![](https://www.electronics-lab.com/wp-content/uploads/2023/10/Main-Image-5.jpg)
BEAVERLAB is excited to announce the launch of a Kickstarter campaign for Davcarve L1, the world’s first dual-laser, multi-module engraver and cutter. Backers can enjoy significant discounts of up to 55% off during the campaign, which starts on October 10 2023.
Support the innovative Davcarve L1 by joining our Kickstarter campaign! Explore all the fantastic features and back us on Kickstarter. Help bring this versatile engraving and cutting tool to life, and be among the first to turn your creative visions into reality with unmatched precision and ease!
Three Laser Modules + 3 other modules
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/3-laser-modules.gif)
The Davcarve L1 L1 is a 6 modules in one machine: 2W infrared laser module, 10W blue laser module, 20W blue laser module, CNC module, fine point module, and artistic drawing module. The 540nm blue laser modules, available in 10W and 20W power options, are ideal for engraving and cutting across various materials, including wood, leather, MDF, opaque acrylic, fabric, dark glass ceramics, and even cement.
![](https://www.electronics-lab.com/wp-content/uploads/2023/09/7-1-850x639.jpg)
For engraving on metal materials such as copper, gold, silver, titanium, and stainless steel, the 2W infrared laser module is an ideal choice.
Powerful CNC Modules
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/7.jpg)
With its 10,000 RPM ER11 spindle and 3.175mm spring collet, the CNC module transforms the Davcarve L1 into a powerful CNC router machine, which allows for efficient and smooth carving on thick and rigid materials, as well as precise carving of thinner materials like PCBs.
Fine-Point Blade Cutting
![](https://www.electronics-lab.com/wp-content/uploads/2023/09/图11-图-850x850.jpg)
The Davcarve L1’s Fine Point Blade Module features a secondary pressure spring and telescopic blade. Users can use this module to cut most flexible materials with a fine-point blade and a reach of up to 14mm.
Create Hand-Drawn Artwork
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/EngravingCutting-Works-1-scaled.jpg)
The Davcarve L1’s drawing module can help those who struggle with drawing turn their wishes into reality. With a range of pen sizes and styles, diameters from 5 to 20mm, and lengths from 80 to 190mm, including gel pens, markers, and ballpoint pens, this module provides endless possibilities for creative expression. The drawing module can automatically create stunning hand-drawn artwork by presetting art templates and parameters in the software.
Easily Replaceable Parts
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/5-scaled.jpg)
The Davcarve L1 has a unique design called a dovetail slot which allows you to quickly and easily replace or install parts without needing any extra tools, electricity, or air connections. This makes using the Davcarve L1 simpler and reduces hassle during operation.
2,000 mm² Working Space
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/aspect.jpg)
Davcarve L1 offers a vast working area of 400x500mm, allowing you to unleash your creativity fully. By installing the optional risers, you can increase the working height of the Davcarve L1 to an impressive 110mm, granting you even more flexibility and space to work with.
High Performance
The Davcarve L1 is a machine equipped with a strong 57mm motor that can engrave designs at a speed of up to 1000mm/s. It lets professional users tweak the engraving settings to achieve unique effects manually. This machine is precise to 0.01mm, allowing for detailed engravings on different materials. It’s great for artists, designers, and DIY lovers, helping to turn digital designs into real creations with high accuracy.
Additionally, the Davcarve L1 is good for cutting through thick materials. It has a 20w laser module that can easily and precisely cut through 15mm wood or 10mm acrylic sheets in a single go, which helps reduce restrictions on the thickness of materials for your projects.
Curved Engraving with Ease
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/EngravingCutting-Works-2.jpg)
The Davcarve L1 comes with features for rotary engraving. It has adjustable attachments and rollers that allow you to engrave on curved objects like rings, balls, cylinders, and cones. You can engrave both the outside and inside surfaces of these curved items with ease using this tool.
Intelligent Design
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/7-APP.jpg)
BEAVERLAB’s LaserCreate app is a user-friendly engraving software designed for beginners. It features a comprehensive library of resources, simple instructions, and video tutorials. With the app, you can easily adjust engraving settings and remotely monitor your project’s progress by using your smartphone.
The LaserCreate PC software is designed for handling complex projects that require precise design and detailed parameter settings. It is equipped with multiple languages and supports a variety of vector graphic formats, including DXF, SVG, JPG, PNG, BMP, and NC. The best part? You can enjoy free updates for life with LaserCreate!
Offline operation lets you unleash your creativity anywhere and anytime! With its built-in 16GB TF card, you can save hundreds of files in advance. The intuitive joystick and roller give you complete control over the X/Y and Z-axes. With the intuitive touch buttons next to the HD IPS screen, you can easily select the files you want to engrave or cut without any hassle.
Safety is the top priority
![](https://www.electronics-lab.com/wp-content/uploads/2023/10/incline-stop.gif)
Davcarve L1 is designed with user safety in mind. Equipped with a gyroscope sensor, flame detector, and active stop button, the device immediately stops working if it detects a flame or if the tilt angle exceeds 15 degrees, ensuring maximum safety. Additionally, Davcarve L1 has obtained CE, FCC, FDA, and RoHS certifications, indicating that all products and accessories meet international safety standards.
