Audio Line Receiver using INA134
- Rajkumar Sharma
- 403 Views
- easy
- Tested
- SKU: EL121261
- Quote Now
The project described here is a differential line receiver consisting of high-performance INA134 OPAMPs with on-chip precision resistors. The project is fully specified for high-performance audio applications and has excellent AC specifications, including low distortion (0.0005% at 1kHz) and high slew rate (14V/µs), assuring good dynamic response. In addition, wide output voltage swing and high output drive capability allow use in a wide variety of demanding applications. The INA134 on-chip resistors are laser trimmed for accurate gain and optimum common-mode rejection. Furthermore, excellent TCR tracking of the resistors maintains gain accuracy and common-mode rejection over temperature. Operating power supply ±4V to ±18V (8V to 36V total supply).
This project is used in combination with the DRV135 Audio-Balanced Line Driver as the transmitter. Together they offer a complete solution for transmitting analog audio signals without degradation over a long distance.
- Power Supply +/-12V (SUPPLY RANGE: ±4V to ±18V)
- Low Distrortion: 0.0005% at f = 1kHz
- High Slew Rate: 14V/µs
- Fast Settling Time: 3µs to 0.01%
- Low Quiescent Current: 2.9mA max
- High CMRR: 90dB
- Fixed Gain= 0dB (1V/V)
- PCB Dimensions 39.37 x 360.48 mm
Applications
- Audio Differential Line Drivers
- Audio Mix Consoles
- Distribution Amplifier
- Digital Effects Processors
- Hi-Fi Equipment’s
Schematic
Parts List
NO. | QNTY. | REF. | DESC. | MANUFACTURER | SUPPLIER | PART NO |
1 | 1 | CN1 | 3 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1248-ND |
2 | 1 | CN2 | 3 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1248-ND |
3 | 1 | CN3 | 6 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5319-ND |
4 | 2 | C1,C5 | 10uF/20V SMD TANTLUM SIZE 1210/1411 | KYOCERA | DIGIKEY | 478-12567-1-ND |
5 | 2 | C2,C6 | 0.1uF/50V SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
6 | 3 | C3,C4,C7 | 470PF/50V SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
7 | 1 | D1 | LED 3MM THT | AMERICAN OPTO | DIGIKEY | 2460-L314GT-ND |
8 | 1 | R1 | 49.9E 1% SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
9 | 1 | R2 | 1.5K 5% SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
10 | 1 | U1 | INA134 SOIC8 | TI | DIGIKEY | INA134UA-ND |
CAPACITOR C1, C5 | CAN BE REPLACED WITH | 10uF/25V | ELECTROLYTIC CAPACITOR |
Connections
Application Diagram
