12V Step-Up DC-DC Converter from 1.8V to 5V Input
- Rajkumar Sharma
- 123 Views
- easy
- Tested
- SKU: EL145312
- Quote Now
This is a DC/DC converter that combines a traditional voltage feedback loop and a unique current feedback loop to operate as a constant-current, constant-voltage source. The project has been designed using the LT1618 chip. The board provides 12V/150mA output, from input supply 1.8V to 5VDC. The LT1618 uses a constant frequency, current mode control scheme to provide excellent line and load regulation.
- Input Supply 1.8V to 5V
- Output 12V @ 150mA
- Boost Converter with 500mA Input Current Limit
- Operating Frequency 1.4Mhz
- Efficiency up to 80%
- Header Connector for Input and Output
- Low Profile, small size PCB
- PCB Dimensions 18.89 x 14.13mm
The LT1618 step-up DC/DC converter combines a traditional voltage feedback loop and a unique current feedback loop to operate as a constant-current, constant-voltage source. This fixed frequency, current mode switcher operates from a wide input voltage range of 1.6V to 18V, and the high switching frequency of 1.4MHz permits the use of tiny, low-profile inductors and capacitors. The current sense voltage is set at 50mV and can be adjusted using the IADJ pin.
Connections
- Pin 1 = Input Supply 1.8V To 5V DC
- Pin 2 = GND
- Pin 3 = GND
- Pin 4 = Output 12V DC
Schematic
Parts List
NO | QNTY. | REF. | DESC. | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 4 PIN MALE HEADER PITCH 2.54MM | ADAM TECH | DIGIKEY | 2057-PH1RB-04-UA-ND |
2 | 2 | C1,C3 | 4.7uF/16V X7R CERAMIC SMD SIZE 0805 | SAMSUNG | DIGIKEY | 1276-2970-1-ND |
3 | 1 | C2 | 10nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
4 | 1 | C4 | 2.2uF/16V X7R CERAMIC SMD SIZE 0805 | TDK | DIGIKEY | 445-1420-1-ND |
5 | 1 | D1 | SS14 FAST DIODE | ON SEMI | DIGIKEY | SS14CT-ND |
6 | 1 | J1 | OPEN/SOLDER JUMPER | |||
7 | 1 | L1 | 10uH | BOURNS | DIGIKEY | SRR4011-100YLCT-ND |
8 | 2 | R1,R2 | 0.2E 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
9 | 1 | R3 | 2K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
10 | 1 | R4 | DNP | |||
11 | 1 | R5 | 0E SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
12 | 1 | R6 | 909K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
13 | 1 | R7 | 107K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
14 | 1 | U1 | LT1618 MSOP 10PIN | ANALOG DEVICES | DIGIKEY | LT1618EMS#TRPBFCT-ND |
LT1618 Block Diagram
