H-Bridge-DC-Motor-Driver-Module-pic.jpg - Electronics-Lab.com
84
4.5A H-Bridge DC Motor Driver Module Using TB6549HQ
[Customadds id=643821] The H-Bridge Motor Driver Module Based on TB6549HQ IC from Toshiba, is a full-bridge driver IC for DC motors that uses an LDMOS structure for output transistors. High-efficiency drive is possible through the use of a MOS process with low ON-resistance and a PWM drive system... Read More
