Broadcom AFBR-S4N33C013 is a silicon photo multiplier
The Broadcom® AFBR-S4N33C013 is a single silicon photomultiplier (SiPM) used for ultra-sensitive precision measurement of single photons. The active area is 3.0 × 3.0 mm2.
The high packing density of the single chips is achieved using through-silicon-via (TSV) technology and a chip-sized package (CSP). Larger areas can be covered by tiling multiple AFBR-S4N33C013 CSPs almost without any edge losses. The protective layer is made by a glass highly transparent down to UV wavelengths, resulting in a broad response in the visible light spectrum with high sensitivity towards blue- and near-UV region of the light spectrum.
The AFBR-S4N33C013 SiPM is best suited for the detection of low-level pulsed light sources, especially for the detection of Cherenkov- or scintillation light from the most common organic (plastic) and inorganic scintillator materials (for example, LSO, LYSO, BGO, NaI, CsI, BaF, LaBr). This product is lead-free and compliant with RoHS.
Key features
  • High PDE of more than 54% at 420 nm
  • Chip-sized package (CSP)
  • Excellent SPTR and CRT
  • Excellent uniformity of breakdown voltage, 180 mV (3 sigma)
Additional features
  • Excellent uniformity of gain
  • With TSV technology (4-side tileable), with high fill factors
  • Size 3.14 × 3.14 mm2
  • Cell pitch 30 × 30 μm2
  • A highly transparent glass protection layer
  • Operating temperature range from –40 °C to +85 °C
  • RoHS and REACH compliant
Applications
  • X-Ray and Gamma Ray Detection
  • Gamma Ray Spectroscopy
  • Safety and Security
  • Nuclear Medicine
  • Positron Emission Tomography
  • Life Sciences
  • Flow Cytometry
  • Fluorescence – luminescence Measurements
  • Time Correlated Single Photon Counting
  • High Energy Physics
  • Astrophysics
more information: www.broadcom.com
How to use PICKit+ with MPLAB-X IDE
PICKit+ recently announced that it is now possible to Program Microchip PICs from MPLAB-X using PICkit2 programmer and it’s even possible for those PICs that MPLAB-X programmer operations do not support.
The challenge
There are many PIC microcontrollers that currently not supported by MPLAB-X or MPLAB-IPE. This typically includes:
  • 16(L)F15xxx
  • 16(L)F18xxx
  • 16(L)F19xxx
  • 18(L)FxxK40
  • 18(L)FxxK42
  • 18(L)FxxK83
  • 18(L)FxxQ10
  • 18(L)FxxQ43
The Solution
This can be done by using the PICkit2 programmer and integrate it with MPLAB-X and be able to program old and new PICs.
  • Easy to integrate
  • No complex firmware changes required
  • Leverages your current investment in your programmers
  • The complexity of the MPLAB-X programmer setup removed.  It just works.
  • Support clone PICkit2 programmers
And the same applies to PICkit3 programmers.
Video
A demonstration
Program a 18F24k42 to flash an LED
  1. Create and edit MPLAB-X project to flash Porta.0
  2. Configure MPLAB-X project to use PICKitPlus
  3. You can use a PICkit2 or PICkit3 programmer
  4. Review results
for more details on the process check the video above.
Cricket ONE is an Arduino compatible board in Raspberry Pi form factor
The Cricket ONE is the first in a series of small microcontroller boards using the familiar form factor of the Raspberry Pi Zero series of single-board computers. Featuring an ATMEGA328PB and CH340C USB to UART converter, this board is Arduino IDE compatible and includes all of the features of the newer ATMEGA328PB.
Basic Specs:
  • ATMEGA328PB at 20 MHz (16 MHz Beta)
  • CH340C USB to Serial adapter
    • Supports board reset for automatic download
    • No external crystal necessary
  • 1A 3.3V LDO to support peripherals
  • Program download and power over microUSB
  • RPi-compatible pinout and mechanical design
    • Works with many HAT’s
    • Fits existing cases
The board is on sale at Tindie for 7 USD.
Toradex i.MX 8X-based System on Modules gain AWS certification and support for Torizon embedded Linux
Toradex is now bringing Torizon, its easy-to-use industrial Linux software platform, to its System on Modules (SoMs) based on the i.MX 8X applications processors from NXP®. Toradex offers the i.MX 8X-based SoMs in two form factors: the small Colibri iMX8X and the powerful Apalis iMX8X, with optional ECC memory. Toradex was among the first few partners to be part of NXP’s Early Access Program for the i.MX 8X applications processors and was shipping early samples of the Colibri iMX8X in 2018.
Additionally, the Colibri iMX8X is now AWS-certified and available in the AWS Device Catalog, based on certification requirements for Amazon IoT Greengrass. This certification is part of the AWS Device Qualification Program.
i.MX 8X-based SoMs are ideal for demanding applications requiring the highest reliability and power-efficient processing. Advanced security and safety features make these SoMs safety-certifiable. The SoMs come with up to four 64-bit Armv8 Cortex-A35 cores. Compared to the Cortex-A7, the Cortex-A35 can deliver up to 40% faster performance — and at the same clock speed — while consuming 10% less power. Compared to the Cortex-A53, it uses up to 32% less power at the same clock speed.
The Vivante GPU supports OpenGL™ ES, OpenCL™ and Vulkan® for modern graphics, or to accelerate such computing tasks as deep learning inference. The SoMs are also available with onboard Wi-Fi and Bluetooth, supporting dual-band 802.11ac 2×2 MU-MIMO Wi-Fi and Bluetooth 5.
An advanced, 28-nanometer FDSOI silicon process was chosen to build the SoC to increase MTBF and decrease soft error rates, which is crucial for critical applications. The additional Cortex-M4 core permits the offloading of critical real-time or safety tasks from the main operating system.
Toradex now provides Torizon, an open-source, embedded, industrial Linux platform for these i.MX 8X-based SoMs. Torizon provides a modern development platform, allowing developers to focus on their applications instead of on building a Linux operating system. Torizon offers integration with Visual Studio and Visual Studio Code. It comes with an automotive-grade update client for simple and secure over-the-air updates. Toradex’s high-quality reference images for the Yocto Project are also available for free. In addition, Android and QNX are available via the Toradex Partner network for i.MX 8X-based SoMs.
With the AWS certification for the Colibri iMX8X, developing cloud-connected devices that use Amazon IoT Greengrass and other AWS offerings is now simpler.
The Colibri iMX8X is pin-compatible with the complete Colibri family, including SoMs based on the NXP® i.MX 6i.MX 7i.MX 6ULL and NVIDIA® Tegra SoCs. Similarly, the Apalis iMX8X is compatible with SoMs featuring the i.MX 8QuadMaxi.MX 6 and NVIDIA TK1 SoCs.
Toradex’s Colibri and Apalis SoMs are an ideal fit in applications such as healthcare, transportation, industrial automation, testing and measurement, and smart cities.
megaAI – 4K, 60 FPS camera solution for computer vision
megaAI is a turn-key computer vision and artificial intelligence solution that combines and harnesses the 4 TOPS (Trillion Operations Per Second) of AI processing power with a beautiful 4K, 60 FPS camera for human/object tracking in a tiny, low-power, package. It’s perfect for hobbyists and researchers and is ready for direct integration by OEMs. It’s also compatible with our DepthAI ecosystem, and is therefore insanely easy to use.
Hardware Features
Unbelievably Simple Object Detection
megaAI takes previously difficult computer vision tasks like real-time object detection and tracking and makes them as simple as plugging in a USB cable and running a Python script. Just clone the DepthAI git repository and run python depthai.py to see a live demonstration of MobileNetSSD being run on your host system. You can even record live 4K, 30 FPS video of everything the camera sees.
Object Tracking & Detection
Object localization is the capability to know what an object is and where it is in the physical world. megaAI is able to accomplish this at 30 frames per second on a Raspberry Pi, without adding any load on the Pi.
The project is live on crowdsupply and has 9 days to go.
a project by Brandon Gilles.
World’s first fully self-contained Raspberry Pi audio HAT board with MERUS™ class D multilevel amplifier
Infineon Technologies AG developed the world’s first fully self-contained Raspberry Pi audio amplifier HAT (Hardware attached on Top) board. It offers high definition audio at boom box power levels in a small form factor. The Infineon proprietary multilevel technology ensures minimum size and consumption, state of the art power efficiency, and HD audio quality for Raspberry Pi users and makers. Target field of use are active speakers with wireless music streaming.
The board (KIT_40W_AMP_HAT_ZW) is compatible with Raspberry Pi Zero W and Raspberry Pi 3 and 4. It leverages the MERUS™ multilevel class D amplification enabled by the MERUS MA12070P amplifier, which allows for filterfree amplifier design that does not need to use a filter-coil at the output filter. This reduces significantly the BOM cost and enables PCB area reduction. The board furthermore scores high output power in small form factor up to 40 W instantaneous peak power at 4 Ohm. The solution offers best-in-class efficiency and playback time up to 20 hours with a ~6700 mAh power bank. There is no need for additional power supplies, only a single 5 V/2.5 A USB power supply is required for both the Raspberry Pi and the HAT.
For a quick and easy audio system set-up the board is compatible with the main Linux distributions such as Raspbian, Volumio, moOde Audio or JustboomPlayer. Dual-channel bridge-tied load (BTL) or single-channel parallel bridge-tied load (PBTL) configurations for Multiroom, TWS, or subwoofer applications are also possible.
Availability
The Raspberry Pi audio HAT audio amplifier board is on stock. More information is available at www.infineon.com/kit-40w-amp-hat-zw.
TransferFi Launches Wireless Power Network for Lightning Up Sensors Up To 55 Meters Away
For a while now, we have witnessed the use of wireless charging, by placing a phone or other devices that support wireless charging on a charging pad. Energous is one of the companies that started promoting their near-field, mid-field, and far-field wireless charging solutions, with far-field meaning within a room. But so far, they only have released near-field devkits and products. However, Singapore based TransferFi Pte has developed its own wireless charging solution called the TranferFi wireless power network (TFi WPN), aimed at powering sensors up to 55 meters away, and specifically aimed at building and factory automation to enable companies to save on installation and cabling costs.
The TFi WPN functions with a gateway powering up and receiving data from sensors wirelessly, having a range of up to 55 meters.  The TFi Gateway Max Turin-1 has a range of up to 32 TFi Sense devices through multichannel beamforming, offering support for up to 16 channels and can be connected to Modbus, BACnet & Web services. TFi Sense Turin-1’s sensor node is powered by a secret Arm Cortex-M4 microcontroller, and it enables a 3-axis accelerometer, a microphone, temperature, pressure, humidity & TVOC (Total Volatile Organic Compounds) sensors. It also further equipped with proprietary encryption & AES-128, and transmit at up to 5 Hz.
The TFi Sense Turin-1 is optimized to perform within the 860MHz – 940MHz frequency ranges. However, TransferFi can also offer the solution in the 2.4GHz – 5.8GHz bands on request. A representative of TransferFi Pte explains:
“All this is done through patented signal optimization and beamforming algorithms enhanced for long-range of Wireless Power Transfer (WPT) to more than 100m. We’re working on a developer kit which has loads of customization features for different sensors, communication ports, antenna and micro controllers.”
The company did not disclose more information about the kit at this time, but it is likely the “Max” gateway is relatively pricey, probably because the development kit will include TFi Gateway Lite Turin-1 instead which would just support one sensor nodes and have a shorter range.
The sensor is set to be a programmable sensor with control abilities for Home IoT or project. Comparing the TransferFi to Energous, the company says:
“The main difference with Energous is that we are truly long distance with transmission over 24-55m. Focus is on industrial Iot, enabling a digitization of a physical space.”
One of the key advantage of the solution is its much lower installation cost, due to the fact that traditional wired sensor deployments waste 80% of the time on installation & cabling, which is more than 60% of the overall sensor deployment budget. The TFi WPN platform boasts of reducing deployment time by 80%, and cabling and installation cost by 50%.
More details can be found on the company’s website.
7-segment Mini Clock using PIC16F628A and DS1307 RTC
This is a minimal and small clock based on PIC16F628A microcontroller and DS1307 RTC IC. It is able to only show the time on a small 7-segment display with a total of 4 segments. The display we used is a 0.28″ SR440281N RED common cathode display bought from LCSC.com, but you can use other displays as well such as the 0.56″ Kingbright CC56-21SRWA. This project is heavily inspired by the “Simple Digital Clock with PIC16F628A and DS1307” in the case of schematic and we also used the same .hex as”Christo”.
7-segment Mini Clock using PIC16F628A and DS1307 RTC – [Link]
iWave i.MX8M Mini Board with NXP eIQ ML Software Enables Low Cost Facial Recognition System
Have you recently been sceptical of using a contact-based access system in your office or a public place? This trait is a major concern in most places for a valid reason. An access surface in a public place is used by many individuals, which makes it a potential source for contracting the deadly Covid 19 virus. Taking this into account, iWave Systems, a leading embedded solutions provider, has successfully demonstrated an alternative solution using facial recognition technology. The solution helps customers with a zero-contact access application by using individuals’ faces to authorize access to a commercial/industrial space, home/office, transportation, banking, and Government sites.
Facial Recognition:
Facial Recognition is the process of recognizing the identity of a person by using their facial features against a previously stored database.
It is a technology that uniquely identifies or verifies a person by comparing and analysing patterns based on the person’s facial details. The face capture process transforms the analogy information into a set of digital information, while the face match process verifies the information with a database of known faces to find a match.
iWave Solution :
The facial recognition demo is running on iWave’s development board based on the NXP® i.MX8M Mini applications processor. The power-efficient edge computing platform with a SODIMM form factor is coupled with a MIPI Camera module (1080p@30 fps) , MIPI Display (1920 x1080 60fps), and multiple connectivity options. Through the support of key features such as camera, display, connectivity, and the NXP eIQ machine learning software, the i.MX 8M Mini board provides an intelligent platform for the development of facial recognition systems.
Demo Environment
The captured image and stored images are fed to the application to recognize the faces. eIQ OpenCV ML software compares the novel face features with the known face images in the Django framework database. Real-time data logging can be configured to send the information with alert for authorized or unauthorized detection.
NXP eIQ OpenCV Machine Learning Software:
 iWave i.MX8M Mini board is integrated with the NXP eIQ OpenCV machine learning softwarewhich enables faster time to market while reducing the development complexity. The eIQ software includes pre-optimized libraries and tools to perform machine learning and computer vision applications. The eIQ software enables developers to accelerate the development flow of the ML applications by taking full advantage of the underlying i.MX8M Mini SoC. The software supports C++/Python/Java API’s which provides the programming flexibility to the developers.
Why iWave?
 iWave Systems Pvt. Ltd., with vast expertise in NXP platforms, provides a wide range of custom and standard NXP System on Modules –i.MX6 , i.MX8i.MX8M, i.MX8X and i.MX8M mini/nano. iWave assures customers of product longevity of 10+ years, providing custom design services and long term technical support. iWave can help customers with custom design implementation, porting trained models, hardware, and software pipeline optimization for machine learning functions on the i.MX8M.
More detailed information on the i.MX8M Mini board can be found here.
To get in touch with us for enquiries and further information, please write to mktg@iwavesystems.com or contact our Regional Partners.
Next-generation AI Processing Solution for Video Analytics at the ‘Edge
Foxconn, a global leader in smart manufacturing, is joining Socionext, a major provider of advanced SoC solutions for video and imaging systems, and leading artificial intelligence (AI) chipmaker Hailo to launch the next-generation AI processing solution for video analytics at the edge.
Foxconn has combined its high-density, fan-less, and highly efficient edge computing solution, “BOXiedge™”, with Socionext’s high-efficiency parallel processor “SynQuacer™” SC2A11, and the Hailo-8™ deep learning processor. The new combination provides market-leading energy efficiency for standalone AI inference nodes, benefiting applications including smart cities, smart medical, smart retail, and industrial IoT.
Robust Solution Processes More Than 20 Camera Streaming Inputs in Real Time
In a global AI market forecasted by research firm IDC to approach $98.4 billion in revenue in 2023, this joint solution helps address the need for cost-effective multiprocessing capabilities required in video analytics, image classifications, and object segmentation. The robust, high-efficiency product is capable of processing and analyzing over 20 streaming camera input feeds in real-time, all at the edge. The result is a high-density, low-power, complete local VMS server, ensuring top performance for video analytics and privacy, including image classification, detection, pose estimation, and various other AI-powered applications – all in real time.
“Our vision at Foxconn is to pave the way for next generation AI solutions,” said Gene Liu, VP of Semiconductor Subgroup at Foxconn Technology Group. “We are confident that this strategic collaboration with our long-standing partner, Socionext, alongside Hailo, will do more than that. We recognize the great potential in adopting AI solutions for a multitude of applications, such as tumor detection and robotic navigation. This is why we are proud to say that our edge computing solution combined with Hailo’s deep learning processor will create even better energy efficiency for standalone AI inference nodes to positively impact rapidly evolving sectors including smart cities, smart medical, smart retail, and industrial IoT.”
Foxconn has already deployed several in-house developed AI solutions on different production lines, leading to an improvement in reporting accuracy from 95% to 99% and a reduction of at least one third of the operating costs for appearance defect inspection projects.
We are very pleased with this joint effort by the companies, and to officially announce our strategic partnership with Hailo,” said Noriaki Kubo, Executive Vice President at Socionext. “This collaboration will lead to more innovative solutions that specifically address the growing demand from our AI customers in multiple sectors. We are confident that this product will enable endpoint devices to operate with better performance, lower power, more flexibility, and minimal latency.”
Hailo’s specialized Hailo-8™ deep learning processor delivers unprecedented performance to edge devices. Featuring up to 26 Tera Operations Per Second (TOPS), the chip is built with an innovative architecture that enables edge devices to run sophisticated deep learning applications that could previously only run on the cloud. Its advanced structure translates into higher performance, lower power, and minimal latency, enabling enhanced privacy and better reliability for smart devices operating at the edge.
“We are thrilled to announce our collaboration with two of the global leaders in AI solutions,” said Orr Danon, CEO and Co-Founder of Hailo. “Our deep learning processor significantly upgrades the capabilities of smart devices operating at the edge, and this collaboration will impact a wide range of industries increasingly driven by edge technology. A new generation of chips means a new generation of capabilities at the edge.”
The next generation of the BOXiedge AI computing solution is equipped with applications for a broader market relying on low latency, a high data rate, high reliability, and quick processing at the edge. Smart retail and smart cities, for instance, require hundreds of cameras – either in-store or in traffic monitoring – to generate video streams that need to be processed locally, quickly, and efficiently with minimal latency. Similarly, for industrial IoT, where every split-second counts, data acquiring, processing, inferencing, and presenting on the production floor rather than in the cloud translates into significant cost savings along with more efficient processing for tasks such as inspection and quality assurance.
TOP PCB Companies
