Type K Thermocouple Sensor Amplifier Arduino Shield
This is a Type K Thermocouple Sensor Amplifier Arduino Shield that enables an Arduino board to acquire temperatures from a thermocouple of type K. The shield works with a single supply and takes 5V DC from the Arduino board, the output of the circuit is 0 to 4V DC for 0-degree centigrade to 400C. The output of the amplifier is connected to the A0 analog pin of Arduino. A typical application of thermocouples is in boilers, soldering stations, and heaters. Also, 3D printers rely on thermocouples to measure the extruder temperature.
Type K Thermocouple Sensor Amplifier Arduino Shield – [Link]
High density robust SSD offers densities up to 1TB in a 16×20 mm BGA
2100AI/AT SSD Family – High density robust SSD offers densities up to 1TB in a 16×20 mm BGA
Micron has officially launched the Micron 2100AI/AT– an industrial- and automotive-grade PCIe NVMe Industrial SSD family based on 64-layer triple-level cell (TLC) 3D NAND technology. Available in 64GB-1TB BGA and 256GB-1TB M.2 form factors, the new 2100AI/AT series is Micron’s first offering with a PCIe interface supporting the NVMe protocol that is designed to address the needs of the industrial segment: longevity, reliability, quality, ruggedness, and application-specific features such as namespace, autonomous power transitions, and boot emulation.
These SSDs are ideally suited for the Aerospace and Defence market combining an extended temperature range and robust data protection features, along with Micron’s long-term product commitment and customer collaboration, creates a design that stands apart from the competition.
Designs that require high endurance can take advantage of application-specific features provided by these PCIe NVMe SSDs, such as namespace. With the namespace feature, a portion of the SSD (or the entire SSD) can be converted to SLC mode.
In addition to having a removable M.2 form factor, the BGA form factor offers a highly ruggedized solution for industrial applications—providing up to 1TB of storage space. Systems requiring greater than 1TB can utilize multiples of these devices to take advantage of the 16mm x 20mm package size.
Benefits
  • Extended Temperature Ranges: Withstand extreme environments via an industrial temperature range (2100AI: –40°C to 95°C), and automotive temperature range (2100AT: –40°C to 105°C), and adaptive thermal throttling.
  • Robust Data Security: Protect data with industry leading and on-the- fly hardware-based encryption, secure firmware download, and cryptographic erase.
  • Data Path Protection: Help protect user data as it passes through the SSD.
  • Power-Loss Protection: Protect data at rest, helping to ensure data integrity in unexpected power-loss events.
  • Responsive Performance: Deliver significantly faster boot, file and application load times compared to traditional hard drives.
  • Low Power Consumption: Consume considerably less power than typical hard drives.​
more information: www.micron.com
Advantech Releases High-Performance 3.5″ SBC MIO-5373 with 8th Gen. Intel® Core™ Processors
Advantech, a leading global provider of IoT systems and embedded platforms, is pleased to announce the latest 3.5″ SBC MIO-5373 based on the low power 8th Gen. Intel Core SoC. Featuring compact 146 x 102 mm dimensions, the MIO-5373 design not only offers impressive I/O functionality but also provides domain-focused features like CANBus and wide-range power input. It is ideally suited for use in application fields like medical equipment, automation control systems, outdoor kiosks, and areas requiring small dimensions and Intel Core-level computing power.
Quad-Core Performance and High Speed NVMe x4
The new 8th Gen. Intel Core low-power SoC (codename: Whiskey Lake-U) is the first generation to double the computing cores from dual to quad. This new generation provides up to 40% Multi-threaded computing performance over previous generation processors at a TDP of just 15 Watt. Featuring a built-in Gen9LP graphics engine, MIO-5373 supports three simultaneous displays through LVDS/eDP, HDMI, and DisplayPort interfaces up to 4K resolution, as well as H.265/HEVC, H.264/AVC, MPEG2 hardware decode/encode. The MIO-5373 supports Dual channel DDR4 memory up to 32GB(64GB*) and the M.2 M-Key 2280 for NVMe supports high-speed PCIe x4 SSDs, providing extremely high memory and mass storage data rates. Enhancing overall system performance—rather than just that of the core processor—makes the MIO-5373 very well-suited for image processing in medical applications or heavy loading content kiosk displays.
*64GB DDR4 memory supported with selected SO-DIMM modules.
Domain-Focused I/O and Flexible Expansion
MIO-5373’s built-in iManager 3.0 is based on Advantech’s EIO-201 embedded board management controller, which integrates power sequence control for higher reliability and generic functions including GPIO, hardware monitoring, smart fan control and watchdog timer. It also has domain-focused features like high-speed RS-232/422/485 up to 1Mbps, I2C (100kb/400kb/1Mb) and CANBus. iManager provides I/O functionality in company with drivers and software APIs on both the Windows and Linux operating systems to make it easier for software development. MIO-5373 provides adequate expansion for a variety of function cards, including M.2 E-Key for WiFi+BT or AI acceleration card, M.2 B-Key for 3G/LTE modules or SATA SSD’s  (optional with M-key for high-speed NVMe/PCIex4 SSD’s) What’s more, Advantech’s MIOe Extension interface provides 4x PCIe x1/USB/LPC/SMBus slots for vertically-focused or customized expansion. The MIOe-260 I/O module provides additional 2x GbE, 8x UART, 4x USB, 2x isolated CANBus, 1x miniPCIe socket and 1x M.2 B-key socket. Together with MIO-5373 and MIOe-260, it enables factory automation processes for AGV, CNC machines, or medical equipment I/O requirements.
Wide-Ranging Power Inputs and an Extended Operating Temperature Range
MIO-5373 comes with a 12-24VDC wide-range power input that easily connects to factory power rails or outdoor equipment with HVAC systems inside. To deal with extreme outdoor temperature conditions, MIO-5373 variants are available supporting operation from -40°C to 85°C. The advanced thermal solution leverages four symmetrical heatsink screw holes around the CPU to dramatically lower thermal resistance between CPU and heatsink and help heat quickly dissipate into air. MIO-5373 effectively solves temperature and thermal issues that often confront outdoor kiosks, railways, and crucial factory environments.
WISE-PaaS/DeviceOn: Value-Added Software and Cloud-Based Manageability
MIO-5373 provides ready-to-use Windows 10 and Ubuntu images in company with iManager software API and SUSI utility. Advantech’s WISE-PaaS/DeviceOn—IoT device operations and management software—makes it easy to integrate, visualize, operate, and manage industrial IoT devices through public or private clouds. With DeviceOn’s easy-to-use interface, users can monitor device health, enjoy real-time control over power on/off, troubleshoot, and perform updates over-the-air (OTA), on-site and remotely.
Product Features and Specifications:
  • 8th Gen. Intel® Core i7-8665UE/i5-8365UE/i3-8145UE
  • Dual channel DDR4-2400MT/s with up to 32GB and 32GB eMMC onboard
  • Triple simultaneous displays with 48-bit LVDS/eDP+HDMI+DP, up to 4K resolution
  • Dual GbE, 4x USB3.0, 2x RS-232/422/485, CANBus, 12-24VDC input
  • M.2 E-key 2230 for WiFi+BT, M.2 B-key 2280 for SATA SSD’s or 3G/LTE (optional M.2 M-Key 2280 for NVMe PCIe x4 SSD’s)
  • MIOe extension interfaces with 4x PCIe x1 (configurable as 2×2/1×4), DDI, USB, LPC, SMBus
  • Supports iManager software APIs for Windows 10 and Linux
  • Supports WISE-PaaS/DeviceOn
more information: www.advantech.eu
Meet the RFL-Watch: LoRa-Based Text Communicator
While adulations were still being showered on his work on the MORPHESP 240, Dr. Philippe Cadic (@Sulfroid on twitter), recently shared progress on another project called the RFL-Watch, via his twitter handle which is usually loaded with reports on the progress of his projects.
Based on the RAK4260, the RFL-Watch is a wearable LoRa communicator device which at the very least is expected to be able to tell time among other features.
The maker community for a while has been clamoring for an integrated Lora-MCU module similar to what is available with the ESP8266, with MCU and communication integrated into a single module. A number of LoRa-STM32 modules from Murata and STM themselves, have in the past seemed like a possible way out, but they require extra effort in RF design and certification, and Murata has a minimum order requirement (above 100 units), all of which puts the modules in a different category to modules like the ESP. The amount of LoRa-MCU vendor solutions in the market has increased, but it’s safe to say one of the few that has truly spoken to the pain point of makers has been the RAK4620 and @Sulfroid is already putting the module to use with this Watch.
The RAK4620, based on Microchip’s ATSAMR34J18B, combines a 32-bit ARM Cortex -M0+ MCU with a LoRa Transceiver in a compact surface-mount package, with key features including; Full support for 862 to 1020 MHz frequency coverage (all LoRaWAN® bands), High level of accuracy and stability (32MHz TXCO), Max Tx Power: 20dBm, Max Sensitivity (SF12 BW125kHz):  -136dBm, 17mA (typical) RX Current, and a rich selection of interfaces( I2C, SPI, ADC, UART, GPIOs).
While the work on the RFL-Watch is still in progress, the watch, asides the primary time-telling functionality, comes with a display, a 240 x 240 pixel, high-DPI, IPS LCD, through which a LoRa based text communication is expected to be implemented.
The project is still evolving and the final destination is still largely unclear, but you can follow the development process by checking out the twitter handle of the good Dr.(@sulfuroid).
We will also provide you with more information as things unfold. Stay tuned!
The K thermocouple has usually two wires, made of Alumel and Chromel that need to be connected with special care: no solder, just use a mechanical connection, therefore it is advisable to use special connectors available for thermocouples.
The circuit is built using LTC1049 op-amp and Thermocouple Cold Junction Compensator chip LTC1025. The board also supports other sensors like Type E, J, R, S, and T, however I have tested this circuit with Type K Sensor, jumpers are provided to use, and select other types of sensors.
The LTC1049 is a high performance, low power zero-drift operational amplifier. The two sample-and-hold capacitors usually required externally by other chopper stabilized amplifiers are integrated on the chip. Further, the LTC1049 offers superior DC and AC performance with a nominal supply current of only 200μA. The LTC1049 has a typical offset voltage of 2μV, drift of 0.02μV/°C, 0.1Hz to 10Hz input noise voltage of 3μVP-P and typical voltage gain of 160dB. The slew rate is 0.8V/μs with a gain-bandwidth product of 0.8MHz.
The LT®1025 is a micropower thermocouple cold junction compensator for use with type E, J, K, R, S, and T thermocouples. It utilizes wafer level and post-package trimming to achieve 0.5°C initial accuracy. Special curvature correction circuitry is used to match the “bow” found in all thermocouples so that accurate cold junction compensation is maintained over a wider temperature range. The LT1025 will operate with a supply voltage from 4V to 36V. The typical supply current is 80mA, resulting in less than 0.1°C internal temperature rise for supply voltages under 10V. A 10mV/°C output is available at low impedance, in addition to the direct thermocouple voltages of 60.9mV/°C (E), 51.7mV/°C (J), 40.3mV/°C (K, T) and 5.95mV/°C (R, S). All outputs are essentially independent of power supply voltage
  • Supply 5V DC
  • Thermocouple Sensor: Type K
  • Output 0 to 4V DC
  • Temperature Sensing range 0 to 400 Degree Centigrade
  • PCB dimensions: 31.75 x 51.12mm
Schematic
Parts List
Connections
Gerber View
Sample Code
  AnalogReadSerial
  Reads an analog input on pin 0, prints the result to the Serial Monitor.
  Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/AnalogReadSerial
// the setup routine runs once when you press reset:
void setup() {
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
// the loop routine runs over and over again forever:
void loop() {
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  delay(1);        // delay in between reads for stability
Photos
Video
LTC1049 Datasheet
LTC1025 Datasheet
QD7-0-SD/QD50-0-SD Position Sensing Detectors
OSI Optoelectronics’ position sensing detectors are ideal for light beam nulling and position applications
OSI Optoelectronics’ QD7-0-SD and QD50-0-SD are quadrant photodiode arrays with associated circuitry to provide two difference signals and a sum signal. The two difference signals are voltage analogs of the relative intensity difference of the light sensed by opposing pairs of the photodiode quadrant elements. In addition, the amplified sum of all four quadrant elements is provided as the sum signal. This makes the QD7-0-SD or QD50-0-SD ideal for both light beam nulling and position applications. With these detectors, very precise light beam alignments are possible and the circuit can also be used for target acquisition and alignment.
  • Precise light beam alignments
  • Beam nulling
  • Two difference signals
  • Sum signal
  • Position measuring
  • Beam centering
  • Targeting acquisition
  • Guidance systems
more information: www.osioptoelectronics.com
Detector-Filter Combination Series Planar Diffused Silicon Photodiodes
OSI Optoelectronics’ detector-filter combination series incorporates a filter with a photodiode to achieve a tailored spectral response in a multitude of standard and custom combinations. All detector-filter combinations can be provided with a NIST traceable calibration data specified in terms of amps/watts, amps/lumen, amps/lux, or amps.
The PIN-10DF is a 1 cm2 active area, BNC package detector-filter combination optimized to achieve a flat responsivity from 450 nm to 950 nm. This is the spectral response required for radiometric measurements. This type of detector has several advantages over thermopile, such as sensitivity, which is about a thousand times higher, as well as 10 times more stability.
The PIN-10AP is a 1 cm2 active area, BNC package detector-filter combination which duplicates the response of the most commonly available optical aid, the human eye. The eye senses both brightness and color with response varying as a function of the wavelength. This response curve is commonly known as the CIE curve. The AP filters accurately match the CIE curve to within 4% of the area.
The PIN-005D-254F is a 6 mm2 active area, UV enhanced photodiode-filter combination which utilizes a narrow bandpass filter peaking at 254 nm.
  • CIE match (AP series)
  • Flat band response (DF)
  • With amplifier hybrid
  • BNC packages
Applications
  • Analytical chemistry
  • Spectrophotometry
  • Densitometers
  • Photometry/radiometry
  • Spectroradiometry
  • Medical instrumentation
  • Liquid chromatography
Nano: spot welding just got easy and affordable
One of the major focuses of the maker movement since time immemorial has been the development of a makeshift version of tools with the goal of making them cheaper and more accessible. This focus has been more pronounced in recent times with several tools like CNC and 3Dprinters being all open-source, decentralized, and affordable to regular folks. To take things further to more machine tools, Canada-based battery refurbishing company; RePowered Batteries, recently announced the launch of their Nano Ultra-Compact Spot welder, which is aimed at making welding more accessible to hobbyists.
Sharing the reason behind the development of the Spot Welder, the team at RePowered Batteries said that the primary “goal is to make a no-hassle and affordable welder” that surpasses the current welders in the market by being both cordless (no external power supply required) and more efficient and safe compared to similar devices on the market.
The Ultra-Compact Spot Welder is comprised of a small built-in DC-DC power regulator, high-quality supercapacitors, and a welding control board on a PCB with 15x more copper than standard PCB, all packaged in a 3D-printed housing, with a selection of welding tips and air-cooled electrodes as consumables.
Built with versatility in mind, unlike other similar solutions in the market, the Spot Welder allows users to weld up to 0.15mm solid nickel. A table showing how the weather further compares with similar devices in the market is shown below:
While the goal is to make the device handy and untethered, one way to power the device is via the use of a 9v external power supply which could be useful, when you need to get things done, fast. However, if you are not in a hurry and not out of battery power, there are several other ways to power the devices including; power over USB or by hooking up a single 18650 battery cell to it.
The Kickstarter campaign for the device was launched a few days back and with just 21 days left, the project has raised up to $12,400 surpassing its initial goal of $3,047 by up to 400%. The device was designed in a modular form and the crowdfunding campaign provides users with the opportunity to buy them in parts, separately, or as a kit.
More information on the SpotWelder, the crowdfunding campaign, and perks, can be found on the project’s Kickstarter page.
AirBolt® GPS – The Tiny GPS Tracker You’ve always wanted
From pets wandering away and ultimately getting lost, to keys and other items getting misplaced, the desire to, at all times, be able to tell the location of things that are important to us is a priority to everyone. Several GPS tracking solutions exist on the market with small form factors and superb performancε thanks to advancements in communication and GPS technologies. However, with innovation, there is always room for improvement and greater heights to scale, and that’s exactly what Melbourn based AirBolt is doing with the launch of its new GPS tracker; the AirBolt® GPS which debuted on Kickstarter a few days ago.
AirBolt takes pride in its user-led design process as displayed in the AirBolt Smart Travel Lock which was released a while back, and the process was adopted for the development of the AirBolt® GPS. According to the AirBolt team, A total of 6 factors/features were considered and set as priorities during the design of the new GPS;
  • Small Form Factor
  • Long Battery Life
  • Customizable Alerts
  • Discrete Outlook
  • Shared Access
  • Global Tracking
  • Sturdy and Waterproof
Tailoring the design towards this features/goals led the team to the development of a small, only 37mm x 34mm x 11mm (1.45″ x 1.34″ x 0.43″) and VERY lightweight (approx. 21 grams, 0.75oz), LTE-M/NB-IOT enabled device, based on GPS rather than Bluetooth as in other devices.
The small and discrete nature of the device means it can be hung from the collar of a pet or slipped discreetly in a pocket/bag or be used as a keyholder.
Implementing location over LTE-M/NB-IoT, which are low-powered cellular networks, helps users leverage in the latest communication solutions while saving big on power, ensuring the device lasts for a long time before recharge is needed.
Some highlight features of the AirBolt® GPS as documented by CNX-software include:
  • SoC(s)
    • Unnamed, but considering Nordic Semi is listed as a partner it should be nRF9160 SiP with Arm Cortex-M33 MCU core, 1024 KB flash, 256 KB SRAM, NB-IoT, LTE Cat M1, and GPS connectivity
    • There’s also Bluetooth 5.1 so one of the nRF52 chips might also be included.
  • Connectivity
    • Bluetooth 5.1 with long-range and direction-finding support
    • Cellular – Worldwide support via NB-IoT and LTE Cat M1 (aka eMTC or LTE-M)
    • GNSS – GPS
  • Sensors – Accelerometer, temperature sensor
  • Misc – Alert Button, LED, a loud buzzer
  • Battery – Up to 12 months of battery life; rechargeable via USB-C port
  • Dimensions – 37 x 34 x 11 mm(ABS + anodised aluminum)
  • Weight – 21 grams
  • IP Rating – Not listed, but the tracker is said to be waterproof up to 1 meter for up to 30 minutes (IPX7)
The AirBolt® GPS has shown potentials of being a top-notch product as the Kickstarter campaign has already raised more than 200% of its goal with over 3,105 backers.
More information about the product and the Kickstarter which will be closing in about a week’s time can be found on the project’s campaign page.
DipDuino – An Arduino clone made for breadboarding
DipDuino is an Arduino clone that’s really small, even simpler to use, and designed for clean use with breadboards. It solves the problem of needing to jump wires from an external board to a breadboard, as well as the need to fit a PCB in a tight spot. Having the entire Arduino on a breadboard (including programmer) allows for easier transport and less chance of something being pulled off. Being so small allows it to fit inside a range of enclosures and odd places.
Just like the Arduino Pro Mini, you get access to all the pins possible; but DipDuino is presented in an easier-to-use package and with a built-in programmer. Not only is the package smaller, but the castellated holes allow you to use it a surface mount type of PCB as well.
Features & Specs
  • Processing:
    • Microchip ATmega328P
    • 8-bit AVR processor operating at 8 MHz (3.3 V) or 16 MHz (5 V)
    • 32 KB flash, of which 2 KB is used by bootloader
    • 2 KB SRAM
    • 1 KB EEPROM
  • Power:
    • Available in 5 V or 3.3 V versions
    • 5 V provided by USB
    • 600 mA 3.3 V LDO regulator on 3.3 V version
    • RGB LED – power is GREEN
  • USB:
    • USB Micro Type-B connector
    • CP2102N for USB-to-UART bridge
    • RGB LED – Tx (BLUE) & Rx (RED)
  • Form-factor:
    • Breadboard-friendly
    • Small size: 9.7 x 48.8 mm (0.38 x 1.92 in)
  • Connectivity:
    • 1x SPI, 1x I²C, 1x UART, 6x PWM, 8x ANALOG, 2x EINT
    • 21 GPIO broken out to standard breadboard-pitch holes as well as castellated holes for surface-mounting
    • USB for programming and USB-to-UART applications
    • EAST1616RGBA4 RGB LED for power/UART
  • Supports Arduino IDE:
    • Board set as Arduino Pro or Pro Mini
Programmable by PC/Mac/Linux Machines
DipDuino is as thin as a 0.3 in DIP chip (hence the name). It is super thin – which leaves all extra rows free and open for use. The board can also be surface mount soldered to a PCB. The USB-to-UART on board allows it to be programmed and communicate with PC/Mac & Linux machines, including Android devices.
more information: www.crowdsupply.com
TOP PCB Companies
