8 Tactile Switch Board with High & Low Outputs
- Rajkumar Sharma
- 7.083 Views
- easy
- Tested
- SKU: EL64169
- Quote Now
8 Tactile Switch Input Board is a simple PCB offering an easy connection of a standard 10-pin Box Header connector to 8 small type Tactile Switch with a jumper selectable pull-up/pull-down of resistor network connected in parallel.
Specifications
- Input Voltage: 3.3V/5V
- Output Voltage: same as input
- Current rating: 0.5mA
- Operating temperature: -20 to 60oC
- PCB dimensions: 37 mm x 87 mm
8 TACTILE SWITCH WITH HIGH OR LOW OUTPUT JUMPER SCHEMATIC & PCB LAYOUT
Schematic
Login
