Dual Voltage Power Supply
- Izhar Fareed
- http://www.extremecircuits.net
- izhar@gmx.us
- 45.935 Views
- moderate
- Tested
Description
The following circuit Diagram of (DUAL VOLTAGE POWER SUPPLY ) can be used for Misc.. application.
It requires a few components to built. The most important components of this circuit are REGULATORS.
1 : (AN) 7812 and 2 : (AN) 7912 AN7812 is the Positive Voltage Regulator. It regulates the voltage from (almost) 24vDC to 12vDC (accurate). AN7912 is the Negative Voltage Regulator. It regulates the voltage from (almost) -24vDC to -12vDC. A transformer output must be between 12vAC to 24vAC @ 500mA. Input of transformer (Primary)
should be about 110vAc-220vAC. It also include some capacitors to filter the current.
Where can I buy a dual power supply +/- 12 Volts, like this in Canada or in line?
Also check this power supply https://www.electronics-lab.com/project/12v-dual-power-supply/ . This one is available as a kit on http://www.kealab.com
