BO.Duino – ATmega328 Arduino Compatible board
- Сергей Бойко
- sergeihronos@gmail.com
- 10.372 Views
- medium
- Tested
BO.Duino
Description
BO.Duino is an Arduino compatible board based on ATmega328 ATMEL’s mcu. This board features many peripherals usually externally connected on a breadboard or prototyping board such as sensors, SD card etc. Peripherals included are:
- A real-time clock
- AT24 series external memory chip
- MicroSD card adaptor (SPI)
- RGB LED
- A potentiometer on analog input
- Connector for DS18b20 or DHt11 series sensors
The board should be configured as Arduino Duemilanova on Arduino IDE. A jumper is used to select the FT232 chip output level. Also the board’s power supply is selected manually. The FT232RL enables you to programm a new firmware or change the bootloader without the need of extrernal programmer .
Schematic
Photos
Login
