4.5A H-Bridge DC Motor Driver Module Using TB6549HQ
[Customadds id=643821] The H-Bridge Motor Driver Module Based on TB6549HQ IC from Toshiba, is a full-bridge driver IC for DC motors that uses an LDMOS structure for output transistors. High-efficiency drive is possible through the use of a MOS process with low ON-resistance and a PWM drive system... Read More
- full (807x480)
- medium (300x178)
- medium_large (640x381)
- large (640x381)
- 1536x1536 (807x480)
- 2048x2048 (807x480)
- re_large (783x480)
- menu-24x24 (24x14)
- menu-36x36 (36x21)
- menu-48x48 (48x29)
- woocommerce_single (600x357)
- wp_rp_thumbnail_prop (150x89)
