe 4.0 [x4]), and an M.2 2230 E-Key (PCIe 4.0 [x1])
The board is available in SKUs featuring both Intel® Core™ Ultra 7 and 5 Processors, all with a TDP of 15W, maxing out at a total of 12 cores (2 P-cores, 8 E-cores, and a further 2 Low Power E-cores) and 14 threads of processing power.
Equipped with LPDDR5x, two LAN ports (2.5GbE and 1GbE), two USB 3.2 Gen 2 ports, and a variety of serial interfaces for industrial protocols like dual COM for RS-232/422/485, a 4-bit GPIO, and SMBus, AAEON have indicated the board will target the advanced industrial robotics market, with SCADA, MES, and system monitoring devices singled out as particularly suitable uses.
Expansion comes in the form of SATA, an M.2 2280 M-Key (PCIe 4.0 [x4]), and an M.2 2230 E-Key (PCIe 4.0 [x1]). This not only grants adequate storage, but also Wi-Fi 6 support and other wireless communication options for edge solutions such as roadside units, the suitability of which is evident with the board’s default temperature tolerance range of -20°C ~ 70°C.
For detailed specifications, please visit the PICO-MTU4product page on the AAEON website.
The OBJEX Link S3LW is an IoT development board built for battery-powered operations. The board features a custom S3LW system-on-module (SoM) built around the ESP32-S3 MCU. The board supports Wi-Fi, Bluetooth5, LoRa, and LoRaWAN communication protocols and features 33 GPIOs, I2C, I2S, SPI, UART, and USB interfaces, along with a STEMMA connector for easy integration.
There is a dedicated linear regulator for the LoRa radio, allowing for granular power control and optimization in different operating modes. The board can be powered via USB-C PD or a screw terminal block and supports various programming environments like ESP-IDF, Arduino IDE, PlatformIO, MicroPython, and Rus
EN 55032, EN61000-3-2, EN61000-3-3, FCC Part 15 Subpart B, Class B
EN 55035, IEC 61000-4-2 to 4-11
Dimensions:
Main Board: 22.00 x 30.00 mm
Warranty: 3 years
MTBF: >20,161,919 hours
To save power, the module has a separate power control for the LoRa radio and a latch that can turn off the rest of the hardware when not needed. This works together with the ESP32’s sleep modes to use less energy.
The board and module can be used with different programming tools like Espressif ESP-IDF, Arduino IDE, PlatformIO, MicroPython, and Rust.
OBJEX will release open-source design files for the development board and modules in the future. For more information, visit the OBJEX Link S3LW product page to sign up for updates and view preliminary datasheets.
