sch.jpg - Electronics-Lab.com
30
2 Channel Wi-Fi Relay Module Using ESP8266 NodeMCU
[Customadds id=643821] The project described here is an ESP8266 NodeMCU Two Channel Relay Module. This board enables users to control 2 x relays remotely. The 2 channels can be controlled remotely using a webserver/WiFi connection. The project works with 5VDC. Two LEDs indicate relay operation. S... Read More
