HIGH CURRENT AC SOLID STATE RELAY.pdf - Electronics-Lab.com
22
AC Solid State Relay
[Customadds id=643821] This simple circuit designed around Solid State Relay S216S02 from SHARP. The S216S02 solid State Relay (SSR) is an integration of an infrared emitting diode (IRED), a Phototraic Detector and a main output Traic. These devices are ideally suited for controlling high voltage... Read More
