40 PIN & 28 PIN PIC18F USB Development Board
- Rajkumar Sharma
- 13.335 Views
- medium
- Tested
- SKU: EL61265
- Quote Now
PIC18F USB Development Board will help you with your prototyping requirement with any 28/40-pin Microchip microcontroller supporting USB interface . The board has been tested using PIC18F4550 40 Pin & PIC18F2550 28 Pin Microcontroller.
- All ports terminating in separate Box Header with 5 VDC source option
- ICSP connector for programming for the PIC’s with ICD support
- Bridge in the input provides any polarity DC supply connection to the board
- 20 MHz crystal source
- Onboard +5V Voltage regulator
- Four mounting holes of 3.2 mm each
- PCB dimensions 77 mm x 87 mm
Schematic
Parts List
Photos
Login
