Honeywell IPM Intelligent Particulate Matter Sensors
Honeywell IPM Intelligent Particulate Matter Sensors are laser-based sensors that detect and measure particle concentration using light scattering for monitoring air quality. The detection concentration range for Honeywell IPM is 0µg/m3 to 1000µg/m3. A laser light source illuminates a particle as it is pulled through the detection chamber. As particles pass through the laser beam, the light reflects off the particles and is recorded on the photo or light detector. The sensor then analyzes the light and converts it to an electrical signal to calculate particle concentration. During the production calibration, the sensor records the original laser light-intensity parameters and fan speed. The calibration algorithm is applied to the sensor output to minimize drift and improve the sensor’s lifetime accuracy. This self-calibration occurs on each power-on cycle.
  • Laser-based (class 1) particle light scattering particle sensing
  • 0µg/m3 to 1000µg/m3 concentration range
  • Detects 0.3µm to 10µm particles
  • Up to 8 years life with continuous operation
  • Factory calibrated
  • RoHS and REACH compliant
Applications
  • Air-quality monitors (indoors and outdoors)
  • Air purifiers (commercial and residential)
  • Automotive cabin air purifiers
  • HVAC (commercial and residential)
more information: https://sps.honeywell.com/us/en/products/advanced-sensing-technologies/healthcare-sensing/particulate-matter-sensors
Monolithic Power Systems (MPS) MP6651 Single-Phase BLDC Drivers
Monolithic Power Systems (MPS) MP6651 Single-Phase BLDC Drivers are highly advanced and versatile single-phase brushless DC (BLDC) motor drivers. The Monolithic Power Systems (MPS) MP6651 has integrated power MOSFETs and a Hall-effect sensor to deliver maximum performance and efficiency. The device also provides a high degree of control and flexibility. Capable of operating on input voltages ranging from 3.3V to 18V, the MP6651 is perfect for various applications.
  • On-chip hall sensor
  • Wide 3.3V to 18V operating input voltage (VIN) range
  • 2A continuous current with QFN-10 package
  • 1.5A continuous current with SOIC-8 SL package
  • Integrated power MOSFETs
  • Configurable starting duty cycle
  • Configurable min output duty cycle
  • Configurable soft-on/off commutating angle (max 45°)
  • Configurable hall offset angle (max ±45°)
  • 4-step configurable current limit
  • 2kHz to 100kHz PWM input range
  • 2.4s to 19.2s configurable soft-start time
  • Fixed 27kHz output switching frequency (fSW)
  • Rotor lock protection with auto-recovery
  • Thermal protection with auto-recovery
  • Built-in input OVP and UVLO with auto-recovery
  • Available in SOIC-8 SL and QFN-10 (2mm x 3mm) packages
Typical Application
more information: https://www.monolithicpower.com/en/mp6651.html
Nexperia NCA95xx I2C GPIO Expanders
Nexperia NCA95xx I2C General-Purpose I/O (GPIO) Expanders provide an elegant solution when additional I/Os are needed while keeping the interconnections to a minimum. Housed in TSSOP24 and HWQFN24, these GPIO expanders are equipped with multiple features Interrupt, Hardware RESET, Internal pull-up resistors, and configurable pull-ups. These Nexperia NCA95xx GPIO expanders feature benefits such as extremely low static power consumption and reduce the PCB design complexity through trace reduction and routing simplification, thereby reducing the BOM cost.
  • Single supply GPIO expander supporting operating power supply voltage range of 1.65V to 5.5V operation
  • Serial to parallel (SDA to P0-P16) and parallel to serial (P0-P16) conversion with I2C protocol
  • Schmitt-trigger action allows slow input transition and better switching noise immunity at the SCL and SDA inputs
  • Low power consumption of 2.5µA maximum
  • 400kHz operation (FM I2C mode)
  • Glitch-free power-up with all channels configured as inputs with weak pull-up resistors
  • 5V tolerant I/Os and 16 I/Os pins, which defaults to 16 inputs
  • Latched outputs with 25mA drive maximum capability for directly driving LEDs
  • Polarity inversion register
  • External RESET pin to reset state machine and internal registers
  • Noise filters on SCL and SDA inputs
  • TSSOP24 and HWQFN24 packages
  • Specified from -40°C to +85°C and -40°C to +125°C
more information: https://assets.nexperia.com/documents/user-manual/UM90013.pdf
Broadcom AEDR-9930E 3-Ch Reflective Optical Encoder
Broadcom AEDR-9930E 3-Channel Reflective Optical Encoder offers selectable and programmable options of digitally differential A, B, and I outputs. The AEDR-9930E digital encoder mode provides two-channel (AB) quadrature digital outputs and a third-channel digital index output.
The Broadcom AEDR-9930E encoder is TTL compatible with interfaced outputs for most signal processing circuitries. Therefore, the AEDR-9930E enables easy integration and flexible design-in into existing systems.
The device is developed to operate over a -40°C to +115°C temperature range and is ideal for commercial, industrial, and automotive end applications. The encoder encloses an LED light source and photo-detecting circuitry in a 5.00mm × 5.00mm  × 1.05mm (LxWxH) single package. The small size of the AEDR-9930E permits usage in a wide range of miniature commercial applications, where size and space are primary concerns.
  • Digital output option: three-channel differential or TTL compatible; two-channel quadrature (AB) digital outputs for direction sensing and a third channel, index digital output
  • Wide-selection built-in interpolator with 1x to 10x, 12x, 14x, 15x, 16x, 18x, 20x, 25x, 32x, 50x, 64x, 80x, 100x, 128x, 160x, 256x to 512x and other user-programmable interpolation factors
  • SPI programmable interpolator from 1x to 1024x
  • 5.0mm × 5.0mm × 1.05mm (LxWxH) surface-mount leadless package
  • Operating voltage of 3.3V and 5.0V supply
  • Built-in LED current regulation
  • Wide operating temperature range from -40°C to +115°C
  • High encoding resolution of 397LPI (lines per in.) or 15.63LPmm (lines per mm)
more information: https://www.broadcom.com/products/motion-control-encoders/incremental-encoders/reflective-encoders/aedr-9930
Silicon Photomultiplier is utilized for ultra-sensitive precision measurements of single photons
Broadcom AFBR-S4N66P014M NUV-MT Silicon Photomultiplier is utilized for ultra-sensitive precision measurements of single photons. The single-channel SiPM is based on the NUV-MT technology, which integrates improved photo-detection efficiency (PDE) with a decreased dark count rate and crosstalk compared to the NUV-HD technology. The device has a SPAD pitch of 40µm. By tiling multiple Broadcom AFBRS4N66P014M SiPMs, larger areas can be covered.
The Broadcom AFBR-S4N44P044M array encapsulates an epoxy clear mold compound for excellent mechanical stability and robustness. The epoxy is highly transparent down to UV wavelengths, resulting in a broad response in the visible light spectrum with high sensitivity toward the blue and near UV region.
The device is well suited for detecting low-level pulsed light sources, especially Cherenkov or scintillation light from the most common organic (plastic) and inorganic scintillator materials (for example, LSO, LYSO, BGO, NaI, CsI, BaF, or LaBr3).
  • 2×2 SiPM array
  • Array size of 8.26mm × 8.26mm
  • High PDE (63% at 420nm)
  • Excellent SPTR and CRT
  • Excellent uniformity of breakdown voltage
  • Excellent uniformity of gain
  • 4-side tileable, with high fill factors
  • 40μm cell pitch
  • Highly transparent epoxy protection layer
  • Operating temperature range from -20°C to +50°C
  • RoHS, CFM, and REACH compliant
M5Stack CoreS3 ESP32S3 loT Development Kit
M5Stack CoreS3 ESP32S3 loT Development Kit is based on ESP32-S3 solution, dual-core XTensa LX7 processor. This kit features 240MHz frequency, WiFi® at 16M flash, 8M PSRAM, built-in camera, proximity sensor, speaker, power indicator, I2S amplifier, dual microphone, and condenser touch screen. The CoreS3 kit supports OTG, CDC functions, and Arduino and UIFlow programming platforms. Typical applications include Internet of Things (IoT) development, various DIY project development, smart home control system, and industrial automation control system.
  • Developed based on ESP32, supports WiFi® at 16M flash, and 8M PSRAM
  • Built-in camera, proximity sensor, speaker, power indicator, RTC, I2S amplifier, dual microphone, and condenser touchscreen
  • Power button, reset button, and gyroscope
  • TF card slot
  • High-strength glass
  • Support OTG and CDC functions
  • AXP2101 power management and low power design
  • Arduino and UIFlow-supported programming platforms
Specifications
  • 2-inch at 320*240 ILI9342C touch the IPS LCD screen
  • GC0308 at 30 megapixels camera
  • LTR-553ALS-WA proximity sensors
  • 16bits-I2S power amplifier chip AW88298 at 1W
  • ES7210, dual microphone inputs audio decoding chip
more information: https://m5stack.com
Sequans Monarch Go Certified LTE IoT Category M1 Modems
Sequans Monarch Go Certified LTE IoT Category M1 Modems, connected by Verizon, are comprehensive modem components offering a short route to market and a low Total Cost of Ownership (TCO) to develop cellular-IoT connected devices. The Monarch Go Modems avoid costly lab testing while improving time-to-market thanks to a reduced effort for board design. These modems remove the need to design and tune a cellular antenna as it embeds an optimized LTE antenna, saving months of design effort and lab testing. The plug-and-go Monarch Go Modems feature a pre-installed ThingSpace IoT SIM and a default data plan.
The mechanical integration of the Monarch Go LTE-M modem component into IoT devices is extremely simple, requiring only two screws, a single low-profile board-to-board connector, and no soldering. Monarch Go includes an industry-standard UART interface, a set of AT commands, and examples for connecting your device application MCU controller.
  • LTE-M modem component with embedded antenna certified for use on the Verizon network
  • Optional embedded GPS
  • ThingSpace IoT SIM pre-installed
  • ThingSpace online management
  • Easy connection to cloud services from a third party and geolocation
  • Industry-leading network coverage in the USA
  • RoHS compliant
Specifications
  • Modem
    • Sequans Monarch™ LTE-M chip
    • Pre-installed ThingSpace IoT SIM
    • Certified for use on the Verizon network (LTE band 13) with a roadmap for global band support
    • Compatible with Linux, Windows, and a wide range of embedded and real-time operating systems
    • High-speed UART as data and AT command interface
    • Embedded IP stack with support for UDP, TCP, TFTP, FTP, HTTP, HTTPS, MQTT, or MQTTS
    • Location based services
    • SMS send and receive
    • Low power modes PSM, eDRX, and RRC IDLE
    • Support for Verizon FOTA services from the ThingSpace online management platform
    • LTE Cat M1: 375kbps uplink and 300kbps downlink (peak)
  • LTE-M data plan
  • GPS (Monarch Go-GPS)
    • Sensitivity
      • -162dBm tracking
      • -148dBm acquisition
    • Location update rate up to 1Hz
  • Electrical and RF
    • 3.1V to 5.5V regulated supply voltage range
    • Ultra-low power mode (PSM)
      • 1µA without GPS
      • 35µA with GPS
    • 1.8V UART interface
    • Maximum transmit power up to +23dBm, LTE band 13
    • Certified FCC compliant
  • Mechanical
    • 35mm x 50mm x 14.95mm (1.38″ x 1.97″ x 0.59″) in dimension
    • Plastic enclosure fixable with 2 screws
    • Shipped with ThingSpace SIM pre-installed
    • Embedded LTE antenna
    • Low profile 20-pin digital board-to-board connector to connect an application controller through the industry standard UART interface
    • LED for modem activity
    • LED for GPS activity (Monarch Go-GPS only)
    • 16g weight
  • Temperature ranges
    • -40°C to +80°C operating
    • -40°C to +85°C storage
more information: https://sequans.com/products/monarch/
Saelig Introduces Siglent SHA800A Portable Spectrum Range to 7.5GHz
Siglent SHA800A analyzers combine the capabilities of a Spectrum Analyzer, a Vector Network Analyzer, and a Cable/Antenna Tester all in one intuitive handheld package.  With a frequency range up to 7.5 GHz, these analyzers deliver reliable automatic measurements and multiple modes of operation.
Saelig Company, Inc. has introduced the SIGLENT SHA800A series, handheld portable spectrum analyzers which form a powerful, versatile choice for benchtop and field RF measurement applications. SHA800A analyzers combine the capabilities of a Spectrum Analyzer, a Vector Network Analyzer, and a Cable/Antenna Tester all in one intuitive handheld package.    With a frequency range up to 7.5 GHz, these analyzers deliver reliable automatic measurements and multiple modes of operation. The spectrum analyzer includes a built-in amplifier and independent signal source, fast scanning speed, high sensitivity. It can monitor RF broadcasts, perform channel power scanning, power monitoring, wireless interference location, electromagnetic compatibility measurements, and other functions. The cable and antenna testing function includes built-in DC voltage bias, with a 1-path-2-port vector network analysis function. It can measure TDR, VSWR, debug port matching issues, perform insertion loss measurements, tower amplifier debugging, cable fault location, Smith charts, etc.
With two models (SHA851A/SHA852A) the specifications include:
  Spectrum Analyzer:
  • Frequency Range from 9 kHz up to 3.6/7.5 GHz,
  • Displayed Average Noise Level (Typ.), -165 dBm/Hz
  • Offset Phase Noise (1 GHz, Typ.), -104 dBc/Hz.@10 kHz
  • Minimum Resolution Bandwidth (RBW) 1 Hz up to 10 MHz
  • Preamplifier and independent signal source up to 7.5 GHz,
  • GPS positioning and logging
  Cable and Antenna Test
  • Frequency Range from 100 kHz up to 3.6/7.5 GHz,
  • Distance To Fault and Time Domain Analysis
  • Vector Network Analyzer
  • Bias out up to 32VDC
  • Typical working time 4 hours,
  • Weight 7lb
  • 8.4” Multi-Touch Screen, Mouse and Keyboard supported
The explosion of RF Technologies such as 5G and IoT has created a highly complex electronic measurement environment.  Monitoring and debugging these applications are increasingly shifting from laboratories and workstations to on-site and outdoor applications, requiring reliable handheld measurement instruments. Applications for the SHA800A analyzers include communication engineering, telecom operation and maintenance, radio management, factory production, education and teaching, and many others. They provide a capable and more economical alternative to other handheld analyzers. Siglent SHA800A Analyzers are available now from Saelig Company, Inc.
more information: https://www.saelig.com/siglent-spectrum-analyzers/sha852a.htm
MYIR Launched $14 ARM SoM based on Allwinner T113-S3 dual-core Cortex-A7 SoC
MYIR has launched a new SoM MYC-YT113X based on Allwinner SoC after introduced the MYC-YT507H for T507-H last year. The MYC-YT113X CPU Module is powered by Allwinner T113-S3 processor which features up to 1.2 GHz Dual-core ARM Cortex-A7 processor with 128MB DDR3 on-chip memory. Additionally, the MYC-YT113X takes more other advantages of the T113-S3 MPU such as the single-core HiFi4 DSP, Robust Video Engine and extensive connectivity to provide an ideal solution for smart control and HMI applications in the automotive and industrial sectors. MYIR offers two standard configurations for 256MB Nand Flash or 4GB eMMC external memory options. A number of peripheral and IO signals are access through 1.0mm pitch 140-pin stamp-hole (Castellated-Hole) expansion interface.
The MYC-YT113X CPU Module is a highly integrated SoM, measuring only 39mm by 37mm. It is capable of running Linux and provided with software resources including kernel and driver source code, together with detailed user manual and documentations to help customer start their development rapidly.
MYC-YT113X CPU Module Top-view and Bottom-view (delivered with shielding cover by default)
Features Of MYC-YT113X CPU Module
  • Dimensions: 39mm x 37mm
  • PCB Layers: 6-layer design
  • Power supply: 5V/1A
  • Working temperature: -40~85 Celsius (industrial grade)
  • Allwinner T113-S3 processor
    – Up to 1.2GHz Dual-core Arm Cortex-A7 with built-in 128MB DDR3
    – Single-core HiFi4 DSP
    – Supports H.265/H.264 video decoding up to 1080p@60fps and JPEG/MJPEG video encoding up to 1080p@60fps
  • 4GB eMMC or 256MB Nand FLASH
  • 32KB EEPROM
  • 0mm pitch 140-pin stamp hole expansion interface
    – 1 x RGMII/RMII
    – 2 x USB2.0
    – 6 x UART
    – 2 x CAN
    – 4 x TWI
    – 2 x SPI
    – 1 x GPADC and 4 x TRADC
    – 1 x MIPI DSI
    – 1 x Single-channel LVDS and 1 x Dual-channel LVDS or 24-bit RGB (supports up to 1080p@60fps)
    – 1 x RGB
    – 1 x Parallel CSI
    – 2 x I2S
    – Up to 59 GPIOs (Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet and CPU Module pin-out description file)
  • Linux OS
MYC-YT113X CPU Module Function Block Diagram
MYIR provides MYD-YT113X Development Board for evaluating the MYC-YT113X CPU Module. It has a versatile base board to facilitate the expansion from the MYC-YT113X through the 140-pin interface, such as serial ports, USB, Ethernet, CAN, WiFi, LVDS, Audio and so on. It is an excellent evaluation platform as well as a solid reference design for customers using the MYC-YT113X CPU Module or solutions based on T113-S3 processors.
MYD-YT113X Development Board Top-view
MYD-YT113X Development Board Bottom-view
The MYC-YT113X CPU Module is a high-performance and ultra-low-cost SoM, pricing at only $14/pc for the 256MB Nand Flash version (MYC-YT113S3-256N128D-110-I). Discount is to be offered for volume quantities. MYIR also provides OEM/ODM services to help customers accelerate their time to market and save cost.
MYD-YT113X Development Board Function Block Diagram
More information about above new products can be found at: https://www.myirtech.com/list.asp?id=722
AAEON Deepen Ties with Adaptiv Networks to Expand the US SD-WAN Market
With network security a priority in the hybrid working world, AAEON and Adaptiv lead the way.
The value of the SD-WAN solutions market is projected to hit $13.7 billion worldwide by 2026, with more and more organizations making data security a priority. As one of the leading manufacturers of advanced network computing and security hardware platforms, AAEON seeks to make a big contribution in the attempt to achieve this market growth, with a greater focus on providing versatile and cost-effective networking solutions to the US market.
To do this, AAEON has strengthened ties with Adaptiv Networks, a leading cloud-native SD-WAN-as-a-Service vendor with whom AAEON has had a strong partnership for a number of years. In collaboration with Adaptiv, AAEON will help enterprises to simplify their network infrastructure, increase network performance, and improve security.
With its continuously expanding desktop and rackmount network appliance ranges, AAEON has demonstrated a commitment to innovation by incorporating the newest and most sophisticated Intel® platforms to give network security providers the most effective and market-ready white box solutions. This commitment has paid off in the past, with AAEON being awarded Gold Partner status in 2022’s Intel Network Builders Winners’ Circle Program, in recognition of its successful adoption and commercialization of Intel® architecture in its network platform solutions hardware.
Adaptiv’s SD-WAN solutions are designed to address the growing need for enterprises to securely connect to cloud applications and services. In addition to this, there is a growing emphasis on supporting remote and hybrid working environments, for which organizations must balance network functionality with data security.
The increased prevalence of SD-WAN and SaaS solutions illustrates a positive and necessary shift towards institutions prioritizing network security and reliability as hybrid working environments become the new norm. This is why AAEON choose to work with elite providers like Adaptiv to ensure organizations receive the benefits that its white box solutions offer.
For more information about AAEON’s network appliance range, please visit our website or contact an AAEON representative directly.
For more information about Adaptiv’s award-winning cloud-managed network connectivity solutions, please visit their website.
TOP PCB Companies
