4 Digit MultiPlexed 0.33 Inch 7 Segment Common Anode Display
- Rajkumar Sharma
- 9.721 Views
- easy
- Tested
- SKU: EL52029
- Quote Now
7 Seven segment multi-plexed display is tiny board that has been designed around Common Anode 4 digit Display, Display has 12 Pins. The board is provided with current limiting resistors on all LED segments and 4 PNP Transistors to drive 4 digits, the project is ideal for easy micro-controller interface with 13 pin Header connector. The Board supports 3.3V as well 5V TTL interface.
Schematic
Parts List
Photos
Login
