72 Channel Serial To Parallel Driver.pdf - Electronics-Lab.com
6
72 Channels Serial To Parallel Driver Board Using 74HC595 & ULN2803
[Customadds id=643821] 72 channels Serial (SPI) to parallel driver board has been designed for various applications. This project can be used as multi Solenoid driver, large size 7 segment display driver, bar graph driver, and LED driver. The project works with 5V logic levels. Output load supply... Read More
