009.jpg - Electronics-Lab.com
15
5V - 4A Buck Converter using NR110E
[Customadds id=643821] This powerful buck converter can efficiently produce 5 V@4A with an input voltage between 7V to 31V. The project is built using the NR110E chip from Sanken Semiconductor. The IC integrates the power MOSFET. With current mode control, ultra-low ESR capacitors, such as cerami... Read More
