4-Channel-Opto-Isolated-Module-C088B-500×500.jpg - Electronics-Lab.com
44
4 Channel Opto-Isolated Module Using High Speed 6N137 Optocoupler
[Customadds id=643821] 4 Channel Opto isolated board has been designed around 6N137 Opto-coupler, the 6N137 optocoupler is designed for use in high-speed digital interfacing applications that require high-voltage isolation between the input and output. Applications include line receivers, micropr... Read More
