Breakout Board for UCC28019 and UCC28128 PFC Controller
- Rajkumar Sharma
- 205 Views
- easy
- Tested
- SKU: EL138953
- Quote Now
This is a breakout board for UCC28019 and UCC28128 PFC controllers. This module enables users to build a high-power PFC (Power Factor Correction) controller. Active PFC uses the boost topology operating in Continuous Conduction Mode (CCM). The controller is suitable for systems in the 100 W to >2 kW range over a wide-range universal ac line input. The startup current during an under-voltage lockout is less than 200 µA. The user can control low-power standby mode by pulling the VSENSE pin below 0.77 V. Low-distortion wave-shaping of the input current using average current mode control is achieved without input line sensing, reducing the Bill of Materials component count. Simple external networks allow for flexible compensation of the current and voltage control loops. The switching frequency is internally fixed and trimmed to better than 5% accuracy at 25°C. Fast 1.5-A gate peak current drives the external switch.
Numerous system-level protection features include peak current limit, soft over-current detection, open-loop detection, input brown-out detection, output over-voltage protection/under-voltage detection, a no-power discharge path on VCOMP, and overload protection on ICOMP. Soft-Start limits boost current during start-up. A trimmed internal reference provides accurate protection thresholds and regulation set-point. An internal clamp limits the gate drive voltage to 12.5 V.
- Supply 12V to 15V
- 8-pin Solution Without Sensing Line Voltage Reduces External Components
- Wide-Range Universal AC Input Voltage
- Fixed 65-kHz Operating Frequency
- Maximum Duty Cycle of 97%
- Output Over/Under-Voltage Protection
- Input Brown-Out Protection
- Cycle-by-Cycle Peak Current Limiting
- Open Loop Detection
- Low-Power User-Controlled Standby Mode
- PCB Dimensions 26.35 X 21.91 MM
Applications
- CCM Boost Power Factor Correction Power Converters in the 100 W to >2 kW Range
- Server and Desktop Power Supplies
- Telecom Rectifiers
- Industrial Electronics
- Home Electronics
Connections and Other Details
- Connector CN1
- Pin 1 = GND,
- Pin 2 = VCC,
- Pin 3 = NC,
- Pin 4 = VINS (Input AC Voltage Sense)
- Pin 5 = ISN (ISENSE) Current Sense
- Pin 6 = GND
- Pin 7 = Output (MOSFET GATE)
- Pin 8 = GND
- Pin 9 = NC
- Pin 10 = VF-Voltage Feedback from DC Output
- D2: Power LED
Schematic
Parts List
NO | QNTY | REF. | DESC | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 10 PIN MALE HEADER PITCH 2.54MM | MOLEX | MOUSER | 538-22-28-8100 |
2 | 10 | Q1,D1,C1,D3,R8,C10,R11,R15,R16,R17 | DNP | DO NOT INSTALL | ||
3 | 1 | C2 | 1.2nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
4 | 1 | C3 | 1nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
5 | 1 | C4 | 0.68uF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
6 | 1 | C5 | 0.22uF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
7 | 1 | C6 | 3.3uF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
8 | 1 | C7 | 10uF/25V CERAMIC SMD SIZE 1210 | YAGEO/MURATA | DIGIKEY | |
9 | 1 | C8 | 100nF/50V Ceramic SMD Size 0805 | YAGEO/MURATA | DIGIKEY | |
10 | 1 | C9 | 820PF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
11 | 1 | D2 | LED RED SMD SIZE 0805 | OSRAM | DIGIKEY | 475-1278-1-ND |
12 | 1 | R1 | 220E 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
13 | 1 | R2 | 91K 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
14 | 1 | R3 | 910K 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
15 | 1 | R4 | 3K 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
16 | 1 | R5 | 1E 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
17 | 1 | R6 | 1.8M 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
18 | 1 | R7 | 1K 5% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
19 | 1 | R9 | 13K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
20 | 1 | R10 | 1.1M 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
21 | 1 | R12 | 33.2K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
22 | 1 | R13 | 300E 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
23 | 1 | R14 | 100K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
24 | 1 | U1 | UCC28019 SOIC8 | TI | DIGIKEY | 296-34749-5-ND |
Typical Application
Connections
