8 Tactile Switch Board with High & Low Outputs
[Customadds id=643821] 8 Tactile Switch Input Board is a simple PCB offering an easy connection of a standard 10-pin Box Header connector to 8 small type Tactile Switch with a jumper selectable pull-up/pull-down of resistor network connected in parallel. Specifications Input Voltage: 3.3V/5... Read More
- full (1079x803)
- medium (850x633)
- medium_large (640x477)
- large (640x476)
- 1536x1536 (1079x803)
- 2048x2048 (1079x803)
- re_large (783x600)
- menu-24x24 (24x18)
- menu-36x36 (36x27)
- menu-48x48 (48x36)
- woocommerce_single (600x447)
- wp_rp_thumbnail_prop (150x112)
