DS1307 Real Time Clock Module
- Rajkumar Sharma
- 22.027 Views
- easy
- Tested
- SKU: EL39238
- Quote Now
This project is a Real Time Clock based on SD1307 RTC
Description
RTC Add-On Board offers an easy way to interface a standard I2C RTC IC type DS1307, into your project.
Specifications
- 5 VDC supply sourced through the interfacing Box Header connector.
- Battery backup for the RTC board available on the PCB
- Four mounting holes of 3.2 mm each
- PCB dimensions 50 mm x 33 mm
Schematic
Parts List
Possible to connect with Android box circuit? My Android box doesn’t have build-in RTC.
