Analog to Digital Converter module
- Rajkumar Sharma
- 19.308 Views
- moderate
- Tested
- SKU: EL44550
- Quote Now
This simple A2D (Analog to Digital) Converter Board can log upto 8 channel of analog signal with 8 bit resolution. This board uses the ADC0808 chip from National Semiconductor.
- Two standard box type header connector for easy connection of the board to various development boards or project
- Separate box header for Data and Control signal for the ADC
- Screw terminal connector for easy connection of Analog signal input or sensor connection to the board
- +5 VDC and Gnd connection available for sourcing supply for your sensor or add-on interface or signal conditioner board
- Onboard oscillator source for the analog to digital converter
- Four mounting holes 3.2 mm each
- PCB dimensions 54 mm x 63 mm
Schematic
Super
great help
