Capacitive Humidity Sensor to Analog Output Converter
- Rajkumar Sharma
- 94 Views
- moderate
- Tested
- SKU: EL145088
- Quote Now
The project presented here is an analog capacitive humidity sensor converter board suitable for various humidity measurement tasks. The circuit comes from Texas Instruments application note (see below). Most conventional capacitive proximity sensors produce a digital signal, but this circuit produces a DC output voltage that is a function of the relative humidity of the environment. The oscillator input for this circuit is a 1Khz sine source (1Vpp) feed to FQ input. The low frequency and sine characteristics keep RFI problems at a minimum. This sensor output converter may prove difficult to construct because of the small capacitances involved, parasitic capacitances in the sensor circuit, and noise pickup. The circuit requires an external 1Khz sinewave with 1Vpp signal and operates with a dual 15V DC supply.
The circuit consists of a complete charge amplifier for the detection of the capacitive sensor’s capacitance change. The charge amplifier is followed by an absolute value circuit which serves as a full-wave rectifier. This part of the circuit converts the varying AC signal from the charge amplifier to a DC voltage, however this DC voltage is unfiltered and contains the carrier frequency ripple.
So the next part of the circuit takes this DC voltage and passes it through a 2-stage, 4-pole low pass filter to remove the ripple. This results in a DC voltage that is a function of the charge amplifier gain. To design the 4th order filter stage, Filter_Pro_v1.3 Tool is used.
The previous charge amplifier circuit produces a stable DC level for a fixed charge amplifier gain. In the diagram below the input sensor capacitance is changed to 3 different values, 160, 180 and 200pF, thus resulting in three different charge amplifier gains and corresponding DC levels.
Further Improvements
The circuit is not overly sensitive and a large DC level is present. Adding gain would help exaggerate the DC charge that results from the capacitance change, but the large DC level would be gained up as well. This would have to be dealt with in a subsequent stage.
- Power Supply +/-15V (Dual 15V DC)
- Header Connector for Sensor Inputs and Outputs
- On Board Power LED
- Works with various capacitive humidity sensors (see below)
- PCB Dimensions 60.17 x 16.19 mm
Connections
- CN1: Pin 1 = +V 15V DC, Pin 2 = Frequency Input 1Khz Sine Wave 1V Peak to Peak, Pin 3 GND, Pin 4 = GND, Pin 5 = Sensor, Pin 6 = -V 15V
- CN2: Pin 1 = +V 15V DC, Pin 2 = GND, Pin 3 = -V 15V, Pin 4 = GND, Pin 5 = Output
- D3 Power LED
A suitable capacitive humidity sensor for this board is the P14-W from IST-AG, but any other capacitive sensor with similar specifications should work. This sensor is ideal for universal humidity measuring tasks in a wide variety of different applications. The sensor is capable of measuring 0 % RH to 100 % RH (maximal dew point +85 °C) with a capacitance of 150 pF ±50 pF (wired) / 180 pF ±50 pF (SMD) (at 30 % RH and +23 °C) and operates within a temperature range of -50 °C to +150 °C. An alternative sensor is the KFS140-D from B+B sensors.
Schematic
Parts List
NO. | QNTY. | REF | DESC | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 6 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5319-ND |
2 | 1 | CN2 | 5 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5318-ND |
3 | 1 | C1 | 15nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
4 | 1 | C2 | 68nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
5 | 1 | C3 | 470nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
6 | 1 | C4 | 1.5uF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
7 | 1 | C5 | 180PF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
8 | 10 | C6,C7,C8,C9,C10,C12,C13,C14,C15,C16 | 100nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
9 | 2 | C11,C17 | 10uF/25V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
10 | 2 | D1,D2 | 1N4148 SMD | MICROCHIP | MOUSER | 494-1N4148UR-1 |
11 | 1 | D3 | RED LED SMD SIZE 0805 | OSRAM | DIGIKEY | 475-1278-1-ND |
12 | 1 | R1 | 2.05K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
13 | 1 | R2 | 17.4K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
14 | 1 | R3 | 1.5K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
15 | 1 | R4 | 16.5K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
16 | 1 | R5 | 10M 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
17 | 1 | R6 | 1K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
18 | 4 | R7,R8,R10,R11 | 10K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
19 | 1 | R9 | 5K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
20 | 5 | U1,U2,U3,U4,U5 | OPA132 SOIC8 | TI | MOUSER | 595-OPA132UA/2K5 |
Connections
Application Schematic
