IB822 – 3.5-inch SBC features Intel Gemini Lake
IBASE Technology Inc., a world leading supplier of embedded board and industrial computing systems, has released the IB822 3.5-inch SBC (single board computer) supporting Intel’s “Gemini Lake” Pentium® Silver J5005 and Celeron® J4005 processors built with 14nm fabrication, a base clock/burst rate of 1.5GHz/2.8GHz and 2.0GHz/2.7GHz, and integrated Intel® UHD Graphics 605 (18EUs@800MHz) and UHD Graphics 600 (12EUs@750MHz) respectively.
“Enabling lower power consumption, the highly compact IB822 offers silent and extremely reliable operation. Its fanless and power-efficient design makes it a durable embedded computer solution,” said Wilson Lin, Director of IBASE Product Planning Department. “With the 10W TDP (thermal design power), the IB822 is just the perfect fit for low power applications such as kiosk, panel PC and those in factory automation environments.”
The IB822 includes a rich set of standard features including two DDR4 SO-DIMMs for up to 16GB of DDR4-2400 memory, two Intel® PCI-E Gigabit Ethernet and 12V~24V power input. Providing triple independent display, graphics interfaces include an HDMI (2.0a), a DisplayPort, and eDP or 18/24-bit dual LVDS. Measuring 102mm by 147mm, the board offers comprehensive I/Os with two M.2 sockets for storage, four COM ports, four USB 3.0 ports, and two SATA III ports to ensure usability and interoperability.
The two IB882 models are now readily available. For more information, please contact your local sales representative or see our website at www.ibase.com.tw.
IB822 FEATURES
  • Onboard Pentium® Silver / Celeron® SoC
  • 2x DDR4-2400 SO-DIMM sockets, Max, 16GB
  • Supports HDMI (2.0a), DisplayPort and eDP or 18/24-bit dual-channel LVDS
  • 2x Intel® 211AT PCI-E Gigabit LAN
  • 2x M.2 sockets (B/E key)
  • Digital I/O, iSMART, Watchdog timer
Specifications for the IB822 include:
  • Processor — Intel “Gemini Lake” :
    • Pentium Silver J5005 (4x 14nm cores @ 1.5GHz/2.8GHz burst); Intel UHD Graphics 605 (18EUs @ 800MHz); 10W TDP
    • Celeron J4005 (2x 14nm cores @ 2:00GHz/2.7GHz burst); Intel UHD Graphics 600 (12EUs @ 750MHz; 10W TDP
  • Memory — Up to 8GB DDR4-2400 via 2x SODIMMs
  • Storage — 2x SATA III (6Gbps)
  • Media:
    • HDMI 2.0a port
    • DisplayPort
    • eDP or 18/24-bit single/dual-channel LVDS
    • Intel HD Audio and Realtek ALC233-VB2-CG
    • Class-D speaker amplifier
  • Networking — 2x Gigabit Ethernet ports (Intel 210AT via PCIe)
  • Other I/O:
    • 4x USB 3.0 ports
    • 2x USB 2.0
    • RS232/422/485 port (DB9)
    • 3x RS-232
    • DIO
  • Expansion — 2x M.2 slots (B-key 2242 and E-key 2230)
  • Other features — Watchdog; hardware monitoring; iSMART 3.5
  • Power — 12-24V DC input; 12V/1.58A consumption with Celeron and 8GB
  • Operating temperatures — 0 to 60°C with humidity resistance
  • Dimensions — 147 x 102mm (“3.5-inch form factor”)
The IB822 is available now at an undisclosed price. More information may be found in Ibase’s IB822 announcement and product page.
1.41″ 320×360 AMOLED Full Color Display Panel With In-cell Touch-MIPI
DM-OLEDC141-648 is a 1.41″ 320×360 AMOLED Full Color Display Panel With In-cell Touch-MIPI interface.
Main features
  • Active Matrix Full Color OLED
  • 1.41″  320×360 Pixels
  • Interface: MIPI
  • Drive IC: WT010
  • In-cell Touch
The AMOLED display is available from www.displaymodule.com for $18.95.
HTU21D the small digitial humidity sensor that is big on performance
The HTU21D Digitial Relative Humidity Sensor offers high quality, high efficient low-cost solutions for OEM applications. Created for high volume cost sensitive applications, each sensor is individually calibrated and tested to ensure that quality measurement is paramount across your whole product offering.
With a 3x3mm by 1mm height footprint, they are embedded in a reflow Dual Flat No leads package, making them ideal where space constraints are a big factor.
Direct interface with a microcontroller is made possible with the module humidity and temperature digital outputs, calibrated linearised signals are provided in a digital I²C format.
See how these sensors react to continual use within a dynamic environment in the video below.
The application potential for the HTU21D sensors are vast, common association to Automotive, Medical, HVAC, Printing and Weather Monitoring are apparent but also home appliance and engine and vehicle management systems benefit from this highly versatile sensor.
To help bring your an application to life there are a number of sensor development kits for the HTU21D. … read more
easySwitchBox – The long-range LoRa® wall switch
easySwitchBox by easySensors is a long-range LoRa® wall switch powered by coin cells and the Arduino IDE. easySwitchBox enables you to remote control your appliances from long distance as easy as the push a a button.
The easySwitchBox does one simple thing – it sends on\off signals to any relay, actuator, or other project. It can be used to trigger any event wirelessly and from a distance (even up to a couple kilometers using LoRa®). It’s easy to program using the Arduino IDE, and communication is secured by an authentication chip. The easySwitchBox not only makes your project more effective, it also looks more professional.
Features & Specifications
  • IDE Control: Fully compatible with the Arduino IDE
    • Enumerates as an Arduino Pro Mini @ 8 MHz
    • Compatible with all RFM 69 \ 95 compatible open source libraries available
  • Radio Transceivers: Three transceiver options are available
    • HopeRF RFM95 LoRa® 433/868/915 MHz (long-range version)
    • HopeRF RFM69-HCW 433/868/915 MHz (mid-range version)
    • HopeRF RFM69-CW 433/868/915 MHz (low power consumption version)
  • Security: On-board Atmel/Microchip ATSHA204A crypto-authentication chip
    • Provides secured handshakes
  • Antennas: Tuned PCB antenna options that are soldered to the main board
    • 915 MHz – United States, Canada, Australia
    • 868 MHz – Europe
    • 433 MHz – Europe
  • Interface: Long-run soft-touch buttons similar to high-quality home switches
    • Each button has a built-in LED for message delivery confirmation
  • Power: Utilizes two CR2032 coin cell batteries
    • On-board coin cell holders
    • Reverse polarity protection
    • High-efficiency power converter
    • Batteries can last as long as two years with daily use
  • Mounting: Two options are provided for mounting
    • Pre-applied adhesive tape on the back
    • Screws through holes in the back plate
  • Open Source Hardware: For all your hacking desires
Nano Radio Shield
Some easySwitchBox kits ship with an Arduino Nano radio shield that allows you to easily receive signals from easySwitchBox using an Arduino Nano. This shield:
  • Will come with the same radio configuration as the easySwitchBox you order (RFM69-CW/HCW, RFM95)
  • Allows jumper wire access to all Nano pins, even with the Nano installed
  • Contains an Atmel/Microchip ATSHA204A crypto authentication chip (as does easySwitchBox)
  • Has an SMA connector for antenna (antenna is included)
  • Has an on-board 5 V to 3.3 V level converter for the radio and Flash
  • Features a microSD card slot
Quality and Versatility
RFM 95 has miles of coverage. RFM 69 is great for indoor use (for example: RFM69CW can easily cover large 5-story building). Since easySwitchBox is 100% compatible with Arduino IDE, anyone who loves Arduinos can use it in their projects. The easySwitchBox also comes with example code, to help get you started.
Finely-Tuned and Tested
Each easySwitchBox is tested and tuned while inside the enclosure and with a hand in front of it so that the resonance and Standing Wave Ratio (SWR) can account for these blockages.
Easy to Program
It has both open source hardware and software parts. The project is based on popular RFM 69/95 radios. There are lots of open source drivers and software available for RFM 433/868/915 MHz radios. It is easily programmable, using the popular ATmega328P, and is Arduino IDE compatible.
The project is live on CrowdSupply and has 22 days to go with pledges starting from 31 USD.
First dev-kits available for mosaic, Septentrio’s new high-precision GNSS module
mosaic is Septentrio’s most compact high-precision GPS/GNSS receiver module. This next-generation receiver is now available for trial with its newly released development kit.
Septentrio announces today that the mosaic development kit is available for testing and integration. mosaic is Septentrio’s most compact next-generation, high-precision multi-frequency GPS/GNSS module. This receiver brings precision and reliability of high-end multi-frequency GNSS to mass market applications. It is designed to fit into the assembly line process, which allows mosaic to be favorably priced for high volumes.
Its light weight and low power consumption helps extend battery life of robotic devices increasing operation time and efficiency. This makes mosaic ideal for applications such as robotics, automation, telematics and wearables.
“We see a growing demand for reliable high-precision positioning,” said Chris Lowet, Product Manager at Septentrio. “A few years ago, this demand was concentrated in professional applications, for example survey, high precision mapping and machine control. Today, with expansion of robotics, automation and IoT, a wide range of devices need high-precision positioning, from Ag robots to IoT gateways to autonomous vehicles. We designed mosaic to answer these market needs.”
Some of mosaic’s highlights include:
  • Centimeter positioning in tough environments with multi-frequency, multi-constellation GNSS technology
  • Best-in-class Advanced Interference Mitigation (AIM+) allows you to continue working despite radio interference from other electronic devices or jamming
  • Extensive corrections support for high-accuracy positioning: SBAS, PPP, SSR, RTK
  • RAIM+, integrity engine needed for safety-critical applications such as autonomous vehicles
  • Tracking all current and future GNSS satellite signals for enhanced RTK (Real-Time Kinematic) performance and guaranteed RTK network compatibility
  • 100 Hz update rate, ideal for robotics and fast-moving vehicles
The development kit assists Septentrio customers with integrating mosaic into their system. It supports connectivity through internet, COM ports, USB 2.0 as well as an SD Card slot. Would you like to try out mosaic in your system? Contact Septentrio to request your development kit here.
Photoacoustic spectroscopy (PAS) miniaturizes CO2 sensor XENSIV™ PAS210
City dwellers often spend a large amount of their time indoors, either in an office, at school, or simply at home. Urbanized spaces, however, tend to trap and develop bad air quality as they get more insulated for energy efficiency purposes. The concentration of CO 2 is an indicator for bad air quality. Today´s market solutions for monitoring this odorless and colorless gas are bulky and costly or simply not good enough for a widespread adoption. Infineon Technologies AG (FSE: IFX / OTCQX: IFNNY) has developed a disruptive CO 2 sensor technology based on the photoacoustic spectroscopy (PAS).
XENSIV™ PAS210 makes use of this new technology. It implements a high sensitivity MEMS microphone as a detector and enables significant miniaturization of CO 2 sensors. For this reason, it is ideal for smart home applications and building automation i.e. demand controlled ventilation, as well as various indoor air quality IoT devices such as air purifiers, thermostats, weather stations, and personal assistants. The sensor helps to improve the indoor air quality in a timely and energy efficient manner. Based on an extensive portfolio of patents around the PAS technology, PAS210 will not only enable high volume and cost sensitive CO 2 sensing applications but will also pave the road for the detection of other gases in the future.
On a single PCB, the CO 2 sensor integrates the photoacoustic transducer including the detector, the infrared source and the optical filter. It also holds a microcontroller for signal processing and algorithms as well as a MOSFET to drive an infrared source. All the components are developed and designed in-house according to Infineon´s high quality standards, leading to the best-in-class price/performance. For instance, XENSIV PAS210 uses the high SNR (Signal-to-Noise Ratio) MEMS microphone XENSIVE IM69D130 as a detector. The sensor thus benefits from Infineon´s long record of accomplishments in acoustic technology and related applications.
PAS210 is a real CO 2 sensor in an unprecedented small form factor, enabled by the unique PAS detection principle. The sensor saves more than 75 percent space in customer end products compared to commercially available real CO 2 sensors. Its direct ppm readings, surface mounting capability and simple design allow for an easy and fast integration in low and high volume applications alike.
The integrated microcontroller converts the MEMS microphone output into a ppm reading, which is available either via the serial I²C, UART or PWM interface. XENSIV PAS210 CO 2 measurement capabilities cover a range from 0 ppm to 10,000 ppm with an accuracy of ± 30 ppm or ±3 percent of the reading. In a pulsed mode, the XENSIV PAS210 CO 2 sensor is designed to have a lifetime of ten years.
Availability
The XENSIV PAS210 CO 2 sensor will be showcased at Sensor+Test in Nuremberg and at Sensors Expo in San Jose (California), USA. Early samples are being validated in selected targeted applications. Engineering samples are planned to be available in the first half of 2020, Infineon aims at starting the production in the second half of the same year. More information is available at www.infineon.com/PAS210.
X-FAB Introduces Highly-Sensitive SPAD and APD Devices Based on its Modular 180nm Process Technology
X-FAB Silicon Foundries, the leading analog/mixed-signal and specialty foundry, continues to develop ground-breaking semiconductor solutions to address the most difficult of design challenges. It has now announced the availability of avalanche photodiode (APD) and single-photon avalanche diode (SPAD) products for implementation in scenarios where there are extremely low light conditions to contend with and augmented sensitivity is required, as well as tight timing resolutions involved.
Based on the company’s popular 180nm high-voltage XH018 (https://www.xfab.com/technology/cmos/018-um-xh018/) process, these function block devices deliver a combination of elevated performance parameters and straightforward integration. The APD has a strong linear gain figure, and is fully scalable – going from just ten to several hundred micrometer dimensions. The proprietary X-FAB quenching circuit used in the SPAD results in a dead time of less than 15ns – thereby supporting high bandwidth. In addition, its low dark count rate (<100 counts/s/µm²) means that it is far less susceptible to thermal noise. The high photon detection probability (PDP) of the SPAD ensures that a much higher proportion of incident photons trigger an avalanche, and this is maintained across an extensive range of wavelengths (e.g. 40% at 400nm).
The X-FAB APD and SPAD can be utilized in a broad spectrum of different applications – including proximity sensing, LiDAR, time of flight (ToF), medical imaging (CT and PET) and scientific research. Being AEC-Q100 compliant, they are suitable for deployment within automotive systems. Furthermore, the low breakdown voltage (<20V) that has been achieved facilitates their incorporation onto customer dies. As integral parts of the X-FAB design kit, they are fully characterized, and can easily be combined with other modules featured in the XH018 process. Models for optical and electrical simulation, along with a specific application note, will help designers to integrate these devices into their circuitry within a short time period. As well as being supplied in a function block format, a quenching reference circuit that fully demonstrates the capabilities of the SPAD is also available.
Members of the X-FAB team will be able to discuss the new APD and SPAD products when the company exhibits at Sensors Expo (Booth #546, McEnery Convention Center, San Jose, 25th-27th June). https://www.sensorsexpo.com
Teledyne e2v’s Emerald 67M, high-resolution image sensor
Teledyne e2v, a Teledyne Technologies company and global innovator of imaging solutions, and TowerJazz, the global specialty foundry leader, announces that Teledyne e2v’s Emerald 67M image sensor, designed for ultra-high resolution electronics inspection, high-end surveillance and microscopy is now available.
The sensor is a member of Teledyne e2v’s Emerald family and features TowerJazz’s smallest in the world 2.5µm low-noise global shutter pixel, on TowerJazz’s 65nm platform, in its Uozu, 300mm Japanese manufacturing facility.  The pixel is integrated with a unique light pipe technology, offering superb angular response, more than 80dB shutter efficiency, in a significantly small size, and extremely low noise (one electron).  This unique pixel architecture provides cutting edge performance that enables improved manufacturing yields, through detection of smaller defects.
The Emerald family of sensors, solely manufactured by TowerJazz, provides customers with an unprecedented set of features and are all suitable for high-speed interface systems including 10GigE, CoaXPress, Camera Link, and Camera Link HS.  Special features include HDR modes with up to 120dB dynamic range and also a unique Region Of Interest (ROI) mode which allows multiple ROI to be captured under different exposure conditions, further improving the dynamic range of an image.
Emerald 67M has a square shape with 8k resolution per side, enabling 95% utilisation of the image area for the next generation of display manufacturing, gen 10.5. The ultra-high resolution optimizes vision system movements in large product inspection, reducing system complexity and removing instabilities. It is available in two different speed grades (ultra-high speed, 60fps and high speed, 30fps).
Rafael Romay, Vice President of Professional Imaging at Teledyne e2v, said “The Emerald 67M is the first sensor of its kind and is enjoying strong interest in inspection applications due to its ultra-high resolution and fast speed. It also shares many of the smart features within other Emerald sensors making it easier to deploy within vision systems. The great technology innovation and support from TowerJazz allowed us to bring to market this best-in-class solution, customized to product and application needs.”
Dr. Avi Strum, TowerJazz Senior Vice President and General Manager of the Sensor Business Unit said, “Teledyne e2v’s design and supply chain along with TowerJazz’s state of the art 65nm process have again brought a game changing sensor to machine vision applications. We are proud to have developed this together and look forward to further collaboration with Teledyne e2v to serve the machine vision market.”
For sample and evaluation kit requests or more information visit the product webpage. You can also see a live demo of the sensor at the Image Sensing Show 2019, 12-14 June in Yokohama, Japan. You can find us exhibiting with our partner, the IPN Corporation, on booth 19.
For more information about TowerJazz’s CMOS image sensor technology offering, please visit here.
MYIR MYC-JX8MX Module supports Linux on i.MX8M COM
MYIR has launched its first board based on one of NXP’s high performance i.MX8 processors. The 30 to 80°C tolerant “MYC-JX8MX CPU Module” runs Linux on a quad -A53 i.MX8M with 1GB or 2GB LPDDR4 and 8GB eMMC, with a “MYD-JX8MX” dev board adding 5x USB 3.0 plus mini-PCIe and PCIe x4 for NVMe. The $99 upward 82 x 52mm MYC-JX8MX CPU Module features i.MX8M COM, and connects via a 314-pin MXM 3.0 edge finger to the $279 MYD-JX8MX dev board. The module is designed for applications like scanning/imaging, building automation, and smart home, HMI, and machine vision.
MYIR has released several embedded modules and SBCs that features NXP’s low-power, Cortex-A7 based i.MX6 UL and i.MX6 ULL, like the MYC-Y6ULX module and MYD-Y6ULX-HMI dev board. The MYC-JX8MX CPU Module accompanies several sandwich-style i.MX8M offerings like Phytec’s phyCORE-i.MX 8M, phyBoard-Polaris SBC and Google’s AI-enabled Coral SOM and Coral Dev Board. The module features a Yocto Project-based stack with Linux 4.9.88 on the quad-core version of the Cortex-A53 based i.MX8M, which is clocked to 1.3GHz. The i.MX8M also includes a Vivante GC7000Lite GPU and VPU and a 266MHz Cortex-M4 MCU. Powering at 5V/0.5A, the MYC-JX8MX CPU Module enables 1GB or 2GB LPDDR4, 8GB eMMC, and 256Mb QSPI flash. Available also is a Gigabit Ethernet PHY and a PMIC on board.
The MXM 3.0 connector manifests the wide array of industrial and media interfaces obtainable on the general-purpose i.MX8M, of which many are available on the optional MYD-JX8MX development board. The MYD-JX8MX dev board is equipped with a microSD slot, GbE port, 4x USB 3.0 host ports, and a USB 3.0 Type-C host/device port. The dev board offers a wireless module with 802.11 a/b/g/n/ac 2×2 MIMO and Bluetooth 4.2 support,  with dual antenna mounts. A 4G LTE module can be incorporated using the single USB-based mini-PCIe interface and SIM slot, with also a PCIe 3.0 x4 interface that supports NVMe SSDs. Display feature includes an HDMI 2.0a port with 4096 x 2160 @ 60Hz video,  plus an HD ready MIPI-DSI interface and dual LVDS connectors. Available also is a capacitive touchscreen interface with backlight support.
MYD-JX8MX dev board detail view
Additional media features include dual audio jack and 2x 4-lane MIPI-CSI interfaces alongside an optional, 5-megapixel MY-CAM003M camera which sells for $29. The 12V/3A, 180 x 110mm “MYD-JX8MX” dev board is equipped with dual RS232 and single serial debug connectors and also 40- and 30-pin expansion connectors. It is further equipped with an RTC with battery holder plus LEDs and reset user and power buttons.
The module and dev board ships with extensive documentation, but they seem not to ship with schematics like MYIR’s Rico and Z-turn SBCs. The MYC-JX8MX CPU Module is available at $99 for 1GB or $119 for 2GB, and the MYD-JX8MX development board with module goes is available at $279 for 1GB or $299 for 2GB.
More information can be found on MYIR’s MYC-JX8MX announcement and product page and MYD-JX8MX product page.
PHILIPS Projection launches a new PicoPix Collection for nomads
Philips Projection design and manufacture pico projectors and home cine projectors for the mainstream market. As part of its strategy to extend and renew the current PicoPix portable devices, Philips Projection is unleashing the brand new PicoPix Collection. The collection is composed of 2 new micro DLP projectors bringing vivid images, wireless connectivity and a battery, packed in a pocket friendly design, accentuated by a black ceramic glossy effect, made for a touch of elegance. The new PicoPix Collection, along with NeoPix and Screeneo, bring Philips Projection with the widest projection range in the market.
PicoPix Nano: Pico Size, Mobile Experience!
Smaller than your phone, smaller than your Bluetooth speaker, smaller than ANY projector on the market! Meet our PicoPix Nano, the tinniest plug and play projector featuring Wireless connection and Multi Media Player. Ideal for ultra-nomads, the PicoPix Nano is equipped with a battery and the latest TI DLP LED to project up to 80mins of your sporting feats. Shot videos or pictures on your action cam and directly watch it on a 60” screen thanks to the microSD card reader. Got content in your smartphone, laptop or tablet and want to share it? The PicoPix Nano has a wireless mirroring function to display movies, pictures, office documents or streaming content.The mighty design is accentuated by a black ceramic glossy effect, made for a touch of elegance.
PicoPix Micro: Pico Size, Mobile Experience!
PicoPix Micro is smarter and brighter. With 150 Color Lumens, WVGA resolution and a weight of 225g, PicoPix Micro is the powerful and pocket companion to share your content. The upgraded Wi-Fi chip will smoothly connect to any devices and share videos & pictures straight away thanks to wireless screen mirroring. PicoPix Micro now offers a built-in multimedia player to play any content from the USB port. Its HDMI connectivity offers you the possibility to connect notebooks, game consoles, or any other HDMI output devices. With its built-in speaker and battery, feel free to project when you want and wherever you are. The mighty design is accentuated by a black ceramic glossy effect, made for a touch of elegance.
Press release distributed by Pressat on behalf of Philips Projection, on Monday 17 June, 2019. For more information subscribe and follow http://www.pressat.co.uk/
TOP PCB Companies
