200W Lamp Flasher
- Rajkumar Sharma
- 10.845 Views
- moderate
- Tested
- SKU: EL34573
- Quote Now
Description
200W Lamp Flasher kit is used to flash lamps, bulbs and halogen lamp to give your product that attracting look.
- Input supply – 6 ~ 12 VDC
- Output – upto 200 W lamp / bulb load
- Optically isolated Mains supply
- Onboard preset to adjust the frequency (speed) of flashing (1 Hz to 5 Hz)
- Power Battery Terminal (PBT) for easy input 230 VAC mains and load connection
- Terminal pins for connecting DC power supply
- Four mounting holes of 3.2 mm each
- PCB dimensions 36 mm x 68 mm
Schematic
Parts
excellent
