2 Channel Wi-Fi Relay Module Using ESP8266 NodeMCU
[Customadds id=643821] The project described here is an ESP8266 NodeMCU Two Channel Relay Module. This board enables users to control 2 x relays remotely. The 2 channels can be controlled remotely using a webserver/WiFi connection. The project works with 5VDC. Two LEDs indicate relay operation. S... Read More
- full (1500x1291)
- medium (850x732)
- medium_large (640x551)
- large (640x551)
- 1536x1536 (1500x1291)
- 2048x2048 (1500x1291)
- re_large (783x600)
- menu-24x24 (24x21)
- menu-36x36 (36x31)
- menu-48x48 (48x41)
- sendpress-max (600x516)
- woocommerce_single (600x516)
- wp_rp_thumbnail_prop (150x129)
