AC Solid state Relay for Inductive Load
- Rajkumar Sharma
- 15.658 Views
- moderate
- Tested
- SKU: EL47318
- Quote Now
AC Solid state Relay for Inductive Load offers simple On/Off type Switch Control with TTL compatible input signal.
- Input signal : 2 ~ 5 VDC, TTL compatible
- Output : up to 500 W
- Mains supply input 230 VAC or 110 VAC
- Optically isolated Triac based design
- Power Battery Terminal (PBT) and Terminal pins for easy input / output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 35 mm x 72 mm
Schematic
I have one question, if I would need a higher rated inductive or resistive load is it enough to change only the triac (for ex. On Semi BTA25, BTA 30)? Thank you
on a and k can v give cd4017’s signal ? and how to connect it to some signal boards . please share video if possible.thank you
Sure, input can be any signal in the range 2-5V
Can I do without the L1 coil. Not sure where to find it.
