[Customadds id=643821] This is a low profile and small size two-channel MOSFET board that can drive loads up to 2 x 3A. The Power Supply is 5V to 14V DC. Inputs and input Enable are TTL-level signals. The Output is by default enabled and an active high signal disables the output. Parallel Operati... Read More
- full (317x252)
- medium (317x252)
- medium_large (317x252)
- large (317x252)
- 1536x1536 (317x252)
- 2048x2048 (317x252)
- re_large (317x252)
- re_xmedium (317x236)
- re_medium (317x252)
- menu-24x24 (24x19)
- menu-36x36 (36x29)
- menu-48x48 (48x38)
- sendpress-max (317x252)
- woocommerce_single (317x252)
- wp_rp_thumbnail_prop (150x119)
