5V @ 3A Power Supply using TPS54302
- 7.294 Views
- easy
- Non tested
This circuit is based on TPS54302, a high efficient buck converter from Texas instrument. The input range for this circuit varies between 4.5V to 28V and it can produce an output voltage of 5V. Over voltage protection and over current protection are the two major advantages of this device.
- Input(V): 4.5VDC to 28VDC
- Output(V): 5VDC
- Output load: 3A
- PCB:85mm X 31mm
Parts List
Do you have the drill file?
Unfortunately the designer forgot to include the drill file on Gerbers. Sorry for that, they are not available.
