IMG_0776.jpg - Electronics-Lab.com
26
Contactless Automatic Wardrobe LED Light with Fade Effect
[Customadds id=643821] Contact-less controlled automatic wardrobe light turns on the LED when you open the wardrobe door. Τhe project is based on Hall effect IC including LED driver and tiny magnet. Board doesn’t require any mechanical switch. When magnet is close to the board, LED is off, whe... Read More
