+9V-TO-60V-PWM-SOLENOID-VALVE-DRIVER-pcb-TOP.png - Electronics-Lab.com
13
+9V to 60V PWM 2.3A Solenoid Valve Driver using DRV101
[Customadds id=643821] The DRV101 is a low-side power switch employing a pulse-width modulated (PWM) output. Its rugged design is optimized for driving electromechanical devices such as valves, solenoids, relays, actuators, and positioners. The DRV101 module is also ideal for driving thermal devi... Read More
