GRB BOTTOM.jpg - Electronics-Lab.com
10
4 Channel Current Sense Amplifier - Low and High-Side Voltage Output
[Customadds id=643821] This 4-Channel current sense amplifier is designed for cost-optimized applications. This is a current-sense amplifier (also called a current-shunt monitor) that senses the voltage drop across current-sense resistors at common-mode voltages from –0.2 V to +26 V, independen... Read More
