Infineon-IFX9201SG-DS-v01_01-EN.pdf - Electronics-Lab.com
26
6A H-Bridge with PWM-DIR input and SPI Interface
[Customadds id=643821] This 6A H-Bridge is designed for the control of DC motors or other inductive loads. The outputs can be pulse width modulated at frequencies up to 20kHz. PWM/DIR control reduces the number of PWM-capable pins needed on the microcontroller side. For load currents above the cu... Read More
