The project presented here is suitable for all types of resistive, inductive, and capacitive loads, and can also be used to drive LEDs. The board is built using 2 xVN5025AJ chips which are monolithic devices made using STMicroelectronics VIPower technology. It is intended for driving resistive or inductive loads with one side connected to the ground. Active VCC pin voltage clamp protects the device against low energy spikes. This device integrates an analog current sense which delivers a current proportional to the load current (according to a known ratio) when CS_DIS is driven low or left open. When CS_DIS is driven high, the CURRENT SENSE pin is in a high impedance condition. Output current limitation protects the device in overload conditions. In case of long overload duration, the device limits the dissipated power to a safe level up to thermal shut-down intervention. Thermal shut-down with automatic restart allows the device to recover normal operation as soon as the fault condition disappears.
Power Supply 4.5V to 30V (Up to 36V Limited by Capacitor Voltage)
Load Current Up to 10 Amps Per Channel (Peak Current 41A)
Current Sense Voltage Output 0.5V/Amp
Under Voltage Threshold 3.5V
Turn On Delay 30 micro-Seconds (4.3Ohms Load)
Turn OFF Delay 50 micro-Seconds (4.3Ohms Load)
Temperature Shutdown Threshold 175 Degree Centigrade
Inrush current active management by power limitation
Very low standby current
0V CMOS-compatible input
Optimized electromagnetic emission
Very low electromagnetic susceptibility
In compliance with the 2002/95/EC European directive
PCB Dimensions 41.91 x 38.58 mm
4 x 3 mm mounting holes
Diagnostic functions
Proportional load current sense
High current sense precision for wide range currents
This is a breakout board for UCC28019 and UCC28128 PFC controllers. This module enables users to build a high-power PFC (Power Factor Correction) controller. Active PFC uses the boost topology operating in Continuous Conduction Mode (CCM). The controller is suitable for systems in the 100 W to >2 kW range over a wide-range universal ac line input. The startup current during an under-voltage lockout is less than 200 µA. The user can control low-power standby mode by pulling the VSENSE pin below 0.77 V. Low-distortion wave-shaping of the input current using average current mode control is achieved without input line sensing, reducing the Bill of Materials component count. Simple external networks allow for flexible compensation of the current and voltage control loops. The switching frequency is internally fixed and trimmed to better than 5% accuracy at 25°C. Fast 1.5-A gate peak current drives the external switch.
Numerous system-level protection features include peak current limit, soft over-current detection, open-loop detection, input brown-out detection, output over-voltage protection/under-voltage detection, a no-power discharge path on VCOMP, and overload protection on ICOMP. Soft-Start limits boost current during start-up. A trimmed internal reference provides accurate protection thresholds and regulation set-point. An internal clamp limits the gate drive voltage to 12.5 V.
This is a compact high-power stepper motor driver built for bipolar stepper motors. The driver can be controlled using a serial communication interface (SPI). It combines a flexible ramp generator for automatic target positioning with the industry’s most advanced stepper motor driver. Using external transistors, the driver ensures absolutely noiseless operation combined with maximum efficiency and the best motor torque. High integration, high energy efficiency, and a small form factor enable miniaturized. The complete solution reduces the learning curve to a minimum while giving the best performance in class. The project has the option to interface an external incremental encoder for easy control of position and step-loss operations.
Note 1: Refer to the datasheet of TMC5160 to understand the SPI interface and control system.
Note 2: This board only works with serial-SPI mode, it doesn’t support standalone mode.
Power Supply Motor 9 to 36V DC
2.8A Continues Current (3.1A Peak)
Configuration & Control via SPI
S/D mode selectable via solder option
Header Connectors for All signal Inputs
Screw Terminal Connectors for Power Supply and Easy Motor Connections
Low Ohmic MOSFETS for High Efficiency and Low Heat
On Board Power LED
Encoder Interface and 2xRef-Switch Input
Highest Resolution 256 Microsteps Per Full Step
Step/Dir Interface with microstep interpolation MicroPlyer™
Motion Controller with SixPoint™ramp
StealthChop2™ for quiet operation and smooth motion
Resonance Dampening for mid-range resonances
SpreadCycle™ highly dynamic motor control chopper
DcStep™ load-dependent speed control
StallGuard2™ high precision Sensorless motor load detection
CoolStep™ current control for energy savings up to 75%
P5: Pin 1 = Encoder A, Pin 2 = Encoder B, Pin 3 = Encoder N
P6: Pin 1 = GND, Pin 2 = Motor Supply + 9V to 36V DC
P9: Pin 1 = Motor B2, Pin 2 = Motor B1, Pin 3 = Motor A2, Pin 4 = Motor A1
D1: VCC Power LED
Mode of Operation
MODE 1: Full Featured Motion Controller & Driver
All stepper motor logic is completely within the TMC5160. No software is required to control the motor – just provide target positions. Enable this mode by tying low pin SD_MODE. Install Resistor R2 0 Ohms to select this mode. Do not install R1.
MODE 2: Step & Direction Driver
An external high-performance S-ramp motion controller like the TMC4361 or a central CPU generates step & direction signals synchronized to other components like additional motors within the system. The TMC5160 takes care of intelligent current and mode control and delivers feedback on the state of the motor. The Micro Plyer automatically smoothens motion. Tie SD_MODE high. Install Resistor R1 0 Ohms to select this mode. Do not install R2.
Mode Selection
Soldering R2 / not R1 = Internal ramp generator active with Trinamic’s 6-point-ramp (default mode)
Soldering R1 / not R2 = Step/Direction interface active for use with external motion controller (STEP =REFL, DIR = REFR)
Automatic Standstill Power Down
An automatic current reduction drastically reduces application power dissipation and cooling requirements. Modify stand still current, delay time and decay via register settings. Automatic freewheeling and passive motor braking are provided as an option for stand still. Passive braking reduces motor standstill power consumption to zero, while still providing effective dampening and braking! An option for faster detection of standstill is provided for both, ramp generator and STEP/DIR operation.
Encoder Interface
TMC5160 board provides an encoder interface for external incremental encoders. The encoder allows automatic checking for step loss and can be used for homing of the motion controller (alternatively to reference switches), or for software-controlled correction of step-loss or position stabilization. Its programmable pre-scaler allows the adaptation of the encoder resolution to the motor resolution. A 32-bit encoder counter is provided.
Key Concepts
The TMC5160 board implements advanced features which are exclusive to TRINAMIC products. These features contribute toward greater precision, greater energy efficiency, higher reliability, smoother motion, and cooler operation in many stepper motor applications.
StealthChop2™ No-noise, high-precision chopper algorithm for inaudible motion and inaudible standstill of the motor. Allows faster motor acceleration and deceleration than StealthChop™ and extends StealthChop to low stand still motor currents.
SpreadCycle™ High-precision chopper algorithm for highly dynamic motion and absolutely clean current wave. Low noise, low resonance, and low vibration chopper.
DcStep™ Load dependent speed control. The motor moves as fast as possible and never loses a step.
StallGuard2™ Sensorless stall detection and mechanical load measurement. CoolStep™ Load-adaptive current control reducing energy consumption by as much as 75%.
MicroPlyer™ Microstep interpolator for obtaining full 256 microstep smoothness with lower resolution step inputs starting from fullstep
In addition to these performance enhancements, TRINAMIC motor drivers offer safeguards to detect and protect against shorted outputs, output open circuit, overtemperature, and undervoltage conditions for enhancing safety and recovery from equipment malfunctions.
Control Interfaces
The TMC5160 board supports both, an SPI interface and a UART based single wire interface with CRC checking. Additionally, a standalone mode is provided for pure STEP/DIR operation without use of the serial interface. Selection of the actual interface is done via the configuration pins SPI_MODE and SD_MODE, which can be hardwired to GND or VCC_IO depending on the desired interface.
SPI Interface
The SPI interface is a bit-serial interface synchronous to a bus clock. For every bit sent from the bus master to the bus node another bit is sent simultaneously from the node to the master. Communication between an SPI master and the TMC5160 node always consists of sending one 40-bit command word and receiving one 40-bit status word.
The TMC5160 scores with complete motion controlling features, powerful external MOSFET driver stages, and high-quality current regulation. It offers a versatility that covers a wide spectrum of applications from battery powered high efficiency systems up to embedded applications with 10A or more motor current per coil. The TMC5160 contains the complete intelligence which is required to drive a motor. Receiving target positions, the TMC5160 manages motor movement. Based on TRINAMICs unique features StallGuard2, Cool Step, DC Step, Spread Cycle, and Stealth Chop, it optimizes drive performance. It trades off velocity vs. motor torque, optimizes energy efficiency, smoothness of the drive, and noiselessness. The small form factor of the TMC5160 keeps costs down and allows for miniaturized layouts. Extensive support at the chip, board, and software levels enables rapid design cycles and fast time-to-market with competitive products. High energy efficiency and reliability deliver cost savings in related systems such as power supplies and cooling.
The project presented here is an Arduino-compatible motor control board. The board consists of an ATMEGA328 microcontroller, LMD18201 H-Bridge, and 2 x potentiometers. This closed-loop servo system provides position control using a feedback potentiometer mounted on the output shaft of the gearbox and provides position control by turning the shaft of the reference potentiometer, the motor-gearbox output shaft follows the reference potentiometer. The project can also be used in other applications that require Arduino-compatible hardware and H-Bridge.
The project requires a special mechanism, where the DC motor’s output shaft is mechanically coupled with the potentiometer shaft using a reduction gear. Approx. reduction ratio 15-50: 1. When the reference pot is turned, the motor shaft follows the position. This will provide a maximum rotation of 270 degrees. Multi-rotation is possible with the help of a multiturn potentiometer.
Arduino Code
Arduino example code is available and the board can be programmed using the CN2 connector, the same connector helps burn the boot-loader to a new ATMEGA328 chip.
This is a Self-oscillating full-bridge project built using the IRS2453 chip. This chip incorporates a high-voltage full-bridge gate driver with a front-end oscillator similar to the industry standard CMOS 555 timer. HVIC and latch-immune CMOS technologies enable ruggedized monolithic construction. The output driver features a high pulse current buffer stage designed for minimum driver cross-conduction. Noise immunity is achieved with a low di/dt peak of the gate drivers and with an under-voltage lockout hysteresis greater than 1.5 V. The IRS2453(1)D also includes latched and non-latched shutdown pins.
Load Supply voltage: 90V DC, this is limited due to capacitor voltage C1, C2, and MOSFETs Q1-Q4. The board can support DC supply up to 600V, choose appropriate capacitors and MOSFETs.
Oscillator: Refer to the figure below to choose the right value of C7 and R3 to program the oscillating frequency.
Heatsink: Heatsink and Fan are a must for MOSFETs and to dissipate heat.
Power Supply Gate Driver 12V to 15V DC
Power Supply 90V Limited by DC Capacitors and MOSFETS (Up to 600V Change Capacitor C1 and C2)
Frequency 68Khz, Oscillator frequency can be programmed using CT, RT (C7 and R3)
Load Current Up to 5Amps
Duty Cycle 50%
Micropower Startup
Internal Dead Time 1uS
4 x 4 MM Mounting Holes
PCB Dimensions 69.22 x 58.90 mm
Application
Wireless Charger
Low Power DC to AC Inverter
Tesla Coil
Induction Heater
Under-Voltage Lock-Out Mode (UVLO)
The under-voltage lockout mode (UVLO) is defined as the state the IC is in when VCC is below the turn-on threshold of the IC. The IRS2453(1)D under-voltage lock-out is designed to maintain an ultra-low supply current of e the high and low side output drivers are activated. During under-voltage lock-out mode, the high and low side driver outputs LO1, LO2, HO1, HO2 are all low. With VCC above the VCCUV+ threshold, the IC turns on and the output begin to oscillate.
Normal Operating Mode
Once VCC reaches the start-up threshold VCCUV+, the MOSFET M1 opens, RT increases to approximately VCC (VCC-VRT+) and the external CT capacitor starts charging. Once the CT voltage reaches VCT- (about 1/3 of VCC), established by an internal resistor ladder, LO1 and HO2 turn on with a delay equivalent to the dead time (td). Once the CT voltage reaches VCT+ (approximately 2/3 of VCC), LO1 and HO2 go low, RT goes down to approximately ground (VRT-), the CT capacitor starts discharging and the dead time circuit is activated. At the end of the dead time, LO2 and HO1 go high. Once the CT voltage reaches VCT- , LO2 and HO1 go low, RT goes to high again, the dead time is activated. At the end of the dead time, LO1 and HO2 go high and the cycle starts over again. The frequency is best determined by the graph, Frequency vs. RT, shown below, for different values of CT.
A first-order approximation of the oscillator frequency can also be calculated by the following formula:
f » 1/1.453 x RT x CT
This equation can vary slightly from actual measurements due to internal comparator over- and under-shoot delays
Bootstrap MOSFET The internal bootstrap FET and supply capacitor (CBOOT) comprise the supply voltage for the high-side driver circuitry. The internal bootstrap FET only turns on when the corresponding LO is high. To guarantee that the highside supply is charged up before the first pulse on HO1 and HO2, LO1 and LO2 outputs are both high when CT ramps between zero and 1/3*VCC. LO1 and LO2 are also high when CT is grounded below 1/6*VCC to ensure that the bootstrap capacitor is charged when CT is brought back over 1/3*VCC.
This is an Arduino-compatible hardware designed for building a low-cost function generator. The project consists of all the required spices to build your own function generator. It includes multiple options such as a potentiometer, rotary encoder, tactile switches, op-amp, and 16×2 LCD interface. The project can output sine, triangular, and square waves with gain adjustment and offset adjustment. The board works with a 5V single power supply.
Key Features
Atmega328 TQPF microcontroller for Arduino IDE
16×2 LCD Parallel Interface Can be used to display Function Generator Menu
Connector for I2C LCD Interface (Connector CN2)
AD9833, DDS Function Generator Chip
Dual Supply for Op-Amp Circuit to Increase Low Output Signal of AD9833 DDS Function Generator
Potentiometer to Adjust the Gain of the Op-Amp
Potentiometer On Analog Pin A0 (Can be used to Adjust the Frequency)
Tactile Switch SW2 Connected Arduino A0 with an optional pull-up resistor
Tactile Switch SW2 Connected Arduino D12 with an optional pull-up resistor
Jumper J1 Arduino A3 Pin, with optional Pull Up Resistor
Jumper J2 Arduino A2 Pin, with optional Pull Up Resistor
Rotary Encoder U1 with Tactile Switch
LED D2 Connected to Arduino D12
Connector CN4 Dual Power Supply input for Op-amp, in case U1 MAX680 is not used
Jumper J3, AD9833 Direct Output or Op-Amp Output Selection
Trimmer Potentiometer PR4 to Adjust the Op-Amp Offset (Zero), DC Level Adjust
Power Supply 5V DC @ 120mA
Optional Dual Supply Input for High Voltage Output Swing
Output Sine, Triangular, and Square Wave
Output Frequency Up to 12Mhz
On Board Rotary Encoder for Menu and Frequency Control
Gain and Offset Adjust Potentiometer
On Board Parallel 16X2 LCD and I2C LCD Option
LCD Contrast Adjust Trimmer Potentiometer
BNC Connector for Output
PCB Dimensions 80.01 x 55.88mm
4 x 3MM Mounting Holes for LCD
DC-DC Converter 5V Single Supply to Dual Output +/-10V Output
U1 MAX680 is a single supply to Dual supply converter. This chip provides a symmetric power supply +/-10V to OPAMP U4. A dual supply is required for Sine-Wave output, in the case of higher voltage output, use external dual power supply input through CN4, in this case, don’t install U1 Max680, capacitor C4, and capacitor C1.
OPAMP
The sine-Wave and Tringle-Wave outputs of AD9833 are very low and need amplification, U4 op-amp is provided to amplify the output of AD9833. This Op-Amp requires a dual supply. Output offset can be adjusted using PR4 trimmer potentiometer and gain adjust using potentiometer PR3. 1 to 20, Maximum output swing +/-7V, for higher voltage swing use external dual power supply for the op-amp, in this case, don’t install U1 MAX680.
AD9833
The AD9833 is a low-power, programmable waveform generator capable of producing sine, triangular, and square wave outputs. Waveform generation is required in various types of sensing, actuation, and time domain reflectometry (TDR) applications. The output frequency and phase are software-programmable, allowing easy tuning. No external components are needed. The frequency registers are 28 bits wide: with a 25 MHz clock rate, a resolution of 0.1 Hz can be achieved; with a 1 MHz clock rate, the AD9833 can be tuned to 0.004 Hz resolution.
The AD9833 is written via a 3-wire serial interface. This serial interface operates at clock rates up to 40 MHz and is compatible with DSP and microcontroller standards. The device operates with a power supply from 2.3 V to 5.5 V. The AD9833 has a power-down function (SLEEP). This function allows sections of the device that are not being used to be powered down, thus minimizing the current consumption of the part. For example, the DAC can be powered down when a clock output is being generated.
ATMEGA328 Programming
AVR micro-controller used to make the project Arduino compatible, all pin details are provided in schematics, a new chip can be programmed using Arduino IDE, Connector CN3 is provided to boot-loader and Arduino programming for the ATMEGA328. Refer to diagrams below.
16×2 LCD Parallel Connections
The 16×2 LCD can be directly connected and installed on board using 4 Screws with the help of studs. The male header on the main board and female header on LCD provides an easy interface and LCD seats directly on the board. Trimmer PR2 can be used to adjust the contrast of LCD, LCD backlight is powered through current limiting resistor R5.
I2C serial LCD or OLED
I2C Serial LCD or OLED display can be connected to CN2 connector.
Connections and other details
CN1: 3 Pin Male Header Connected to A1 pin of Arduino Pin 1 = VCC, Pin 2 = A1, Pin 3 = GND
CN4: Dual Power Supply Input for Op-Amp U4 optional, in case external power supply input (Do Not use MAX680 U4) If the board is powered from an external source
PR1: On Board Potentiometer Connected to Arduino Analog A3
This is a very precise Electronic Load project built using the ultra-Precision, Low-Noise OPAMP MAX44251 from Analog Devices. The project can sink current from a power source. It can be used as test gear for power supplies, chargers, solar panels, batteries, and DC-DC converters. The resistor R11 acts as a shunt, OPAMPs convert current into voltage, 2nd op-amp, and Q1 MOSFET are used to control the load current. A Multi-turn potentiometer helps to adjust the load current in the range of 0 to 1A. The supply voltage is up to 60V DC. The board works with dual supply +/-15V DC and draws a few milli amps. LM317 regulator provides 12V DC top op-amp and LM337 provides regulated -7V supply to op-amp. At full load, MOSFET Q1 produces lots of heat, and a fan and large heatsink on MOSFET will help cool it down. Users may use a current meter in series to load to display the current. Optional onboard Trimmer potentiometer provided in case external potentiometer is not required.
Operating Power Supply Dual 15V DC (+/-15V DC)
Load Current 1Amp, Power Supply Up to 60V DC
Highly Efficient and Ultra-Precision Current Control
On-Board Power LED
Barrier Block Connector for Load connection
External Or On-Board Trimmer Potentiometer Option for Current Control
PCB dimensions: 66.52 x 33.66 mm
CN1: Pin 1 = +Load, Pin 2 = GND
CN2: Pin 1 = +15V DC Power Supply, Pin 2 = GND, Pin 3 = +15V Power Supply
D1: Power LED
PR1: Optional Trimmer Potentiometer (Do Not Use CN3 Potentiometer If this is used)
AAEON’s newest system targets the smart factory market with high-performance computing in a rugged fanless PC.
Leading provider of embedded PC solutions, AAEON, is delighted to announce the official launch of the BOXER-6406-ADN, a compact and fanless embedded computer built upon the Intel Atom® Processor X Series/Intel® Processor N-series Processor platform.
Designed to cater to the demands of smart factory applications, the BOXER-6406-ADN boasts a range of features that establish it as a remarkably robust choice for industrial projects. Notably, the system boasts an impressive operational temperature range spanning from -20°C to 60°C. Furthermore, it supports a wide voltage input range of 9V to 36V, inclusive of over/under-voltage current protection as well as short-circuit protection. To enhance its durability, the system is equipped with IEC 68-2-27 anti-shock tolerance and advanced anti-vibration capabilities. Lockable I/O connectors have also been incorporated to safeguard against wear and tear.
With dimensions measuring just 186mm x 104.6mm x 49.1mm, the BOXER-6406-ADN’s compact chassis can be easily wall-mounted for convenient deployment. The system relies solely on passive cooling mechanisms, foregoing fan-assisted cooling systems to prevent the accumulation of contaminants when deployed in smart factory settings.
The BOXER-6406-ADN is available in various SKUs, powered by the Intel® Processor N200, Intel® Processor N50, or the Intel Atom® x7211E. These selections were made due to their exceptional combination of power-efficiency and capable processing performance.
For system memory, the BOXER-6406-ADN offers 32GB of DDR5 running at 4800Mhz via SODIMM slot, which gives high-bandwidth data transmission to its collection of industrially conducive interfaces, such as DB-9 and DB-15 ports for RS-232/422/485 and digital I/O functions. On top of this, its I/O also includes two RJ-45 ports for Intel® I226-LM ethernet running at 2.5GbE, dual HDMI, and a total of four USB type-A ports (USB 3.2 Gen 2 x 2, USB 2.0 x 2).
Flexible storage is offered via a 2.5″ SATA drive and an M.2 2280 M-Key, with additional expansion supported by the presence of an M.2 2230 E-Key for Wi-Fi, as well as full-size Mini Card and SIM slots.
AAEON has affirmed that due to its rugged, compact, and fanless construction, coupled with an array of high-speed interfaces, the BOXER-6406-ADN is precisely tailored to the needs of the smart factory market. The company specifically highlights its suitability for applications such as automated guided vehicles (AGVs), edge gateways, and automated manufacturing.
MYIR has launched a new ARM SoM MYC-YM62X CPU Module based on AM62x (AM625/AM623), the latest Sitara processor from TI, equipped with quad/dual/single Arm Cortex-A53 core (up to 1.4GHz) and single Cortex-M4F core (400MHz). In addition to the AM62x MPU, the MYC-YM62X CPU Module has integrated 1GB/2GB DDR4, 8GB eMMC, 32Kbit EEPROM and PMIC. It carries out a variety of peripheral and IO signals through the 1.0 mm pitch 222-pin Castellated-Hole expansion interface including dual TSN-enabled Gigabit Ethernet ports, USB, MMC/SD, Camera interface, OSPI, CAN-FD and GPMC. It also takes advantage of the AM62x processor to support dual-display and 3D GPU (only for AM625). This makes it particularly suitable for Human-machine Interaction (HMI), Internet of Things (IoT) and Gateway applications.
MYC-YM62X CPU Module (MYC-YM6231 / MYC-YM6252 / MYC-YM6254)
The MYC-YM62X CPU Module measures only 43mm by 45mm. It is capable of running Linux and provided software resources including kernel and driver source code, together with detailed user manuals and documents to help customer start their development rapidly.
MYC-YM62X CPU Module Function Block Diagram
Features of MYC-YM62X CPU Module
Dimensions: 43mm x 45mm
PCB Layers: 10-layer design
Power supply: 5V/1A
Working temperature: -40~85 Celsius (industrial grade)
TI Sitara AM62x Processor (AM6254/AM6252/AM6231)
– TI AM6254: 4*[email protected] + Cortex-M4F@400MHz (AM6254ATCGGAALW)
– TI AM6252: 2*[email protected] + Cortex-M4F@400MHz (AM6252ATCGGAALW)
– TI AM6231: 1*[email protected] + Cortex-M4F@400MHz (AM6231ASGGGAALW)
– Two PRU-SS running up to 333MHz
– 3D GPU graphics accelerator (only for AM625 processors)1GB/2GB DDR4
8GB eMMC
32KB EEPROM
0mm pitch 222-pin stamp hole expansion interface
2 x RGMII
2 x USB2.0
9 x URAT
3 x CAN FD
6 x I2C
5 x SPI
1 x GPMC
2 x LVDS
1 x RGB
1 x MIPI CSI
3 x MCASP
1 x JTAG
Up to 143 x GPIOs
Linux OS
Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet and CPU Module pin-out description file.
The MYD-YM62X Development Board is a demo board for evaluating the MYC-YM62X CPU Module. It has a versatile base board to facilitate the expansion from the MYC-YM62X through the 222-pin expansion interface, a rich set of peripherals and interfaces have been brought out such as two RS485, two CAN, two USB 2.0 HOST and one USB 2.0 OTG, two Gigabit Ethernet, one M.2 Socket for USB based 4G/5G LTE Module with two SIM card holders, one Micro SD card slot, one SDIO based WIFI/BT module, one HDMI display interface, one dual-channel LVDS display interface, two single-channel LVDS interfaces, one MIPI CSI camera interface and one audio input/output interface, as well as one 30-pin extension header for GPMC. The MY-CAM003M MIPI Camera Module and MY-LVDS070C LCD Module can be used as options for the MYD-YM62X board which allows customers to acquire a better development experience.
MYD-YM62X Development Board Top-viewMYD-YM62X Development Board Bottom-viewMYD-YM62X Development Board Function Block Diagram
The MYC-YM62X CPU Module is provided with three standard configurations at cost-effective prices. The part MYC-YM6231-8E1D-100-I is pricing at only $29/pc. Discount is to be offered for volume quantities.
MYIR also provides OEM/ODM services to help customers accelerate their time to market and save costs.
Featuring 1 x16 PCIe Gen5 and up to 16 Performance-cores plus 8 Efficient-cores, the module is ideal for compute-intensive use cases such as test & measurement, medical imaging, and industrial AI
Summary:
The ADLINK COM-HPC-cRLS Client type Size C module based on 13th Gen Intel® Core™ processor is available for order with:
up to 13th Gen Intel® Core™ i9 processor, 16 Performance-cores, 8 Efficient-cores, and 32 threads
up to 128GB DDR5 SODIMM at 4000MT/s
and 36MB cache (6MB more than predecessors)
1 x16 PCIe Gen 5, 2x 2.5GbE LANs
Supporting Intel® TCC, and Time Sensitive Networking (TSN), COM-HPC-cRLS is well-suited for hard-real-time computing workloads required by applications such as industrial automation semiconductor equipment testing, and AI robots
ADLINK Technology Inc., a global leader in edge computing, announces the readily availability of one of its most sought-after Computer-on-Modules based on the latest, 13th Gen Intel® Core™ processors — The COM-HPC-cRLS, a COM-HPC Client type Size C module.
Utilizing Intel’s advanced hybrid architecture, with up to 16 Performance-cores plus 8 Efficient-cores and an increased cache of 36MB, the module demonstrates brilliant performance per watt along with AVX-512 VNNI and Intel® UHD AI inferencing support for realizing diverse edge AI and IoT use cases.
Available with up to 13th Gen Intel® Core™ i9 processor at 65W TDP, the COM-HPC-cRLS provides two 2.5GbE LANs and up to 128GB DDR5 SODIMM at 4000MT/s. Most importantly, it packs 1 x16 PCIe Gen5 lanes that can fulfill the same computing and transmission performance with fewer lanes than its predecessors, and with a bandwidth of up to 32GT/s, in driving next-gen compute-intensive edge innovations.
What’s more, the module offers Intel® TCC (Time-Coordinated Computing) and TSN (Time Sensitive Networking) support. TCC brings precise time synchronization and CPU/IO timeliness within a system, whereas TSN optimizes time precision for synchronized networking between multiple systems. With these two features working coincide with one another, COM-HPC-cRLS can be assured of the timely execution of deterministic, hard real-time workloads with ultra-low latency, making it well fitted for hard real-time computing workloads required by applications such as industrial automation, semiconductor equipment testing, AI robots, autonomous driving, and aviation.
All in all, the ADLINK COM-HPC-cRLS cannot only simplify developers’ application-specific carrier designs and reduce their time to market significantly with PCIe Gen5 but also caters to various future-proof edge AI use cases at all fronts
COM-HPC-cRLS
Up to 24 cores (16 P-cores + E-cores), 32 threads
16 PCIe Gen5 lanes, 8 PCIe Gen4 lanes
Up to 128GB DDR5 SO-DIMM at 4000 MT/s
2x 2.5GbE LANs
AI inferencing (AVX-512 VNNI, Intel® UHD)
ADLINK is also working to provide I-Pi development kits based on the ADLINK COM-HPC-cRLS module for on-the-spot prototyping and referencing.
For more information about the ADLINK COM-HPC-cRLS module, please follow the following link here at adlniktech.com: COM-HPC-cRLS (COM-HPC Client Type)
