4 channel infrared remote relays
- Rajkumar Sharma
- 83.497 Views
- medium
- Tested
- SKU: EL36876
- Quote Now
Description
4 Channel Infrared (IR) Remote controller is using HT12A and HT12D encoder / decoder chips from Holtek.
- Supply – Transmitter : 3 to 5 VDC, 5 V @ 20 mA & Receiver : 5 VDC @ 200 mA
- Output : 4 channel Latch or Momentary on board Jumper for selection
- Crystal based oscillator for reliability of operation
- Jumper selectable 8 bit address code
- LED output to indicate reception
- On/Off slide switch in the transmitter
- Power-On LED indicator in the Receiver / Transmitter
- Valid transmission indicator
- 4 LED for Relay On/Off status
- Four mounting holes of 3.2 mm each
- PCB dimensions – Transmitter : 43 mm x 56 mm & Receiver : 80 mm x 73 mm
Schematic
Parts List
Receiver BOM
Circuit seems to be good. I have not yet tried. Is it a straight forward in the final working or there may be problems?.Thanks
Circuit is tested and working as it should be. You can try it for your self.
what is size of pcb LAYOUT unit?
The transmitter PCB size is 46.36 x 59.69mm and receiver size is 86.36 x 83.19mm
Any alternative of IC’s i do not have and not in my region.
Have you checked on ebay.com?
WHER TO CONNECT SW6 CIRCUIT SIR PLEASE TELL ME
i want to buy complet project 4 ir led using encorder decoder
Check on this website http://www.koteq.com for kits.
can I use universal IR remote to operate this circuit
But these ICs are used for 433mhz transmitter and receiver, So will it work in IR also?????
They work for both RF and infrared transmissions.
i donT have HT12A IC SO CAN I USE HT12E IC ITS WORKING ORE NOT
I think it will not work as HT12E has slightly different characteristics.
its range ?
As it is based on IR emitter and receiver, the range would be in the range of meters as a common TV remote control.
i dont hav 455khz crystal can i use 4Mhz
It is necessary to use a 455Khz crystal for the internal oscillator to work.
can we use ir blaster app of mobile as transmitter
can you tell me alternate of HT12A IC because it is not available
I don’t know any alternative for this IC but you can find it online on many shops.
THANK YOU
HT12E WORK ? I DONT FOUND HT12A ?
please show me your circuit diagram…
Circuit diagram is published above.
How to increase the output voltage.pls tell me sir
Which output voltage do you mean? With the output relays you can control many types of loads.
CAN I USE 5V RELAY
You can use 5V relay.
Project updated to version 2
is the version 2 this project? Or is there link for version 2?
The above is the version 2. Thanks
can use it for drone with dc motor? i want to make with 18650 battery. can you help me how? thx 🙂
This project is used to control a load by turning it on or off but a drone needs motor speed control.
How to check ic ht12a working or not.
Check on pin 17 if signal is present when you press a button.
the BC557 transistor is PNP transistor or NPN transistor
It’s a PNP transistor. Datasheet here: https://www.mouser.com/ds/2/302/nxp_bc556_557-1188849.pdf
can i use any alternative ic insted of HT12A?
You can check if HT12E + HT12D will work on this project. The datasheet will help you.
What is the price ?
Unfortunately we don’t sell kits or assembled boards, but we can produce and ship the board if order quantity is >25 pieces
Can I hold ON position in all four channel at a time ???
No, this is not possible with this project. If you press all switches at the same time, all outputs will go high, but then if you press any of the switches then all goes off.
I’m trying out the circuit using an ht12e instead of a ht12a , so I introduced a timer after to generate the 38khz necaessary for the tsop1738 . However there seems to be a problem with the transmission . The tsop1738 could not detect it . I wired up the data pins directly to check the working and it work Ed , but it was without ir . Could I have some help ?
The HT12E works somewhat different than the HT12A. It doesn’t have a 38khz carrier and it will trigger on different pin. The A is recommended for infrared usage.
Sir is there any coding required for same circuit or not.
What do you mean? Please explain.
Sir i want to know. Any programming requires to burn into the ic’s of this project
No, the ICs on this project are not microcontrollers and do not require programming.
Where from You build the PCBs? Can you share me contacts?
The boards was manufactured locally.
Hi
Can i replace HT12A and HT12D with PT2276 and PT2272?
Hi please tell me can I use any universal tv remote instead off transmitter board which is designed by you.
No, it has to be an HT12A transmitter.
Hello, I see this is what i need for my project. Any help tracking down (sites supplying pcb/parts) all the parts and pcb for the units would be appreciated..
We use http://www.jlcpcb.com for our PCBs and mouser.com or tme.eu for our parts. They may work for you as well.
Can I use 500 khz oscillator in alternative of 445 khz
How can i make the channels independent, meaning i can turn on or of different channels without turing off the already on one?
HI,
The project is based on HT12A and HT12D chips, they don’t have such facility to work independent, it work as what you see in video, follow our other project it works as per your requirement, link is bellow,
https://www.electronics-lab.com/project/16-channel-tiny-infrared-remote-controller-nec-code/
What you think that i can use universal IR remote operation of this circuit.
