ac_dimmer.png - Electronics-Lab.com
56
400VA AC Light Dimmer
[Customadds id=643821] Schematic [alert type="danger" icon-size="normal"]Additional precautions must be taken as this power supply uses lethal voltages. Build it only if you know what you are dealing with.[/alert] Description This is a simple TRIAC AC load dimmer used to control the power ... Read More
