ET980 COM Express Module with 12th Gen Intel Core Processors for Edge Computing
IBASE Technology Inc, a world leader in the manufacture of embedded boards and solutions, has added the ET980 series of COM Express modules to its portfolio. Supporting the U-series and P-series of 12th Gen Intel® Core™ processors from i3-1220PE to i7-1265UE (12M Cache, up to 4.70GHz), ET980 provides a platform with 10-12% boost in productivity performance compared with the previous generation. It is especially suited for applications demanding responsive technology to handle compute-intensive tasks simultaneously, such as medical instruments, industrial automation and control, robotics, and embedded gaming.
ET980 FEATURES:
  • Onboard 12th Gen Intel® Core™ i7/i5/i3 processors
  • 2x DDR4-3200 SO-DIMM sockets, Max. 64GB
  • Onboard 2.5 GbE
  • Supports 3x independent displays via HDMI / DP / VGA / LVDS or eDP
  • 4x USB 3.2, 8x USB 2.0, 2x SATA III, 2x COM
  • 1x PCI-E(x16), 1x PCI-E(x4), 4x PCI-E(x1) to carrier board
  • Digital I/O, TPM (2.0), Watchdog timer
The ET980 offers fast data transmission with an Intel® I226LM 2.5 GbE controller that is Time Sensitive Networking (TSN) capable. The integrated Intel® UHD Graphics drives independent display outputs (HDMI, DP, VGA, LVDS or eDP) to boost productivity levels. Two DDR4 SO-DIMM sockets are available with a capacity of 64GB to meet the needs of demanding real-time applications. The COM Express Type 6 module also supports 4x USB 3.2, 8x USB 2.0, 2x SATA III, 2x COM ports and 1x PCI-E(x16), 1x PCI-E(x4), 4x PCI-E(x1) expansion via the carrier board.
“The new ET980 COM Express module is ideally suitable for use in high-performance IoT edge computing and offers our customers the shortest time to market,” said Wilson Lin, Director of IBASE Product Planning Department. “Its upgradability and versatile design provide a competitive advantage, enabling lower cost of ownership through high configurability and optimum scalability.”
more information: www.ibase.com.tw
Discover LEMO’s new 12G-SDI 4K Ultra High Definition transmission push-pull connectors
LEMO is thrilled to announce the expansion of its field-proven S Series push-pull connectors with the new 1S.275 Series for 12G-SDI (Serial Digital Interface) 4K Ultra High Definition transmission. The new robust push-pull connectors are compliant with the SMPTE ST 2082-1 standard for signal/data transmission and enable a transmission rate of 12 Gbit/s meeting the 12G-SDI transmission standard and providing eight times the bandwidth of a standard HD-SDI in a single link. The chocolate bar shape makes it easier to grip and handle with ease.
LEMO has developed these connectors in response to the rapidly advancing technology landscape and market demands for high transmission rates, lighter structure, low-latency in live events for the Audio Video Broadcasting (AVB) market segments and other market segments like medical imaging platforms such as endoscopy and laparoscopy, among others.
The optimum design of these connectors ensures seamless transmission with high precision, reliability, low return loss, making it a viable alternative to using dual 6G or Quad 3G links. Currently, many 4K professional cameras use Quad link BNC connectors to transmit 12G signals for UHD displays. The newly introduced LEMO product will facilitate the transmission of 12G-SDI using a compact single link connection for UHD displays, enabling higher panel density thus reducing the number of cables/ connectors.
Thanks to its expertise and cable assembly capabilities, LEMO is at your disposal to assist you in providing complete interconnect solutions.
Find out more on: www.lemo.com
Texas Instruments bq25628/bq25629 Battery Charger ICs
Texas Instruments bq25628/bq25629 Battery Charger ICs are highly-integrated 2A switch-mode battery charge management and system power path management devices for single-cell Li-ion and Li-polymer batteries. The solution is highly integrated with built-in current sensing, loop compensation, input reverse-blocking FET (RBFET, Q1), high-side switching FET (HSFET, Q2), low-side switching FET (LSFET, Q3), and battery FET (BATFET, Q4) between system and battery. The device uses narrow VDC power path management, regulating the system slightly above the battery voltage without dropping below a configurable minimum system voltage. The low impedance power path optimizes switch-mode operation efficiency, reduces battery charging time, extends battery life during discharging phase, and the ultra-low 0.15µA ship mode current extends battery shelf life. The I2C serial interface with charging and system settings makes bq25628 and bq25629 truly flexible solutions.
The bq25628 supports a wide range of input sources, including a standard USB host port, USB charging port, and USB-compliant high-voltage adapter. The bq25629 has the ILIM pin to set the default input current limit and TS_BIAS pin for controlled thermistor bias. The device complies with USB 2.0 and USB 3.0 power specifications for input current and voltage regulation and meets the USB On-the-Go (OTG) operation power rating specification up to 2.0A
  • High-efficiency, 1.5MHz, synchronous switching mode buck charger for single-cell battery
    • >90% efficiency down to 25mA output current from 5V input
    • Charge termination from
    • Flexible JEITA profile for safe charging over temperature
  • BATFET control to support a shutdown, ship mode, and full system reset
    • 1.5µA quiescent current in battery-only mode
    • 0.15µA battery leakage current in ship mode
    • 0.1µA battery leakage current in shutdown
  • Supports Boost Mode operation to power accessory
    • Boost Mode operation supporting 3.84V to 5.2V output
    • >90% boost efficiency down to 100mA boost current for 5V PMID
  • Supports a wide range of input sources
    • 3.9V to 18V wide input operating voltage range with 26V absolute maximum input voltage
    • Maximizes source power with input voltage regulation (VINDPM) and input current regulation (IINDPM)
    • VINDPM threshold automatically tracks battery voltage
  • Efficient battery operation with 15mΩ BATFET
  • Narrow VDC (NVDC) power path management
    • System instant-on with depleted or no battery
    • Battery supplement when the adapter is fully loaded
  • Flexible autonomous or I2C-controlled modes
  • Integrated 12-bit ADC for voltage, current, and temperature monitoring
  • High Accuracy
    • ±0.4% charge voltage regulation
    • ±5% charge current regulation
    • ±5% input current regulation
  • Safety
    • Thermal regulation and thermal shutdown
    • Input, system, and battery overvoltage protection
    • Battery, and converter overcurrent protection
    • Charging safety timer
Application Circuit
Texas Instruments bq25628/bq25629 provides various safety features for battery charging and system operations, including battery negative temperature coefficient thermistor monitoring, charging safety timer, and overvoltage and overcurrent protections. The thermal regulation reduces the charge current when the junction temperature exceeds the programmable threshold. The STAT output reports the charging status and any fault conditions. Other safety features include battery temperature sensing for charge mode and OTG boost mode, thermal shutdown and input UVLO, and overvoltage protection. The INT output notifies the host when a fault occurs or status changes. The bq25628 and bq25629 are available in an 18-pin, 2.5mm × 3.0mm WQFN package.
more information: https://www.ti.com/product/BQ25628
Energy harvesting PMIC from Nexperia includes MPPT tracking
Nexperia, the expert in essential semiconductors, today announced an expansion to its range of Power ICs with Energy Harvesting solutions to simplify and enhance the performance of low-power internet of things (IoT) and other embedded applications. The NEH2000BY is a high-performance power management integrated circuit (PMIC) which recharges a battery or storage capacitor using energy harvested from ambient sources, such as light (which can be harvested using a photovoltaic cell). As a result, Nexperia’s NEH2000BY will enable the development of electronic devices that are self-powered, smaller, and environmentally friendly. Furthermore, this energy harvesting solution can help mitigate the environmental impact of the billions of batteries produced and discarded each year.
Nexperia’s NEH2000BY PMIC makes it much easier to design energy harvesting solutions which can be up to 20x smaller than other competing offerings and do not require manual optimization for individual applications. In addition, the PMIC was designed without inductors, simplifying PCB design, and significantly reducing overall BOM and board size, with a 12 mm² assembly area.
To achieve the highest conversion efficiency, energy harvesting solutions must be able to adapt as the ambient energy source fluctuates. The NEH2000BY performs Maximum Power Point Tracking (MPPT), an adaptive algorithm to optimize how it transfers harvested energy and to achieve optimum average conversion efficiency by up to 80%. This unique MPPT algorithm combines speed with accuracy, allowing the PMIC to adapt to environmental changes in less than a second. This is significantly faster than any other currently available solution and maximizes the amount of energy harvested over the course of a day, vastly expanding the number of application areas. Furthermore, due to its self-optimization functionality and ability to operate autonomously without the requirement for pre-programming, the NEH2000BY makes it easier for designers to power devices with ambient energy.
Nexperia’s energy harvesting solutions enable economical energy harvesting from various ambient sources in applications consuming up to several milliwatts of power, including wireless IoT nodes, wearable smart tags, and electronic shelf labels.
Dan Jensen, General Manager Business Group Analog & Logic IC’s at Nexperia adds,
“The NEH2000BY’s cost-efficient, user-friendly, and compact nature will allow the adoption of energy harvesting in a larger range of use cases. By eliminating the requirement to change batteries in these applications, NEH2000BY will significantly reduce the amount of hazardous waste produced, with enormous environmental benefits.”
The NEH2000BY is available in a 16-lead, 3 mm × 3 mm QFN package and operates between -40°C and +85°C.
To learn more about our new product, please visit our website at www.nexperia.com/product/NEH2000BY or read the blog post for more in-depth information: https://efficiencywins.nexperia.com/efficient-products/adaptive-energy-harvesting-pmic.
Highly stable digital MEMS gyroscope for dynamic applications
TDK Corp. introduces the Tronics Gypro4300, a highly stable and vibration-resistant digital MEMS gyroscope for dynamic applications. The gyro is also ideally equipped for use in vehicles.
The Tronics Gypro4300 features an input measurement range of ±300 °/s, a bandwidth of 200 Hz and a latency of 1 ms, and has a closed-loop architecture that ensures high linearity and stability in dynamic environments. The Gypro4300 is the first product in the new Gypro4000 high-performance MEMS digital gyroscope platform, which complements the AXO300 digital closed-loop accelerometer platform.
With an excellent bias instability of only 0.5 °/h as a typical value (2 °/h maximum) and an ARW (Angular Random Walk) of 0.1 °/√h, the Gypro4300 offers a miniaturised, digital MEMS high-performance gyroscope with a low SWaP (Size, Weight and Power) value, paving the way for a new generation of high-precision positioning, navigation and stabilisation functions in dynamic applications such as rail vehicles, land vehicles, VTOL (Vertical Take-Off and Landing) aircraft and UAV (Unmanned Aerial Vehicles), marine and underwater systems, drilling and surveying instruments.
Compact, robust gyroscope for use in high-vibration environments
The Gypro4300’s closed-loop architecture provides high vibration damping of 0.5 °/h/g² in harsh conditions. The gyroscopes are housed in a hermetically sealed, ceramic J-lead miniature enclosure that offers long operating and storage life, as well as high compliance with the stringent temperature cycling requirements of critical applications. They feature hard-coded electronics with a 24-bit SPI digital interface for rapid integration into INS (Inertial Navigation Systems), IMU (Inertial Measurement Units) and AHRS (Attitude and Heading Reference Systems). To minimize mechanical coupling in multi-axis applications, the Gypro4300 is available for three frequency ranges.
Thanks to its miniature package and low power consumption, Gypro4300 offers a digital, low-cost and low-power alternative to bulky, expensive and power-hungry solutions such as DTG (Dynamically Tuned Gyros) and FOG (Fiber Optical Gyroscopes). Thanks to its solid-state architecture, which reduces the number of internal components and system complexity, the Gypro4300 has an MTBF of more than 1,000,000 hours, which is ten times more than established DTG and FOG solutions with similar performance. In addition, the built-in self-test provides both an initial check of the sensor’s integrity and a continuous functional test during operation.
The Tronics Gypro4300 gyros are ideally complemented by the AXO300 high-performance digital accelerometers, which use the same SMD J-lead ceramic package and digital interface to enable cost-effective integration, mounting and board reliability, even in rapidly changing temperature conditions.
The Gypro4300 is available for sample and customer evaluation directly from Tronics or through specialised distribution channels such as TEXIM in Europe. Rapid evaluation of the sensors can also be done with an Arduino-based evaluation kit that offers built-in test functions such as reading and recording outputs, recalibration and digital self-testing.
more information: www.tdk.com
High Performance NanoPi R6C With Rockchip RK3588S
Powerful Performance: FriendlyElec designed and built the NanoPi R6C (as “R6C”). It is an open-source mini IoT gateway with one 2.5G and one Gbps Ethernet port. It has a Rockchip RK3588S CPU, 4GB/8GB LPDDR4x RAM, and 32GB eMMC flash.
Multiple Software:  It works with operating systems like FriendlyWrt, Android, Debian, Ubuntu, etc., and it can boot from TF cards. It also works with headless systems. It comes with a built-in Docker. Docker Hub world’s largest library and community to contain images, and enable users to create, manage, and so on. The user’s application can run on FriendlyWrt via Docker.
Supports Decoding Video Stream of 8K Videos: It can decode video streams of 8K@60fps H.265/VP9 and 8K@30fps H.264 formats.
Storage capacity: The NanoPi R6C has one M.2 NVME port and two USB ports, and it can get power from a USB type-C port. It is a great portable way to store photos and videos. FriendlyElec has made a custom CNC housing for it that was carefully designed.
High Speed 2.5 G Ethernet port: It has one Gigabit Ethernet, and one PCIe 2.5G Ethernet overall, the NanoPi R6C is a board with multiple Ethernet ports, a light NAS, and the ability to play videos with a support upto 2.5 Gbps transmission rate.
32GB eMMC: This onboard 32GB eMMC flash serve as a bootable device to boot a Friendly-Elec-made OS. Running a system is made easier and more stable with this board.
Supports Multiple Methods of System Installation: There are three ways of system installation, for detailed information regarding installation is provided here.
The NanoPi R6C has a small size of 90 x 62 mm and a lot of hardware resources. It has a 30-pin header to expose hardware resources for secondary development, such as GPIO, I2C, I2S, PWM, and SPI interfaces. It also has one HDMI port.
Specifications
  • SoC: Rockchip RK3588S
    -CPU: Quad-core ARM Cortex-A76(up to 2.4GHz) and quad-core Cortex A55 CPU (up to 1.8GHz)
    -GPU: Mali-G610 MP4, compatible with OpenGLES 1.1, 2.0, and 3.2, OpenCL up to 2.2 and Vulkan1.2
    -VPU: 8K@60fps H.265 and VP9 decoder, 8K@30fps H.264 decoder, 4K@60fps AV1 decoder, 8K@30fps H.264 and H.265 encoder
    -NPU: 6TOPs, supports INT4/INT8/INT16/FP16
  • RAM: 64-bit 4GB/8GB LPDDR4X at 2133MHz
  • Flash: 32GB/None eMMC, at HS400 mode
  • Ethernet: one Native Gigabit Ethernet, and one PCIe 2.5G Ethernet
  • USB: one USB 3.0 Type-A and one USB 2.0 Type-A
  • PCIe: one M.2 Key M connector with PCIe 2.1 x1
  • HDMI:
    -compatible with HDMI2.1, HDMI2.0, and HDMI1.4 operation
    -support up to 7680×4320@60Hz
    -Support RGB/YUV(up to 10bit) format
  • microSD: support up to SDR104 mode
  • GPIO: 30-pin 2.54mm header connector up to
    -1x SPI,
    -3x UARTs
    -3x I2C
    -2x SPDIFs
    -1x I2Ss
    -3x PWMs
    -20x GPIOs
  • Debug:
    -UART via 3-Pin 2.54mm header or onboard USB-C to UART
  • LEDs: 4 x GPIO Controlled LED (SYS, WAN, LAN, LED1)
  • Others:
    -2 Pin 1.27/1.25mm RTC battery input connector for low power RTC IC HYM8563TS
    -MASK button for eMMC update
    -one user button
  • Power supply: USB-C, support PD, 5V/9V/12V/20V input
  • PCB: 8 Layer, 62x90x1.6mm (without case) 68 x 94.5 x 30 mm (with case)
  • Ambient Operating Temperature: 0℃ to 70℃
  • Material: Aluminum
  • Weight: 53.1 g (without case) and 260g (with case)
See the Wiki page for detailed information.
Applications
It aids in the development of mini machine vision systems with multiple Ethernet ports and also helps the development of an embedded system to explore and implement prototype design.
Purchase Information
The product page sells NanoPi R6C for $85.00. For further information regarding product options purchase, combinations are all detailed on their webpage.
Radxa’s ROCK 3C Supported by Rockchip RK3566 Processor
Radxa’s ROCK 3C (Radxa’s latest single board computer) features a Rockchip RK3566 64-bit quad-core Cortex-A55 ARM processor, 32-bit 3200Mb/s LPDDR4, and up to 4K@60 HDMI. Because of their low cost, wide range of interfaces, and top-notch design and performance, these single-board computers are perfect for use in both personal and professional endeavors. Additionally, it has a frequency of up to 1.6GHz, as well as a Mali G520 GPU and an 8TOPS NPU.
It has HDMI with a resolution of up to 4K@60, MIPI DSI and MIPI CSI, a 3.5mm jack with microphone, a USB port, GbE LAN, PCIe 2.0, and a 40-pin color extension header. Power over Ethernet (PoE) is supported by the Gigabit LAN, but an extra HAT is needed to get power from PoE. The website states that it can mechanically fit many of the existing Raspberry Pi 4 accessories.
The “Getting Started” page has a lot of information, such as what parts are needed, how to prepare, how to write an image, how to access the host, and so on. The official images for Debian Bullseye, Ubuntu Server 20.04, and Android11-20220408_1204 can be found on the Download page. There are also images from third parties and images made by the community.
Specifications
  • Processor: RK3566 64bit quad-core processor
    Quad-core Cortex-A55, frequency 1.6Ghz
  • GPU: Mali G52
  • NPU: 0.8TOPS NPU
  • Memory: LPDDR4, LPDDR4@2112MT/s, 1/ 2/ 4/ 8GB variants
  • Wifi/BT Antenna: Wifi/BT with external antenna support (uFL)
  • Storage: eMMC module (optional), Optional industrial level high-performance eMMC module, 16G/32G/64G/128G available (click on module bottom side)
  • Micro SD card: uSD card slot supports up to 128GB uSD card,
  • M.2 SSD: M.2 (M) 2230 up to 1T M.2 NVME SSD.
  • Display HDMI: HDMI 2.0 up to 4k x 2k@60, MIPI DSI 2 lanes via FPC connector, HDMI and MIPI DSI can not work at the same time.
  • Audio: Audio 3.5mm jack with mic with improved mechanics, HD codec that supports up to 24-bit/96kHz audio.
  • Camera: MIPI CSI 2 lanes via FPC connector, support up to 800 MP camera.
  • Wireless: Wireless 802.11 ac
  • WiFi 5 / Bluetooth 5
  • USB: USB 3.0 HOST x1, USB 2.0 OTG port x1 (middle upper one), USB 2.0 HOST x2, default – DEVICE, activate – HOST via serial command GPIO header.
  • Ethernet: GbE LAN (with Power over Ethernet (PoE) support via additional PoE HAT)
  • IO 40-pin expansion header :
    – 5 x UART
    – 1 x SPI bus
    – 2 x I2C bus
    – 6 x PWM
    – 1 x ADC
    – 6 x GPIO
    – 2 x 5V DC power in
    – 1 x 3.3V power in
  • Others:
    -RTC
    -RTC battery connector for time backup (optional)
    -Power button
    -Dual pin PWM fan header (controller chip onboard)
  • Power USB-C recommended 5V/3A (5V/5A is recommended when using with SSD)
  • Dimension: Size 85mm x 56mm
Essentials For Getting Started
  • ROCK 3 Model C
  • Power adapter with USB type C port equal to or larger than (5V3A) 15W (or -5V5A – 25W with mounted SSD)
  • MicroSD Card or eMMC module with eMMC-to-uSD adapter board
  • Keyboard & Mouse
  • Monitor with HDMI input
The product page sells ROCK 3C 1GB for $39.00, 2GB for $44.00, 4GB for $54.00, and 8 GB for $74.00. Currently, 2GB,4GB, and 8 GB are out of stock.
High Computing Power AI Mainboard from Firefly
The Octa-Core AI mainboard from Firefly has a high processing capacity and is driven by the SOPHON AI processor BM1684X. This mainboard supports up to 16GB of RAM. INT8 computational power of up to 32TOPS.
A New Generation Processor: This mainboard is powered by the new generation SOPHON AI processor BM1684X, which has octa-core ARM Cortex-A53, a frequency of up to 2.3GHz, and a 12nm lithography process. It has up to 32Tops (INT8) of computing power, and 16TFLOPS (FP16/BF16) of computing power,  It works with popular programming frameworks and can be used in a lot of cloud and edge applications for AI inference.
Powerful multi-channel video AI performance: Up to 32 channels of 1080P H.264/H.265 video decoding can be done on the mainboard. It can process and analyze over 16 channels of HD video at the same time, which makes it great for AI applications like face detection and license plate recognition on live video streams.
Complete software and hardware: With full software and hardware, it’s easy to do artificial intelligence inference for both cloud and edge applications. All of them speed up the development of edge applications like face recognition, video structuring, abnormal alarm, equipment inspection, situation prediction, etc.
The one-stop toolkit is convenient and efficient: The SOPHON SDK one-stop deep learning development toolkit includes a number of software tools.
Specifications
  • SOC: SOPHON BM1684X
  • CPU: High-performance octa-core ARM A53, 12nm lithography process, frequency up to 2.3GHz.
  • TPU: Built-in tensor computing module TPU, computing power up to: 32TOPS (INT8), 16TFLOPS (FP16/BF16), 2TFLOPS (FP32)
    Support mainstream programming frameworks: TensorFlow / Caffe / PyTorch / Paddle / ONNX / MXNet / Tengine / DarkNet.
  • VPU: 32-channel H.265/H.264 1080p@25fps video decoding 32-channel 1080P@25fps HD video processing(decoding + AI analysis)
    Support 12-channel H.265/H.264 1080p@25fps video encoding
  • RAM: 6GB/12GB/16GB LPDDR4/LPDDR4X
  • Storage: 32GB/64GB/128GB eMMC
    -128MB SPI Flash
    -1 x M.2 SATA3.0 SSD (2242)
    -1 x TF card slot
  • Ethernet: 2 x 1000Mbps Ethernet
  • Wireless Network: 2.4GHz/5GHz dual-band WiFi, 802.11a/b/g/n/ac, capable of 4G LTE expansion (Mini PCIe), 5G (M.2)
  • Video Output: 1 x HDMI(1080p@30fps)
  • Audio Output: 1 x HDMI audio output
  • USB: 2 x USB3.0 (current limit: 1A)
    2 x USB2.0 (current limit: 500mA)
  • Power: DC 12V/5A (DC5.5×2.5mm)
  • Other Interfaces:  1 x RS232, 1 x RS485, 1 x Debug(3P-2.0mm)1 x FAN(12V,4P-1.25mm)
  • OS: Linux
  • Dimension: 149mm × 97mm × 37.45mm
  • Weight: 180g
  • Environment: Operating Temperature: -20℃~60℃
    -Storage Temperature: -20℃~70℃
    -Operating humidity: 10%~90% (non-condensing)
Applications
Several popular application programming frameworks such as open SDK, a one-stop AI development toolkit, and a full, user-friendly toolchain are all provided. These features enable quick deployment of algorithm applications and inexpensive algorithm migration. This mainboard can be used for intelligent security, intelligent transportation, intelligent parks, intelligent retail, intelligent finance, smart cities, industries, energy, and more.
Sequent Microsystem’s 6-in-1 LCD Adapter HAT for Raspberry Pi
For standalone Raspberry Pi projects, Sequent Microsystems developed an LCD display adapter with a rotary encoder and 6 switches. The software has drivers for scrolling messages of up to 256 characters. The speed of scrolling can be changed from the command line. The messages can be played just once or over and over again in a loop.
Video
LCD Display Adapter Kit for Raspberry Pi:
The HDMI port on the Raspberry Pi can be used to drive a monitor or a TV. However, the majority of embedded systems only need to display a small amount of data. The ability to interact locally with the Pi and show a few lines of text may be really useful. Both 1602 and 2004 displays with monochrome or RGB backlit can be brought together. The RGB displays use 18 pins, while the 16-pin connector for monochrome displays. All six possible combinations can be inserted into the same 18-pin header and controlled from the same interface.
Monochrome or RGB backlit display connector
Universal, 6-in-1 Display Adapter HAT Specification:
Block diagram
LCD Display Adapter PCB Layout
The 6-in-1 Display Adapter HAT accommodates 2004 and 1602 displays with monochrome or RGD backlighting.
  • I/O Interface: The Display Adapter plugs into the Raspberry Pi’s GPIO connector. It only uses the I2C port to communicate with the Pi, so the other 26 GPIO pins can be used for other things. It can be put on top of any HAT that can be stacked.
  • Microprocessor: The display adapter includes a 32-bit STM32G030 microcontroller (up to 64MHz). It has two functions: First, it reads the state of the pushbuttons and the rotary encoder and reports it to the Raspberry Pi. Second, it implements commands received from the Raspberry Pi on the display adapter. The adaptor can show flashing, scrolling, or static messages.
  • Software: Python, Node-RED, and the command line are all included.
  • Misc: 1 x Rotary encoder. (The easiest way to move through multiple menus, show input values, and control outputs is to turn the rotary encoder)
    6 x Pushbuttons.
  • There are 2 types of standard tiny LCD displays:
    • 2 lines with 16 characters each (LCD1602) measure about 80mm x 36mm.
    • 4 lines with 20 characters (LCD2004). The 77 x 47mm and 98 x 60mm sizes of the 2004 display are available.
LCD1602 Display Adapter Hat
The 1602 LCD Display comes in different colors and has two lines of 16 characters each.  It comes without a connector or with a male connector already soldered with monochrome or RGB backlighting.
LCD Adapter with 1602 Display
LCD 1602 Display Adapter
If 16 characters and two lines are enough for an application, the groves on the side of the PCB are taken out and a rotary encoder is the soldered and top row of 6 pushbuttons. The adapter has 19mm standoffs and can be put on top of any other Raspberry Pi I/O card that can be stacked.
LCD Adapter for 1602 Display with Rotary Encoder and Six Pusp Buttons
LCD2004 Display Adapter HAT
The 2004 LCD Display has four lines of 20 characters each and comes in different colors. It comes without a connector or with a male connector already soldered with monochrome or RGB backlighting.
To use the display adapter with 20 characters and 4 lines displays, a rotary encoder is soldered, and the 6 pushbuttons are provided on the bottom row.
Components:
  • The surface mount components on a printed circuit board are all put together. Installed and tested microprocessor firmware.
  • 2×20 Male-Female Raspberry Pi Tall GPIO header.
  • Mounting hardware: brass standoffs, nuts, and screws. The adapter is installed using the 19mm standoffs on top of Raspberry Pi. In the case of the female header for the LCD display the display is secured with the 11mm standoffs.
  • Rotary Encoder and 6 pushbutton switches.
  • 1 x 18 Male and Female Pin Headers.
Detailed assembly of the LCD Display Adapter Kit is available on the product page.
The product page states that Command Line, Python, and Node-RED drivers are available and can be downloaded from GitHub. An example of nested menus to implement a multi-zone sprinkler controller in Node-RED can also be downloaded.
Purchase Information:
LCD Display Adapter Kit for Raspberry Pi is available for a Pledge of $20 or more on kickstarter.com
iWave’s most anticipated 64-bit Arm-A55 and RISC-V MPU-based System on Module is launched at EW23
iWave Systems announced an upcoming iW-RainboW-G53M: RZ/G2UL, RZ/A3UL, RZ/Five based System on Module (SOM) built on OSM v1.1 Size-M specification at the Embedded World 2023 trade fair. The module delivers sophisticated features and enhanced performance for IoT endpoint devices while reducing overall costs.
RZ/G2UL, RZ/A3UL, and RZ/Five MPUs are available with the same pin package enhancing the compatibility of the SOM architecture. Using the same pin package assignment and peripheral functions across different MPUs, the SOM lets the customer choose either the Cortex-A55 core to target Linux-based HMI applications or the RISC-V AX45MP core, depending on their needs.
The same board design can be adapted to develop new products simply by replacing the chip. In addition, this compatibility enables an engineer to easily transition the development platform from RTOS to Linux-based products, enabling efficient product development across multiple platforms.
The main features of RZ/G2UL, RZ/A3UL, RZ/FIVE-based System on Module are as follows,
  • Compatible with RZ/G2UL or RZ/A3UL or RZ/FIVE MPU
  • Supports Cortex-A55 cores (RZ/G2UL & RZ/A3UL)
  • Supports Cortex-M33 core for RTOS (In RZ/G2UL)
  • RISC-V Andes AX45MP @1.0GHz (FIVE)
  • 2x RGMII, 2x USB 2.0
  • 1x MIPI CSI, 1x RGB (not available on RZ/Five)
  • 2GB DDR4 RAM
  • OSM Size-M LGA Module
ARM Cortex-A55 core leverages AI performance and Cortex-M33 Core supports real-time processing. Incorporating video codec unit along with interfaces like camera input, display, USB, CAN, and Gigabit Ethernet, this system provides a cost-effective solution and sophisticated functionality in industrial HMIs, industrial equipment, and embedded devices with GUI & Video capabilities.
RZ/G2UL System on Module is a low end, energy and cost-efficient platform designed for entry class embedded applications. RZ/A3UL MPUs utilize the superior real-time performance of RTOS to achieve high performance. Whereas RISC-V processor-based SOM is optimized to provide performance and peripheral functions required for IoT endpoint devices. Additionally, RZ/FIVE processor features the Andes AX45MP CPU, which operates at a maximum frequency of 1GHz. AX45MP is a good replacement for high-performance application processors for heavy-duty applications such as AR/VR, AI/ML, 5G, and video/image processing.
The SOM is built on a 30mm x 45mm OSM Size-M standard, and has a low power consumption, making it suitable for use in compact and energy-efficient systems. Designed to enable direct soldering to carrier cards, the SOM provides high levels of robustness and is ideal for products prone to vibration. With an operating temperature range of -40°C to 85°C, this SOM is suitable for use in a wide range of industrial applications where temperature fluctuations can be a concern.
“IoT gateways must have high computational capabilities to provide real-time insights,” said Ahmed Shameem M H, Hardware Project Manager at iWave Systems. “Integrating the powerful 64-bit Arm technology in the new OSM standard can help build rugged and compact products with better performance and reliability. Furthermore, the SOM’s compatibility with the ARM A55 and RISC-V architectures broadens customer choices and increases product development freedom.”
RZ/G2UL, RZ/A3UL, RZ/Five SOM is mounted on a carrier board as a Single Board Computer (SBC), which can also be used as an evaluation kit. This feature-rich multimedia insert-ready SBC is available in Pico-ITX form factor, and is a great candidate for many IoT and embedded applications.
RZ/G2UL, RZ/A3UL, RZ/Five Single Board Computer Features:
  • Arm Cortex-A55 @1.0GHz
  • 2GB DDR4 (Optional), 16GB eMMC (Expandable), Octa SPI Flash (Optional)
  • Micro SD Slot, M.2 Connector Key B (USB 2.0, Nano SIM Connector)
  • Gigabit Ethernet x2, USB 2.0 OTG, USB 2.0 Header
  • RS232, CAN, Debug UART, RTC Battery
  • MIPI Connector
  • Expansion – UART x2, SPI x1, ADC x2 (Optional)
  • 12V DC, -40°C to +85°C Industrial
  • 100 mm x 72 mm (Pico ITX)
  • Linux or RTOS OS support
The System on Module and Single Board Computer are go-to-market and production ready complete with documentation, software drivers, and a board support package. iWave maintains a product longevity program that ensures that modules availability for long periods of time (10+ years).
More information on Renesas OSM System on Modules can be found here.
TOP PCB Companies
