24V to 36V @ 2A DC-DC step-up Converter using LM2588
- Rajkumar Sharma
- 6.573 Views
- easy
- Tested
- SKU: EL78688
- Quote Now
This is another DC-DC boost converter that provides 36V DC output from 24V DC input with load current up-to 2A. The board is very small. Switch-mode converter is based on LM2588 IC from Texas Instruments. The LM2588 regulator integrated circuit specifically designed for fly-back, step-up (Boost) , and forward converter. Board has minimum components, screw terminal provided for input & outputs.
- Supply Input 24V DC (18-36V Possible)
- Output 36V
- Load Current Up to 2Amps
Schematic
Hi
Would it be possible to get the Gerber files and parts list for this projekt?
Sure, let me upload it to this page.
Uploaded above, thanks
