mcu_power_supply_bottom_copper_th.jpg - Electronics-Lab.com
19
Digital Multiple Voltage Power Supply
1.2 to 33 Volts DC @ 3 Amps [Customadds id=643821] Description This is simple to build microcontroller controlled power supply that can switch between 5 (or 32 or more) preconfigured voltages between 1.2 to 33 volts dc and up to 3 amps. This guide will walk you through every aspect of the bui... Read More
