4 Channel Opto-Isolated Module Using High Speed 6N137 Optocoupler
- Rajkumar Sharma
- 11.363 Views
- moderate
- Tested
- SKU: EL63678
- Quote Now
4 Channel Opto isolated board has been designed around 6N137 Opto-coupler, the 6N137 optocoupler is designed for use in high-speed digital interfacing applications that require high-voltage isolation between the input and output. Applications include line receivers, microprocessors or computer interface, digital programming of floating power supplies, motors, and other control systems.
The 6N137 high-speed optocoupler consists of a GaAsP light-emitting diode and an integrated light detector composed of a photodiode, a high-gain amplifier, and a Schottky-clamped open-collector output transistor. An input diode forward current of 5 milliamperes will switch the output transistor low, providing an on-state drive current of 13 milliamperes (eight 1.6-milliampere TTL loads).
Note : For 3.3 Input Signal R1, R4, R7, R10 = 220E
- Supply 5V DC
- Input Signal : 5V DC TTL
- Header Connectors for Inputs & Outputs
- D1 Power LED
Schematic
