Dark-Activated-LED-Light-SCHEMATIC.pdf - Electronics-Lab.com
11
Dark Sensitive Switch - LED Light
[Customadds id=643821] Dark activated LED light is a simple project which operates a LED when the light falling on the LDR goes below a set point.  The circuit is built using LM393 comparator, LDR as light sensor, preset (potentiometer) for sensitivity adjustment, transistor to drive the LED. Th... Read More
