2.4V to 5V Step Up DC-DC Converter
  • Rajkumar Sharma
  • 89.217 Views
  • medium
  • Tested
  • SKU: EL35973
  • Quote Now
Step Up Dc-DC
This project is a step up DC to DC power converter able to convert 2.4V – 5V to 5Vdc.
Description
This project has been designed around Texas Instrument’s LM2623 IC, The LM2623 is a high efficiency, general purpose step-up DC-DC switching regulator for battery powered and low input voltage systems. It accepts an input voltage between 2.4V to 12V volts and converts it into 5V DC. Efficiencies up to 90% are achievable with the LM2623.
Features:
  • Good Efficiency over a very wide load range
  • Very low output voltage ripple
  • 2.4V to 5V (Possible Input Supply up to 14V operating voltage)
  • 5V output voltage (Other output voltages possible by changing R3 and R4)
  • 600mA output current
Application:
  • Hand held instruments
  • Cameras, PDA, Cellphones
  • White LED driver
Schematic
image description
Parts List
image description
PCB
Downloads
53 Comments
Nizam uddin
I like electronics lab.com
hakanak
Does it provide 5V continously even when the input is 2.5V ?
AlexRogers
will the output be stable if the Vin fluctuates?
panjooel
Sorry, i am really zero knowledge of this, and i dont know where to start learning. can i ask how much R3 and R4 should be for output around 3.3v-3.5v. thanx if you want share how to calculate it. 🙂
panjooel
yes, i see.. thanx for the link and reference page number..:) so if R4 is 100k, i just need R3 150-160K.. really thanks…
kim
What kind of inductor you used here and what is R2 0E?
kim
Can i use this inductor? https://www.amazon.com/uxcell-Axial-4-7uH-Color-Inductors/dp/B008MP0HS0. Can i ask the C5 too? Can i use a through hole capacitor? Thanks
kim
Can you recommend an alternative inductor that is not surface mounted because i need it for my project and we need to put it on breadboard. Thank you so much 🙂
kim
can i use electrolytic capacitor on C5?
kim
How about using a 1.5V or 6V battery for the input?
kim
can i use a polarize capacitor for C5?
kim
Can i use solar panel that’s 3V for the input instead of a battery?
kim
Hi! When i finished breadboarding the circuit and put an input voltage of 6 volts the output was 6 volts too. Why does it happened? 🙁
kim
Hi 🙂 I changed the input into 3V but the output is 3V too.
mixos
Please check for damaged diode or IC.
sangeeth sharma
what is the output A’s
Eddy
What are the exact dimensions of the pcb drawn in this page. Thanks.
Eddy
Can i use through hole components (on a new pcb) for all the parts (except the lm2623 of course) ?
Eddy
Thanks for answering.
Another issue : is there a way to improve the maximum output current to let’s say 1.5A or 2A. What are the modifications needed for this purpose? Thanks in advance.
rajeon
PCB Size 24.13X26.99MM
Eddy
Thanks
Eddy
Why the output is oscillating continuously between 4.8 and 5.3 V (not stable) ?
Eddy
Have rebuilt the circuit using your pcb (not the mine) and it works just fine. I’m using it to feed an audio amplifier rated at 6w (2x3w) so the current drawn is 1.2A (6w/5v) vs an announced nominal current of 500mA ?? Is there an explanantion.
Thanks.
James
where can I buy the components for this board?
Anil Tan
Hi i need to charge my samsung s8 with this kind of circuit via aa batteries. .So in need 2 A output. Are there any suggestion for me?
zidni
where i can buy the module? .. but if input 2.4 volt and current is 30 micro ampere, can work the module?
Andrea Poma
Hi Kumar,
could you send me the gerber file?
@ andrea-poma@hotmail.com
Thanks
md kamal ahamed
i need
@ 1-5 vdc to 5 vdc dc dc step up converter with 2000ma
@ intelligent emergency led light driver making circuit diagram . 230vac input and 4vdc utput. 3,7 or 4 vdc li ion battery back up.
ii want t make by myself. i need easy diagram with available parts.
DennisJensen
Hi. Please help me out here
My challenge: I need to boost 3V to 5V, and I need to do it yesterday. – I need something I can buy fast.
Can I buy 10 pcs of this or something smilair and where?
Perferably in Denmark, Europe, US, Asia – This due to the delivery time.
VERY big thanks for any help.
Dennis Jensen
jaya
Can i get 5v from 10v for this circuit?If not ,what are the modification?
RELATED PROJECTS
TOP PCB Companies
