AC Motor Speed Controller for Modern Appliances Using LS7311
- Rajkumar Sharma
- 11.674 Views
- medium
- Tested
- SKU: EL63883
- Quote Now
The project was specifically designed for motor speed control applications in appliances such as blenders, etc. Tact switches provided for selecting/indicating from 1 to 10 power levels ( Speed Levels). The project is ideal for universal and shaded-pole motor speed control for modern appliances design. Eliminates awkward mechanical switch assemblies and multi-taped motor winding.
- 10 Tact Switch for Speed Selection
- 10 LEDs for speed indication
- On-Board Stop and Start Switches ( Start Switch Latch Operation)
- Momentary Run Switch
- Supply 230V ( 110V Possible Refer Data sheet for components Change)
- 300W Load
- On-Board snubber for Inductive Load
- No Separate DC power supply required
NOTE: Dangerous voltages of 220V AC appears on this project. So take appropriate protection measures.
Schematic
nice. dimensions?
Please use the PDF file to print the PCB at correct dimensions.
I’m having a hard time finding this circuit for sale.
Please check on http://www.koteq.com for kits of our projects.
